Enthusiast ![]() ![]() ![]() Joined Sep 18, '02 From Northern, Virginia Currently Offline Reputation: 0 (0%) ![]() |
i had somewhat similiar problem, you have to make sure that your fit and tightened the springs in their housings correctly, also lowering your celica makes the rear sway bars deform and clank up on the underside of the body. Youll have to bend these or get new sway bars.
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
And I don't think it's your steering components that are creaking when you turn. I think it's your front springs moving around a little bit, because mine do it too.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
Is that true about the sway bars? Ive never heard anyone say anything about that before.......that would suck to have to buy all new ones, or to bend them out of shape. Would a car with like a 1.5"-1.7" drop have that issue, or not?? -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Enthusiast ![]() Joined Mar 24, '03 From virginia Currently Offline Reputation: 0 (0%) ![]() |
Yeah, never heard that about the sways, I've got the 1" drop, now I'm paranoid, Guess I'll have to save for new sways. Anyway, I did notice a strange noise after about a month on my new springs(Eibach pro-kit) and slight rubbing sound in the rear pass. fender. only at higher speeds though, around 65mph, when changing lanes? Anyone?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
this does not sound good. People with springs need to be talking.
ummm yea
i have the trd springs and new sways but b4 i got them they worked just fine i would double check to make sure that the springs are installed correctly |
havent had any problems w/ my swaybars yet.... ive had the eibach sportlines (1.5") in for like 4 months....
well i know the sound when you turn is the the springs not being in correctly, I had a problem with clanking when i went over bumps, I thought the underside was rubbing agaisnt the sway bars, shrugs, it couldve been the springs in improperly, because i dont really have the problem anymore.
Enthusiast ![]() ![]() ![]() Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) ![]() |
you won't have any swaybar problems unless you have coilovers. all the springs drop 1.5" or less. jason, i bet the install is messed up somehow. a mechanic telling you that "the springs need to wear in" is BS. if that's what he said, he's probably just trying to cover up a shoddy install job. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Enthusiast ![]() ![]() Joined Jan 16, '03 From Wichita KS Currently Offline Reputation: 0 (0%) ![]() |
my 1.5 in drop makes a slight noise in the rear but not in the front and it dosn't seem to afect the steering in any way. I agree the springs probably didn't sit in the houseing right
okay, I just checked out the celica.net 6th gen room on this problem. Yes I was not crazy, The sound that you hear clanking could be your sway bars rubbing agaisnt your car. you can check this out by boucing the suspected front or rear of your car to see if you get clanking sounds.
![]() Enthusiast ![]() ![]() Joined Oct 30, '02 From Nebraska Currently Offline Reputation: 0 (0%) ![]() |
well if you dont like your CF hood, i might be intrested in buyin it from you
![]() -------------------- 94 celica GT
90 Civic Si |
Enthusiast ![]() ![]() Joined Dec 6, '02 Currently Offline Reputation: 0 (0%) ![]() |
go here and see my reply...sounds like same problem...
http://www.6gc.net/forums/index.php?act=ST&f=5&t=2953 |
Lo-Fi Version | Time is now: February 22nd, 2025 - 4:44 PM |
