> Does the GT-4 & a 94 ST have the same chassy?
post Jun 30, 2005 - 11:52 PM
TruPassionateArt
Joined Jan 11, '05
From Tacoma. Washington
The reason I ask is because my friend was thinking of converting his Celi to RWD.
post Jun 30, 2005 - 11:53 PM
no
post Jun 30, 2005 - 11:59 PM
read this thread
http://www.6gc.net/forums/index.php?showtopic=25793
post Jul 1, 2005 - 1:07 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
yeah rwd would be even harder than awd, because you would have to actually custom fabricate a whole new engine support system, wireing harness, rear differential and a mounting area for it, rear and front suspension, and not to mention things like power steering, shift cables, and etc... the easiest way i can think of would be to get a full drivetran and core supprot of both motor/tranny and rear diff. from an AE86 and use that, thats the only car i can think o that has a 3sgte in a rwd setup, or well i should say i know of that has been done by an individual, i know supras have had 3sgte's with rwd trannys in jgtc, but that doesn't count cuz they have custom trannys anyways, i don't know what teanny the ae86 3sgte swappers use but i do know that it exsist
but either way, rwd or awd, it would be very time and money consuming. but would def be something pretty unique when its done. thats why i plan on doing it.
so to conclude this post i think you should not do it, otr tell your friend he should not do it, because of the time and money involved and the fact i want to be the first in the states to do it
post Jul 1, 2005 - 11:11 AM
darksecret
Joined Mar 9, '05
From Charlotte
Give me a PM I have a ton of info, i'm working on the RWD swap and have a majority of the parts picked out (money is the only thing stopping me now), first off i'm using a number of Supra parts so it's going to run me about $20,000 doing the labor myself, but i'm rebuilding the 3SGTE. As far as the JGTC or Super GT Supras with the 3SGTE, a lot of them use the factory Getrag mainly because it's been able to handle up to 1,200 hp stock, the only reason they would consider switching it is for a different gear ratio, BTW a Getrag from Toyota will run a nice $6,000 without the spacers, snap rings and other goodies to make it work.
post Jul 2, 2005 - 7:22 PM
drnovascotia
Joined May 7, '04
From Concord, NH
No they don't have the same chassy ? I disagree, engine mounts are different for ST and GT but the body itself is the same for a ST and GT, pretty sure of this . .
Dr.
post Jul 2, 2005 - 9:35 PM
TruPassionateArt
Joined Jan 11, '05
Thanks for the replys. If it were myself, RWD wouldn't be an option but my friend has a good payin job & friends that are crazy enough to try.
post Jul 3, 2005 - 9:48 AM
creis
Joined Jan 10, '04
From Shoreline, WA
Sounds like he has the key req. for the task. best of luck if he tries it.
anyway I think that the gt and gt-4 have the same chassy just somewhat diff, (drive shaft holes and some mounts) I dont think that it would be to hard, but AWD is (in my opinion) far better and probibly much easyer to convert too.
This post has been edited by creis: Jul 3, 2005 - 9:48 AM
post Jul 3, 2005 - 11:11 AM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(drnovascotia @ Jul 3, 2005 - 12:22 AM)
Dr.
[right][snapback]307701[/snapback][/right]
Engine mounts are different but the frames are the same, the st even has places pre-marked for the gt mount. I would bet that the GT has the same thing for the ST mount. The GT-4 is not the same as the st, or gt. It is a beefier frame.
post Jul 3, 2005 - 12:56 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
I hate these posts
post Jul 4, 2005 - 12:49 PM
darksecret
Joined Mar 9, '05
From Charlotte
The only reason it would be beefier is seam welding, which from what I can tell is actually done on the GT, I don't know about the ST.
Lo-Fi Version Time is now: November 24th, 2024 - 5:39 PM
