lowering Super Strut, is it possible?? |
Jun 30, 2005 - 6:54 AM |
Enthusiast Joined Jun 30, '05 From Ireland Currently Offline Reputation: 0 (0%) |
Hi all,
I have been looking forward to lowering my ss-3 celica but to my surprise I started to call a couple of my local parts shops(I live in Ireland) and they all tell me either its not possible to lower SS suspension or that the parts have been discontinued(Fensport). Can anyone suggest where/how much/opinions/part numbers on springs-coilovers Thanks |
Jun 30, 2005 - 10:25 AM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
try getting in touch with maikl. Click here for his profile. His has a full coilover set from Tein.
Jul 1, 2005 - 6:19 AM |
Enthusiast Joined May 24, '05 From Malta Currently Offline Reputation: 0 (0%) |
aren't the springs the same on SS and Macphersons? If so you just use normal lowering springs.
Jul 1, 2005 - 7:50 AM |
yozef...
would I be correct in saying that you drive an ssII which would make your suspension super strut also....Did you lower your motor? What did you use , where did you get them, how much were they, do you like them..... thanks |
Jul 1, 2005 - 8:43 AM |
Enthusiast Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
QUOTE(yozef @ Jul 1, 2005 - 6:19 AM) aren't the springs the same on SS and Macphersons? If so you just use normal lowering springs. [right][snapback]307210[/snapback][/right] Afraid not. They're still churning out TRD springs for ST205s, so something must be possible for a SSIII -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Jul 2, 2005 - 10:21 AM |
QUOTE(De_Bong @ Jul 1, 2005 - 7:50 AM) yozef... would I be correct in saying that you drive an ssII which would make your suspension super strut also....Did you lower your motor? What did you use , where did you get them, how much were they, do you like them..... thanks [right][snapback]307220[/snapback][/right] yes. mine's an SSII but not superstrut. |
Jul 6, 2005 - 5:36 AM |
Enthusiast Joined Nov 10, '03 From Netherlands Currently Offline Reputation: 0 (0%) |
I had a st202 with superstrut suspension, lowered it with toyo springs (40mm). You can replace the springs (but is not advisable), but you cant just replace the shocks. I believe that TRD has a nice kit for the celica's with superstrut suspension. Tein only had kits for celica's without superstrut (at least around here).
PS, the superstrut suspension (together with LSD) was a option around here, so if you have a st202 it doesnt mean you got superstrut suspension. This post has been edited by VlaCelica: Jul 6, 2005 - 5:40 AM |
Jul 12, 2005 - 5:43 PM |
QUOTE(VlaCelica @ Jul 6, 2005 - 5:36 AM) PS, the superstrut suspension (together with LSD) was a option around here, so if you have a st202 it doesnt mean you got superstrut suspension. [right][snapback]308967[/snapback][/right] SSIIs had optional superstruts. SSIIIs were standard. -------------------- JDM ST205
Jul 16, 2005 - 10:16 AM |
Enthusiast Joined Jul 24, '03 From Espaņa Currently Offline Reputation: 0 (0%) |
Hello, i have a ST202 with Super Strut
What Shoks are available to Super Strut system? Only TRD? Thanks! |
Jul 17, 2005 - 2:30 AM |
Enthusiast Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
TRD sure are still making Superstrut stuff - just placed an order for a set of springs for the 4.
Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Jul 17, 2005 - 7:34 AM |
Only TRD??
There Is not anything more? Tein? Koni? Bilstein? I just have Lowering springs on my CEli -4 cm This post has been edited by batmanjavi: Jul 17, 2005 - 7:43 AM |
Jul 19, 2005 - 2:59 PM |
Enthusiast Joined Dec 21, '04 From Netherlands Currently Offline Reputation: 0 (0%) |
Tein can deliver superstrut supension for a gt4
Jul 19, 2005 - 5:05 PM |
cough (monroe's make struts for our car)
QUOTE(batmanjavi @ Jul 17, 2005 - 7:34 AM) Only TRD?? There Is not anything more? Tein? Koni? Bilstein? I just have Lowering springs on my CEli -4 cm [right][snapback]313284[/snapback][/right] -------------------- |
Jul 20, 2005 - 5:52 PM |
QUOTE(LewFX @ Jul 19, 2005 - 5:05 PM) cough (monroe's make struts for our car) Probably not for superstrut suspension though. -------------------- JDM ST205
Jul 21, 2005 - 7:07 AM |
i´m going to buy the stock shocks... it is the cheapest solution.
Are this shocks hard or smooth?? This post has been edited by batmanjavi: Jul 21, 2005 - 7:08 AM |
Lo-Fi Version | Time is now: January 10th, 2025 - 1:56 AM |
