> 4A GTE ???
post Apr 21, 2003 - 3:06 PM
macavely
Joined Nov 4, '02
OK has anyone got the 4A GE and Put a turbo on it
this is somthing i'm thinking about doing getting the 4A GE (whole front clip) and just adding a custom turbo.
post Apr 21, 2003 - 9:10 PM
EC_Knightrider
Joined Dec 2, '02
From Gainesville, GA
im sure there are alot of those old 86s with those on.....
would u rather do that than the swap of the 4agze?
post Apr 21, 2003 - 9:17 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (EC_Knightrider @ Apr 21, 2003 - 8:24 PM)
You are right.
It is way better to use the 4agze and turbocharge that than to use the 4AGE.
But I will honestly say that here in the hot and humid Caribbean, 4AGE + T have been successful turbo charge here in a crude way and stands up.
The most internal change is just forged pistons and an oil cooler.
I Know that the 4AGE 20v silver and black top comes with piston oil coolers. I am not sure if the 4age 16v has them.
If you can get a 4AGE 20v Silver top, use that instead and then you can turbocharge that to 240 very comfortable and easily with very light engine work.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Apr 21, 2003 - 9:24 PM
Are you thinking about a 16 valve or 20 valve 4A-GE? I'm not sure on the compression ratios of the older 16v engines, but the 20v engines have high compression ratios that would have to be lowered in order to turbo the engines through the use of internal engine parts such as low compression pistons. Also, I don't think the internals on the 20v engines can withstand a lot of boost without modifications, so you'd probably end up spending a lot of money on hard to find internal parts from Japan, as well as the turbo, manifold, intercooler, etc.
I think that you'd end up spending a lot of money, and it'd probably be cheaper to do a ST185 3S-GTE swap, plus chances are that you'd have more power, unless you really build up the engine and get some nice turbo components. wink.gif
On the other hand, it'd be very, very unique, and it'd be completely awesome to have a turbocharged, high-revving engine with the technology that the 20 valve 4A-GE has such as quad throttle bodies and five valves per cylinder. biggrin.gif
post Apr 21, 2003 - 10:07 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (Coomer @ Apr 21, 2003 - 8:38 PM)
Toda Racing offer all 4age 16v,20 parts
St185 would be a good swap
Either way, once you change to forge piston, you have the option for compression levels. You can either choose between 8.0 - 9.
If you are planning to turbo, go for an vavle angle job or a general head clean.
As I stated coomer, you can turbocharge high compression engines.
You only have to make sure you have gas and not too much boost like over 10psi.
The main problem I see here is the 20v since there can intake more air than a 4v head. So injector upgrades are neccessary. I think the 20v caris 280 or 310cc injectors. An increase to 420-550 would do very good.
I have seen more 20v engines damage here due to the lack of ffuel more than anything else.
post Apr 22, 2003 - 12:08 AM
macavely
Joined Nov 4, '02
the more and more i look the more i find there is so much i can do that i don't know WTF to do.
post Apr 22, 2003 - 10:53 PM
Charlie97L
From North Bethesda, MD
QUOTE (macavely @ Apr 21, 2003 - 9:22 PM)
turboing a 20V is tricky tricky. www.club4ag.com has a lot of good info.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Apr 22, 2003 - 11:00 PM
macavely
Joined Nov 4, '02
Thanks
post Apr 23, 2003 - 5:52 AM
west_minist
Joined Oct 27, '02
From Barbados
Once you understand the risk, everything will be good.
Either way, it is not a big deal.
Just keep your eye on oil levels, oil temperature and boost levels and boost spike, engine temperature, exhaust temp. and A/F meter.
Once you adhere to these parameters, you will be happy.
post Apr 23, 2003 - 6:54 PM
macavely
Joined Nov 4, '02
yea thanks right now i'm leaning more towards a turbo for my 7A but if i can find a 4A real cheap maybe
post Apr 23, 2003 - 7:11 PM
west_minist
Joined Oct 27, '02
From Barbados
macavely, if I may ask, are you between 18 -25yrs olds?
There are more advantages in the lone run with the 4AGE.
Call up ToySport or ask around for another dealer.
post Apr 23, 2003 - 7:34 PM
macavely
Joined Nov 4, '02
i'm 21
post Apr 23, 2003 - 9:33 PM
west_minist
Joined Oct 27, '02
From Barbados
I figure so.
My advice to you is to do some research and chat with some people who have it of it you were coming to barbados, i would hook you up with my Mechanic and friends
post Apr 24, 2003 - 12:25 AM
zigy
Joined Nov 6, '02
From Chicago, IL
sorry I didn't see this post....
how about going with 4AGE - AUTOMATIC.....?????????????
post Apr 24, 2003 - 5:34 AM
west_minist
Joined Oct 27, '02
From Barbados
check my reply is the other post zigy
Lo-Fi Version Time is now: November 28th, 2024 - 5:48 PM
