> 7afte electronics, what do I need?!?
post Jul 2, 2005 - 8:51 PM
SnowMan
Joined Mar 28, '05
From New Jersey
Alright everyone, what electronics are necessary to have with a turbocharged 7afe. If you all can let me know what I need that'd be awesome. Thanks
post Jul 2, 2005 - 10:08 PM
nik
Joined Sep 30, '02
QUOTE(SnowMan @ Jul 2, 2005 - 6:51 PM)
[right][snapback]307716[/snapback][/right]
for a basic 6-7 psi none a simple fmu will control your fuel
This post has been edited by nik: Jul 2, 2005 - 10:09 PM
post Jul 2, 2005 - 11:14 PM
SnowMan
Joined Mar 28, '05
From New Jersey
which would be better, a 12:1 or 10:1. Also, what about the SAFCII, would that be needed and what exactly does it do?? Thanks again
post Jul 2, 2005 - 11:19 PM
s-afc is like a FMU pretty much controls fuel and air....
i'd suggest s-afc2
post Jul 2, 2005 - 11:41 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE(playr158 @ Jul 3, 2005 - 4:19 AM)
i'd suggest s-afc2
[right][snapback]307766[/snapback][/right]
Better yet, get a Greddy eManage and have control over timing too! smile.gif
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 3, 2005 - 4:59 PM
nik
Joined Sep 30, '02
QUOTE(Dr_Tweak @ Jul 2, 2005 - 9:41 PM)
i'd suggest s-afc2
[right][snapback]307771[/snapback][/right]
thats what i did but you can get by on just a 12:1 fmu
post Jul 3, 2005 - 6:22 PM
SnowMan
Joined Mar 28, '05
From New Jersey
Thanks for the replies!! I just read up on a 12:1 fmu, and it says "This FMU allows the car to run normally on a small injector," does that mean I wouldn't need to change the injectors, or should they still be upgraded(and if so, what cc)?
post Jul 5, 2005 - 1:21 PM
nik
Joined Sep 30, '02
QUOTE(SnowMan @ Jul 3, 2005 - 4:22 PM)
[right][snapback]308051[/snapback][/right]
you can run your stock to about 7 psi
post Jul 5, 2005 - 3:08 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I tried a 12:1 FMU with the stock injectors and I don't know if my EGT gauge was/is bad, but it would keep climbing past 1200 so I never went WOT for more than 3 seconds. Can somebody confirm this for the future 7A-FTErs?
post Jul 5, 2005 - 4:04 PM
nik
Joined Sep 30, '02
QUOTE(OOBE @ Jul 5, 2005 - 1:08 PM)
[right][snapback]308682[/snapback][/right]
mine was fine at WOT at 1150 to 1200 on my egt gauge on just the fmu didnt change much after the emanage but i did turn the boost up wink.gif
post Jul 5, 2005 - 10:03 PM
FallenHero
Joined Dec 26, '02
From Alabama
Um, I am going to hijack your thread. If you put 7afe and small port 4ag injectors side by side, they are almost identical. If you put the little plastic seal from the 7a injectors on the 4ag small port injectors, they bolt right onto the 7afe intake manifold.
Since the 4ag's are 256 or something cc injectors compared to the 70something cc 7a injectors, wouldn't they be great for a turbo set up?
post Jul 6, 2005 - 12:53 AM
post Jul 6, 2005 - 2:22 PM
FallenHero
Joined Dec 26, '02
From Alabama
post Jul 6, 2005 - 2:24 PM
red tops are wat CC?
post Jul 6, 2005 - 3:33 PM
nik
Joined Sep 30, '02
QUOTE(FallenHero @ Jul 6, 2005 - 12:22 PM)
[right][snapback]309185[/snapback][/right]
those would work good for 10-15 psi range on a fmu (8:1 or 10:1) but i would get some sort of a fuel controller because you'll be on the rich side
440cc are over kill on a 7afte boosting only 7-10 psi under 200 whp
post Jul 6, 2005 - 6:40 PM
FallenHero
Joined Dec 26, '02
From Alabama
I hear things about low ohm and high ohm 4ag injectors... anybody know if the 4ag small port injectors are capable of being run by a 7afe ECU?
post Jul 6, 2005 - 7:16 PM
you need HIGH impedance injectors
post Jul 6, 2005 - 10:21 PM
FallenHero
Joined Dec 26, '02
From Alabama
post Jul 7, 2005 - 1:23 PM
nik
Joined Sep 30, '02
here http://www.grabercars.com/InjectorSizing.html
these are all HIGH imped happy player do a search
these should work finding them is another thing
Nippon Denso 213 beige 13.8 20.9 42.6 290 Toyota 4AGE
Nippon Denso 250 green 13.8 24.5 50.0 290 Toyota 4AGE
Nippon Denso 250 violet 13.8 24.5 50.0 290 Toyota 4AGE
same engine family and head these might work all so
Nippon Denso 155 violet 13.8 15.2 31.0 290 Toyota 4AFE
Nippon Denso 176 light green 13.8 17.3 35.2 290 Toyota 4AFE
Nippon Denso 176 grey 13.8 17.3 35.2 290 Toyota 4AFE
This post has been edited by nik: Jul 7, 2005 - 1:26 PM
post Jul 7, 2005 - 1:43 PM
FallenHero
Joined Dec 26, '02
From Alabama
I have a set of these for my future engine...
the 4agze injectors would be good for most any 7afe build. The ones I have will only support 200hp supposedly.
This post has been edited by FallenHero: Jul 7, 2005 - 1:43 PM
Lo-Fi Version Time is now: April 23rd, 2025 - 6:09 AM
