> 7afte wont start
post Jul 13, 2005 - 12:43 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i was letting my car warm up one day a noticed that the RPMS were acting weird, i reved the engine and they went up stoped, came down went up, got stuck and fell back to 1K, then died. i relized my o2 sensor was blown and my plugs were shot, so i replaced the plugs and theirs still no spark. WTF is wrong with my car!?!?!?!!?
post Jul 13, 2005 - 12:54 PM
nik
Joined Sep 30, '02
QUOTE(StreetRacing10PSI @ Jul 13, 2005 - 10:43 AM)
[right][snapback]311979[/snapback][/right]
so did you pull one of the plugs and cranked the motor and didnt see any spark
check them all then the distributor like the cap and rotor
post Jul 13, 2005 - 1:50 PM
do you have the right heat range plugs as well?
but yea check wires cap and rotor and double check your connections
post Jul 13, 2005 - 4:32 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i pulled the plug and their was no spark, and i took apart the distributor cap and their were all these lil metal shavings in their.
post Jul 13, 2005 - 11:58 PM
time for a new cap/rotor/button set!
post Jul 14, 2005 - 10:02 AM
nik
Joined Sep 30, '02
QUOTE(StreetRacing10PSI @ Jul 13, 2005 - 2:32 PM)
[right][snapback]312056[/snapback][/right]
metal shavings can you see where they came from? you might need a hole new distributor start with replacing the cap and rotor and go from there
post Jul 14, 2005 - 8:40 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
ends up that when i replaced my coil pack a wire was in the way of the distributor which caused it to snap. its up and running now tho smile.gif
Lo-Fi Version Time is now: November 30th, 2024 - 10:01 AM
