> Fog light recommendation for GT4, Picture added of what I bought
post Jul 1, 2005 - 5:11 PM
jgreening
Joined Jan 17, '04
From Illinois
As some of you know, I am upgrading to the GT4 front facia because of my crash. I have purchased most of the required parts, some of which will be delivered Sunday.
I did not purchase the GT4 fogs because the price is rediculous. I wanted to know if anyone has recommendations on some really nice 4" round fog lights. I want clear.
This post has been edited by jgreening: Aug 4, 2005 - 12:17 AM
Replies (1 - 19)
post Jul 2, 2005 - 2:02 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I think John had some APC 4" fogs, I'm not sure if they were clear.. but I would ask him. Hope that helps a little!
**** Photobucket
post Jul 2, 2005 - 9:09 AM
jgreening
Joined Jan 17, '04
From Illinois
who is John?
post Jul 2, 2005 - 10:13 AM
i have cheap 4in ones i bought at the local car parts store. just look around and u can find some just like that but clear.
if you end up going for the oem ones, youll have a hard time fitting your fmic.
post Jul 2, 2005 - 3:03 PM
95CelicaST
Joined Feb 5, '05
John = Mynzeyes
**** Photobucket
post Jul 2, 2005 - 9:21 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
Ditto, I have cheap advance ones ... mine are tinted blue, but thats fine..
post Jul 3, 2005 - 2:23 AM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Unfortunately, a stray stone has shattered one of the OE lenses on my front lights. Tried Toyota for a replacement but decided againts getting a mortgage bo buy one.
Just been to the local autofactors and came away with a pair of these...
100mm diameter as per OE ones. Not sure hwo they'll fit, but can't see that being too difficult. NZ$159 for the pair is a shed load cheaper than Mr T.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Jul 3, 2005 - 1:42 PM
95CelicaST
Joined Feb 5, '05
how much are the GT-4 fogs from Toyota?
**** Photobucket
post Jul 3, 2005 - 1:59 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
arm and leg.
Team 6gc 2005
post Jul 3, 2005 - 6:18 PM
GT4WRC
Joined Mar 17, '05
QUOTE(Drocay @ Jul 3, 2005 - 1:59 PM)
arm and leg.
[right][snapback]307967[/snapback][/right]
+ a kidney too
GT-Four spec list
post Jul 5, 2005 - 4:19 AM
Einhander
Joined Oct 23, '03
From ky
i got mine at walmart, 5 inch universal fog's 7.99 each. Black housing and fit the area well enough to almost look completely stock.
This post has been edited by Einhander: Jul 5, 2005 - 4:19 AM
post Jul 28, 2005 - 5:18 PM
jgreening
Joined Jan 17, '04
From Illinois
Well, after a lot of researching and looking, I have some things to report including what I bought.
The correct size of the round GT4 fogs is 100mm diameter which is about 3 15/16" across. This is not a common size although it is used in the Toyota Matrix and Pontiac Vibe. The problem is that the OEM versions of those lights are almost as expensive as the GT4.
The options at Walmart, Autozone, and other auto parts stores I went to were very bad. The lights either looked really, really cheap, were blue or yellow tinted, were not the correct size, had very funky halo lights, or had deep or thick rims around the outside. None of those options were acceptable. I certainly did not want to buy something that wasn't going to look like it fit in the stock fog recepticals.
Bosch makes a set called the compact 100 but I couldn't find it anywhere in the United States. I also could not locate a picture of it so I cannot comment on the looks. Very good reviews, however.
PIAA makes some very nice 100mm fogs that would fit. The model of the kit is 510 and they run about $200 for a kit with two bulbs and harnesses and covers. Quite frankly, that was more than I wanted to spend. Also, the inside of the glass is tinted a yellow (which helps in the fog) but I really wanted a clear lens and a clear bulb.
Hella does not make any 100mm aftermarket fog lights. They do, however, distribute some 100mm fog lights for another company that were standard issue on the upper end models of the Mercury Topaz and Ford Tempo from 1992 and 1993. These units are plastic (less need to worry about glass breaking / cracking) and look very decent. They are OEM quality which generally means better than autozone cheapies but not as good as PIAA or Hella. The bulbs are standard size and clear. Overall, a nice looking option if you want something that looks decent but are not ultra concerned about fog light performance. That was where I am.
I just picked up a set for $40 bucks shipped from the junk yard. I will post up pics when I get them installed in a couple weeks.
post Jul 28, 2005 - 8:29 PM
FORGMANN
Joined Dec 11, '04
From USA
hey,
i got my oem st205 fogs from EBAY UK for 100 shipped for pair with brackets
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
post Jul 28, 2005 - 9:19 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(FORGMANN @ Jul 28, 2005 - 8:29 PM)
hey,
[right][snapback]317888[/snapback][/right]
Good find Forgmann!
post Jul 29, 2005 - 1:33 AM
what car did u get the new fogs from ?
This post has been edited by lagos: Jul 29, 2005 - 1:34 AM
post Jul 29, 2005 - 8:19 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(lagos @ Jul 29, 2005 - 1:33 AM)
[right][snapback]318016[/snapback][/right]
92 Ford Tempo
post Aug 4, 2005 - 12:19 AM
jgreening
Joined Jan 17, '04
From Illinois
My junk yard fog lights came in the mail today. Here is a picture of the 92 Ford Tempo fog in the GT4 bezel. It fits good and I like the looks. I think its a good substitute for $40.
This post has been edited by jgreening: Aug 4, 2005 - 12:22 AM
post Aug 4, 2005 - 6:25 AM
looks good jay...once you get them mounted up, im sure theyll look great! smile.gif
post Aug 24, 2005 - 7:40 AM
joncooper
Joined Aug 24, '05
From Somerset, United Kingdom
I have fitted clear fog lights to my uk model ST205. These were 'angel eye' fogs too, and i have wired the halo upto the side light. The kit comes with a wiring harness so that you can have buttons in your car, however i chose to wire 'em in direct to the normal circuits so they come on with the relevant Toyota switches.
Halfords in the UK sell them for £ 79.99, however I purchased them from a local dealer for £ 55.00
If anyone is interested, I'll take a photo (night time looks best!), as well as a day shot and post them to my website for you all to see.
They outperform the standard st205 fogs, and look a whole lot sexier too, as well as being 'E' approved.
Let me know if there's interest.
I understand that I am in the UK, and lots of you are in the USA, so if you would like to group together and buy a few sets, then I could get them shipped over for you (you just pay me whatever I can buy them for plus cost of shipping - and I'm sure I could get a group buy discount!).
These are made by Ring (a company based in Leeds in the UK). They have a website www.ring.ltd.uk , but they dont have pictures on there. I guess you could email them and ask for a distributor in the USA!
Below is a link to the halfords website, where you get an idea of the boxed product. They even have a nifty little 'push this button' on the box, where the angel eyes light up so you can see their effect on the shelf!
http://www.halfords.com/opd_product_detail...4&type=0&cat=13
All I had to do to get mine fitted inside the black plastic GT4 fog lamp holder was to cut the backs off the holders as the new fogs are deeper, and wire them accordingly (very easy).
Again, let me know if you want pics of my fogs on the car, and I can take pics of them off the car (so you can see what I had to cut etc). Nice simple job though.
Good luck,
Jon Cooper :-)
QUOTE(jgreening @ Jul 1, 2005 - 11:11 PM)
[right][snapback]307404[/snapback][/right]
post Aug 24, 2005 - 10:42 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(joncooper @ Aug 24, 2005 - 7:40 AM)
Good luck,
Jon Cooper :-)
[right][snapback]327563[/snapback][/right]
Good info. I notice that the webpage says they are driving lamps and not fog lamps. Do they have fogs available? Using driving lamps in a foggy situation is not ideal.
Lo-Fi Version Time is now: January 10th, 2026 - 3:43 PM
