> Will heat hurt a BOV?, .. and where is yours mounted?
post Jun 30, 2005 - 6:58 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
Well, I just got some new pipework, and I'm in the process of fabricating it.
I was planning on putting the BOV somewhat near the throttle body - like within a foot or so.
I looked at my instruction thing to see if it gave a specific before/after intercooler, etc, and I saw it says "keep >20cm away from high heat (header)".
Well great, the flange doesnt sit flat where I want it to - so I need to either put it way off the TB, or put the flange within the 20cm "safety zone."
Do you think this would hurt the valve long or short term?
Do you all have recirculation kits for your SSQV's?
thanks
This post has been edited by mark_426: Jun 30, 2005 - 10:59 PM
post Jul 1, 2005 - 2:21 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
i dunno. doesnt seem like it would be a prob to me i mean its just a spring in a metal case that opens up at certain times. the line going to it would need to be metal cuz rubber would def melt. the bov would be on your way to the intake so it would be best if the whole thing was away from the block. piping that runs near turbo, header, over block will heat up real good.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Jul 1, 2005 - 7:32 AM
First 20 cm is pretty close. I dont think your in any danger. Second, it doesnt have to be on top of the throttle body, its actually less effective.
post Jul 1, 2005 - 3:33 PM
mark_426
Joined Jan 30, '05
So, where's the best place to put it?
post Jul 1, 2005 - 4:02 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(mark_426 @ Jul 1, 2005 - 12:33 PM)
[right][snapback]307373[/snapback][/right]
i like putting them between the intercooler and the turbo. relieve pressure on the turbo side of tings and makes it even less likely that there will be surging.
as for SSQV recirculation i have the kit, but i dont use it. the SSQV never leaks and only lets out as much air as it needs to, unless you develop stalling problems with open atmosphere, keep it open atmosphere
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
Lo-Fi Version Time is now: December 4th, 2024 - 3:30 PM
