> GZE it is..., #2, I think?
post Jul 9, 2005 - 3:34 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
After lots of thinking and a couple of minutes on club4ag.com and reading through the forums, I made my decision. I'm getting the gze. One of the main reasons is because of the numbers on the spec sheet. also, i didnt like the fact that theres so much debate about the actual hp ratings on the silver and blacktop 20v motors. sounds kinda shady, but w.e. i wish i could have the 3s but putting that in will be more expensive because i have an ST. so im trying to find out as much about this little engine as i can. now club4ag says the gze needs 100 octane gas. i kno they sell this in japan. the highest ive seen here at the pumps are 93. i ALWAYS use 93. now would 93 be fine for the gz? will this be bad for the engine or what? ive seen those octane boosters that raise the octane like 7 units. so that would be 100, but i dont wanna have to buy this stuff all the time. so what will be the difference from using 93 and 100 since 100 is recommended or w.e. o yea, im getting the ae101. yea FAQ, watch out! lol. thanks.
This post has been edited by JoKeRkId613: Jul 9, 2005 - 3:35 PM
post Jul 9, 2005 - 8:57 PM
azian_advanced
Joined Apr 18, '05
From Calgary
there's a guy who owns a 90 JDM MR2 Turbo locally and because those ECUs are programmed to only function properly and more efficiently with 100 octane gas, that i think it IS important that you buy and add the octane boosters everytime you fill your tank. it's exactly what he does. it's just the price you have to pay for having that sort of engine. but i'm not sure what'll happen if you don't in the long run but maybe somebody here can answer to that???
post Jul 9, 2005 - 9:58 PM
Sev408
Joined Dec 4, '03
100 octane i have never read about for the gze. the car manufactures are going to make a car that has to have 100 octane when 93 is normally the highest you can have.
user posted image hows it taste motha f*cka
post Jul 9, 2005 - 10:20 PM
its 100 ron or whatever they call their gas in japan. its not the same as our octain ratin . if you use 93 now, youll be fine using that with your new motor.
post Jul 10, 2005 - 1:39 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
also, can't you just retard the timing and run 87 if you really want to?
kind of kills the performance aspect, but saves gas $(iff 100octane is in US measure)
post Jul 10, 2005 - 11:40 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
the way that the octane level is measured is different in japan then it is in the US, 100 octane jap gas is only a bit higher than our 93, use of octane booster should be more than enough I'd think.
-FAQ
AIM : FAQdaWorld
post Jul 11, 2005 - 1:18 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
faq, do you use 93 on the gze?
post Jul 11, 2005 - 5:48 PM
FAQdaWorld
Joined May 24, '03
So far i have, keep in mind i havent been driving her too hard yet
I do intend to be putting some octane booster in it as well w/ every tank.
AIM : FAQdaWorld
Lo-Fi Version Time is now: February 24th, 2025 - 4:56 PM
