4 Pages V  < 1 2 3 4 >
> Edo's Celica DYNO TUNE., Gained some horses :D
post Jun 29, 2005 - 4:22 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
I told the same to Edo, he should get HKS 2 mm 6 layers metal head gasket and put it on, and then just slap the turbo... But he aint listen to me smile.gif
QUOTE(FallenHero @ Jun 28, 2005 - 11:15 PM)
which is why I'd slap on a high quality thick head gasket and boost the hell out of it. wink.gif
[right][snapback]306374[/snapback][/right]
<<<<<< DCw / JDMart >>>>>>>
post Jun 29, 2005 - 11:33 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(doGGy @ Jun 29, 2005 - 2:22 AM)
[right][snapback]306414[/snapback][/right]
EDO, LISTEN TO ROMAS!
post Jun 29, 2005 - 11:36 AM
don't use a think head gasket it will blow
EDO listen to me
This post has been edited by playr158: Jun 29, 2005 - 11:36 AM
post Jun 29, 2005 - 11:50 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(playr158 @ Jun 29, 2005 - 9:36 AM)
EDO listen to me
[right][snapback]306510[/snapback][/right]
as long as he gets a quality one it won't. They are, after all, made for it. Plus, he has already had his crank balanced with the pistons he has, so getting new pistons could be a problem... he also JUST re-built the engine.
This post has been edited by FallenHero: Jun 29, 2005 - 11:51 AM
post Jun 29, 2005 - 12:42 PM
true true
but considering stock cr is like 9.5:1 and my ideal is like 8.5:1 how thick of a headgasket would you need? and i mean for edo he's at like wat
11.5:1? he'd need a pretty thick one?
post Jun 29, 2005 - 2:49 PM
FallenHero
Joined Dec 26, '02
From Alabama
in all honesty, 7th gen celicas boost safely to over 250whp, and they run 11.5:1 compression. If you could get it down to 10:1 or in the 9's, that would significantly reduce risk. All in all htough, tuning is what is needed. Lower compression is just widens the errors less detramental.
post Jun 29, 2005 - 3:43 PM
doGGy
Joined Oct 28, '02
Playr, you aint reading again....... He is at 11.02:1.... Im at 10.8 with GZE pistons.... Using 2 mm head gasket at 10.8:1 CR i will get the 9.2 CR...... so in Edos case he will ge around 9.5 - 9.8, as for exact nnumber i have to count..
QUOTE(playr158 @ Jun 29, 2005 - 10:42 AM)
true true
[right][snapback]306541[/snapback][/right]
post Jun 29, 2005 - 3:44 PM
doGGy
Joined Oct 28, '02
Not only tuning..... Higher CR means higher Octane fuel. And hig CR and Boost means almost race fuel.... Detonation would kill.....
QUOTE(FallenHero @ Jun 29, 2005 - 12:49 PM)
[right][snapback]306591[/snapback][/right]
post Jun 29, 2005 - 5:54 PM
FallenHero
Joined Dec 26, '02
From Alabama
oh, I agree, but that doesn't change the fact that those seventh gen guys are making good power. You just can't screw anything up or the engine will have a short life. smile.gif
post Jun 30, 2005 - 8:42 AM
so are we back to the forget custom pistons and use
4agze pistons with a HKS 2mm 6-layer metal headgasket?
post Jun 30, 2005 - 12:16 PM
FallenHero
Joined Dec 26, '02
From Alabama
post Jul 2, 2005 - 4:30 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
i dont get it... in the first run, it says hp is 110... isnt that what st's come with stock??? because it says compression is 11 whatever. obviously this car has performance mods. i dont understand.
post Jul 2, 2005 - 6:19 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
They come with that to the crank, which is like 8x-9x to the wheels depending on various factors.
post Jul 3, 2005 - 2:23 AM
edo17982
Joined Dec 21, '02
From Italy
QUOTE(JoKeRkId613 @ Jul 2, 2005 - 11:30 AM)
[right][snapback]307529[/snapback][/right]
Well yes but mixture was rich as hell, that's the reason it only gave power as stock wink.gif
post Jul 3, 2005 - 3:53 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
still dont get it. lol. so whats the hp when everything is working correctly? with a perfect mixture and all that.
post Jul 3, 2005 - 8:06 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(JoKeRkId613 @ Jul 3, 2005 - 1:53 AM)
[right][snapback]307853[/snapback][/right]
127 hp at the crank.
post Jul 5, 2005 - 6:11 PM
nik
Joined Sep 30, '02
edo sell the head and come to the dark side (7age or 7agte) wink.gif tongue.gif
post Jul 6, 2005 - 5:54 AM
edo17982
Joined Dec 21, '02
From Italy
Well nick I'm gonna come to gark side but still not sure if the side is for 7AFTE or 7AGTE.
If doing 7afte I'd just need few things, instead if doing a 7AGTE I want to build it seriously to reach at least 300WHP so good internals etc, and to do so I'd need a spare blocks, a spare GE head and then all new electronic etc and really I dunno if at this point I would build an entire engine....
post Jul 6, 2005 - 2:13 PM
FallenHero
Joined Dec 26, '02
From Alabama
for sake of easiness, I'd just get a thicker head gasket and be done with it.
Jon
post Jul 6, 2005 - 4:36 PM
nik
Joined Sep 30, '02
QUOTE(FallenHero @ Jul 6, 2005 - 12:13 PM)
Jon
[right][snapback]309181[/snapback][/right]
yeah and turbo it with a good t3 turbo at about 10 psi thens its a whole different car
Lo-Fi Version Time is now: November 24th, 2024 - 9:56 AM
