> brakes pushing back?, bumpy
post Jul 3, 2005 - 4:52 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
when i brake on my car the brake pedel pushes back on me in bumps. its like its bumping my foot. its like push, no push, push no push. i checked the disks and pads and they are flat without any bumps or scratches. is it my brake cylinder that isnt applying full pressure, just once every other second? my brake fuid is filled up and doesnt look dirty. i just do not have even braking. could my disks be warped a little from snow?
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Jul 3, 2005 - 5:44 PM
blu94gt
Joined Mar 23, '05
From Kansas City
well the brakes will do that when ABS is kicking in, but unless you're mashing on the brakes or in a skid ABS shouldn't be doing anything. Otherwise I don't know.
If the rotors were warped you would probably feel the car/steering wheel shake when you brake
1999 Celica GT
post Jul 3, 2005 - 8:41 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
It could be a warped rotor, bad pads, air in the line, or even struts.. it depends on the condition it does it in. Also how hot they are and how hard your running them.
post Jul 3, 2005 - 8:45 PM
macavely
Joined Nov 4, '02
sounds like your activating abs .. now her is the important quesiton do your car stop normal? does it take extra time for it to stop ?
post Jul 3, 2005 - 11:22 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
macavely Posted Today, 01:45 AM
extra time to stop. my other celica can stop on a dime but this one needs more braking distance. im not stomping on the brakes either. pads are fine and disks look good. abs light isnt on. this happens when im just driving around the block for 10 minutes.
This post has been edited by ArizonaRed: Jul 3, 2005 - 11:23 PM
-97 Celica ST
(GOT LIFT?)
post Jul 4, 2005 - 1:29 AM
gas65
Joined Nov 6, '03
From Campbellsville, Ky.
Try bleeding your breaks.
post Jul 4, 2005 - 1:48 AM
QUOTE(gas65 @ Jul 4, 2005 - 1:29 AM)
[right][snapback]308181[/snapback][/right]
I agree, possibly air in the lines ?
post Jul 4, 2005 - 2:00 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
QUOTE(Batman722 @ Jul 4, 2005 - 6:48 AM)
[right][snapback]308185[/snapback][/right]
how does that happen?
to bleed brakes do i just unhook the line right where it goes to the caliper? any special tools?
-97 Celica ST
(GOT LIFT?)
post Jul 4, 2005 - 3:44 AM
gas65
Joined Nov 6, '03
QUOTE(ArizonaRed @ Jul 4, 2005 - 2:00 AM)
[right][snapback]308191[/snapback][/right]
No, don't open that line!
You will probably have to jack up each wheel and remove them one at a time for the directions below. And make sure you put a jack stand somewhere to hold the car securely for each wheel before you stick yourself under the car.
Yes, jacking up each wheel, putting a jackstand underneath it, bleeding the line, removing the jackstand, and than lowering the car one wheel at a time will take some time, but it is much safer than trying to crawl under the car with a jack holding it up. You can raise as many wheels at a time if you want, as long as you have enough jackstands. I have 4 jackstands so I raise my whole car and remove all the wheels at once when I do mine. Just be safe.
Directions:
Do not use an open end wrench on the bleed valve, use a boxed end
Jack up the whole car or however many wheels you have stands for. Remove the wheel(s). Open up your brake fluid resevoir. Than starting with the wheel located furthest from your master cylinder, you have somebody pump the brake pedal and hold it down and you open the bleed valve, keep it open until the pedal hits the floor and than close it back while they still have the pedal to the floor. Do this several times until all the air comes out, you should see a steady stream of fluid, not a sporadic flow when the air is all out. Make sure they never lift their foot from the pedal while you have the bleed valve open. When you have a steady stream, close the valve securly but don't try to overtighten the valve, they do strip and break under stress. Now go to the 3rd furthest wheel from the master cylinder and repeat the process, than the 2nd furthest, and than the last wheel(which should be the closest to the master cylinder).
Your brake pedal should now be alot firmer higher up from the floor, in other words, if your pedal did'nt start grabbing until it was halfway down to the floor, it should now start grabbing alot sooner as you push the pedal. That is if you did it right.
WARNING: If you have never bled brakes on any car, I would ask somebody local to show you how to do it, maybe a parent(that has done it) or a mechanic. A mechanic may charge you a little, but these are the brakes that stop your car and the little price is worth more than doing it wrong yourself and having a wreck later.
And you might want to put a hose on the bleed valve before you open it and drain the fluid into an oil pan, but I never do. I usually just keep plenty of rags and towels around and try to catch as much fluid in the pan without a hose, than clean up the driveway with the rags and towels. Hell, whats another spot in the driveway. biggrin.gif
This post has been edited by gas65: Jul 4, 2005 - 3:49 AM
post Jul 4, 2005 - 10:16 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
thanx a bunch
-97 Celica ST
(GOT LIFT?)
post Jul 11, 2005 - 8:43 AM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
arizonared: when u brake, even softly, is it the car's brake pedal pumps? hm.. if so i guess i got the same problem
also, is it normal for brake lines to get air in it every once in a while? i just wanna know if it's normal this will happen once in a while
06 Civic EX
My For Sale Thread
Lo-Fi Version Time is now: November 23rd, 2024 - 11:28 AM
