Subwoofer ain't workin'..., OMGWTFPWNED |
Jul 9, 2005 - 11:28 AM |
Enthusiast Joined Oct 16, '02 From Hohenwald, Tennessee Currently Offline Reputation: 1 (100%) |
Well one day my system just stopped working altogether. First thing I suspected was RCA wires/jacks. I bought new wires and tested them. Nothing. So I tested it with a different CD player. Nothing. I've taken the sub out of the box and inspected it, and it has no signs of being blown. It's a 800W max. sub bridged to a 2-channel 400W amp. I checked all connections between the amp and the sub, along with all the fuses, and everything looks fine. I also checked to see if the amp is getting power, and it is. I'm just not getting any boom boom!
Anyone have any other suggestions? Note that the amp isn't generating any heat whatsoever, but I wouldn't think that it would in the first place if it's not having to use any power other than being turned on. |
Jul 9, 2005 - 12:16 PM |
Enthusiast Joined Nov 20, '04 From Carlisle, PA Currently Offline Reputation: 27 (100%) |
Maybe take the subs and amp to an audio shop, most will be able to test them for you. It would probably be cheaper and less time consuming doing trial and error with different parts, etc.
Jul 9, 2005 - 12:32 PM |
Enthusiast Joined Feb 9, '03 From Sioux falls, South Dakota Currently Offline Reputation: 1 (100%) |
coils dont have to be locked for the sub to be blown they can move freely and act as if they were in fine condtion but in fact be blown. test the ohm load at the back of the sub if it reads zero or some crazy nuber then its blown. thats my suggestion.
-Aaron- -------------------- |
Jul 9, 2005 - 9:04 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
Make sure your remote-on lead from the head unit is connected in dash and to sub, assuming you use it
-------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Jul 9, 2005 - 11:48 PM |
Enthusiast Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
QUOTE(afroman @ Jul 9, 2005 - 1:32 PM) coils dont have to be locked for the sub to be blown they can move freely and act as if they were in fine condtion but in fact be blown. test the ohm load at the back of the sub if it reads zero or some crazy nuber then its blown. thats my suggestion. -Aaron- [right][snapback]310420[/snapback][/right] assuming everything else works, ^^^ that could be the case, if you don't have a mulimeter, play a tune and try pushing the sub down gently (at low volume) just to see if it will come on. -------------------- ----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Jul 10, 2005 - 12:00 AM |
QUOTE(afroman @ Jul 9, 2005 - 12:32 PM) coils dont have to be locked for the sub to be blown they can move freely and act as if they were in fine condtion but in fact be blown. test the ohm load at the back of the sub if it reads zero or some crazy nuber then its blown. thats my suggestion. -Aaron- [right][snapback]310420[/snapback][/right] I'm not a genious with the way speakers work or anything, but it seems odd that an 800W sub could be blown by a 400W amp. Also, this didn't happen while I was in the car. I got off work one night and came home with it working fine. When I got in the car the next day to go to work, it wasn't working. |
Jul 10, 2005 - 9:16 AM |
it doesn't have to be "blown". The coil can break anytime from all that moving up and down, altho it doesn't happen very often. troubleshoot, try any speaker see if that one works. Ur problem is a simple one to find.
also, a 400w "max" amp can blow a 800w max sub when driven into clipping. (when it distorts like a mofo) -------------------- ----------------------6GC's FIRST V6----------------------
Lo-Fi Version | Time is now: December 4th, 2024 - 4:06 PM |
