![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
I've been busy lately but this is what I'm going to give to the person that does the machine work.
Measurements in white are what I got from the 5S flexplate. Measurements in red are what the flexplate needs to be in order to bolt up to the 3SGTE. I started to put the measurements in from what I assumed to be a 5S flywhwheel but that made things really messy looking. I'll make a seperate drawing for that. ![]() -------------------- ![]() Project ST204.5 99.88946% complete... |
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
very good progress so far man! im interested in how this turns out. your going to get vids of it running right?
![]() -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Absolutely.
![]() Enthusiast ![]() ![]() ![]() Joined Aug 25, '06 From HAMILTON NJ Currently Offline Reputation: 1 (100%) ![]() |
so questions if im using the 5sfe tranny for the 3sgte swap i use th 3sgte flyweel and plates and 5sfe disc correct?
Yeah, you'll need the 3S flywheel and pressure plate and either a 5S disk or a custom 3S disk with splines to match the S54 transmission.
I forgot to upload the 5SFE Flywheel measurements but here they are now. If someone can measure theirs to compare that'd be great. ![]() This post has been edited by WannabeGT4: Oct 19, 2006 - 7:21 AM -------------------- ![]() Project ST204.5 99.88946% complete... |
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(celicast3sgte @ Jul 29, 2005 - 4:29 PM) [snapback]318241[/snapback] im embarrased to read this topic........ Couldn't have said it better myself, that's why i'm a ghost on this forum anymore -------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Enthusiast ![]() ![]() ![]() Joined Sep 28, '07 From Toronto, ON Currently Offline Reputation: 5 (100%) ![]() |
okay quick question, because i've been considering doing the st205 motor swap..and i've been acknowledged that in order to use the 5s tranny with the 3s motor, you need the 3s pressure plate and flywheel....well i've got an aftermarket clutch kit (disc, pressure plate), do i still have to switch to the 3s pressure plate?
just realized that the last post was a freakin year ago--oh jeebus. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:28 AM |
