> what is the difference, GT and the GT-Four
post Jul 10, 2005 - 12:17 AM
trey_135
Joined Jul 10, '05
From OTtawa Kansas
ok i have just bought a 1995 celica gt and i love it it has been my dream for about 4 years and i finally have it. so i am searching for a body kit for it and it is between the VARIS body kit and C-One both not easy to come by but i need to know what is the difference between gt and gt-four is there a difference or will regular 6gc body kits work on my gt. any input would help thanx guys
post Jul 10, 2005 - 12:25 AM
GT-Four has 251hp 3sgte engine and is AWD.
Your GT is 135hp and a 5sfe with FWD.
The ST205 (GT-Four) has a different front bumper & hood so body kits will be different on the front end.
This post has been edited by Supersprynt: Jul 10, 2005 - 12:26 AM
post Jul 10, 2005 - 12:30 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
I believe most of this is covered in the home page information...
post Jul 10, 2005 - 2:03 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
i think he meant differences in the body kits
the gt4 looks alittle higher from what i can tell the cent sticks out alil more.
if you can get a hood made fora gt4 i would get the bumper made for the gt4, it looks alil better in my opinion and as long as both the hood and bumper are made for the gt4 or gt they will fit together, if you mix them up you will have a gap or they won't fit correctly
hope that helps
post Jul 10, 2005 - 5:15 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
gt and gt four have different chassies so a body kit for a gt four probably wont fit in some spots without lots of modification.
post Jul 11, 2005 - 2:04 PM
darksecret
Joined Mar 9, '05
From Charlotte
The chassis is very, very, very similar right down to the seam welds in the floor pans, I think the trunk floor is different but I haven't seen any proof if they are or aren't.
post Jul 11, 2005 - 4:30 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
They are belive me - they are.... even the front is WAY too different....
QUOTE(darksecret @ Jul 11, 2005 - 12:04 PM)
[right][snapback]311204[/snapback][/right]
<<<<<< DCw / JDMart >>>>>>>
post Jul 11, 2005 - 5:26 PM
darksecret
Joined Mar 9, '05
From Charlotte
That's the bumper, of course the body is different but if you stripped the GT down you could bolt in 99% of the GT-Four parts, maybe the rear end mount is different, same concept with the Evo and the Lancer, the only difference is the seam welds and the Evo has a slight fender flair over the Lancer. I've been telling people for a while why would Toyota spend an extra load of cash designing a different chassis for almost the exact same look, it's very common for manufacturers to use the same chassis in different vehicles, GTO=Manaro, IS300=Altezza, Celica=Curren, all 1994-2004 Mustangs use the SN-95 (ex. the Saleen SR which was a custom widebody), all F-Body Camaros and Firebirds, G35=350Z, Evo VII and VIII=Lancer, Evo V or VI (can't remember)=Colt/Mirage, 2005 Mustang=Lincoln LS, 300C=Charger, I can name a whole load more that share an almost indentical or identical chassis, what makes the Celica so different from the hundreds of other cars that share the same chassis, is it because ours says ST204/AT200 vs. ST205, Toyota is still a mass production manufacturer yeah the guts maybe different even the skin to but the original shell is the same.
post Jul 12, 2005 - 12:26 AM
doGGy
Joined Oct 28, '02
You Ever saw a GT4?
QUOTE(darksecret @ Jul 11, 2005 - 3:26 PM)
[right][snapback]311285[/snapback][/right]
post Jul 12, 2005 - 12:32 AM
QUOTE(doGGy @ Jul 11, 2005 - 10:26 PM)
You Ever saw a GT4?
[right][snapback]311424[/snapback][/right]
He obviously hasn't. He's just making assumptions that are hugely incorrect. I believe that I have pictures at home that'll prove the point, but the GT-Four is very, very different. Not even the backseat from a GT-Four will bolt into any AT200 or ST202/3/4 I don't think.
post Jul 12, 2005 - 12:44 AM
doGGy
Joined Oct 28, '02
I thought exactly like him before i saw/drove GT-four. They are different. Front / engine bay / stiffnes of the chasis (remeber it was build to be a AWD car) / even the flor of the car is different. Rear end is not like GT / ST at all, there is Fuel tank there are normaly spare wheel is on GT/ST. and so on..... But differences are Not so huge, but still changes where made to the chasis.
QUOTE(Coomer @ Jul 11, 2005 - 10:32 PM)
You Ever saw a GT4?
[right][snapback]311426[/snapback][/right]
post Jul 12, 2005 - 9:59 AM
darksecret
Joined Mar 9, '05
From Charlotte
So what is the point of putting a driveshaft tunnel in a car designed to be specifically FWD, I said other stuff can be different like body panels, the back seat, but a majority of the chassis are the exact same on the exception of maybe the rear trunk panel. As far as the trunk panel I haven't seen behind the fuel tank of the 204 chassis so I don't know if there is a mount loactaion for a rear end.
post Jul 12, 2005 - 5:36 PM
Mr_E
Joined Nov 16, '04
From UK
In answer to the original question, I suspect a ST205 bodykit will not fit on a ST202 without significant work.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
Lo-Fi Version Time is now: February 17th, 2025 - 11:17 AM
