ST HEADERS |
ST HEADERS |
Apr 24, 2003 - 10:38 AM |
Enthusiast Joined Apr 22, '03 From W. Chester - Ohio Currently Offline Reputation: 0 (0%) |
DOES ANYBODY KNOW WHERE CAN I GET HEADERS? EXCEPT AROSPEED THEY DONT MAKE THEM ANYMORE I CALLED THIS MORNING OR IF THE COROLLA ONE WILL FIT AND WHAT MODIFICATIONS HAVE TO BE MADE TO IT
IN ORDER TO FIT THANK'S YA'LL |
Apr 24, 2003 - 12:30 PM |
Enthusiast Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) |
Someone did a how-to a while back about this install. Here's a link to it
http://www.6gc.net/index.php/action/how-to..._article/itu/43 Maybe this will help you out. |
Apr 24, 2003 - 4:41 PM |
THANKS BRO!! YOU DA' MAN
Apr 24, 2003 - 7:52 PM |
Hey don't thank me, thank the guy that wrote it, Ijust found it. Good luck with the project.
Apr 24, 2003 - 9:16 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
yes. thank ME!
hehe, jk, i'm glad i can help you guys out. -John- -------------------- |
Apr 24, 2003 - 9:51 PM |
Was there any sort of noticable difference after you installed the headers? Also, how much did the set run you?
Apr 24, 2003 - 10:22 PM |
there was a little bit of a mid-range power change, and A LOT more flow, so plan on havin the exhaust a little louder, and the set was about 180 bucks. took a little while to install. if you have your mind set to it tho, it'll be aight. .
Apr 25, 2003 - 10:54 AM |
Alright, thanks for that info. I might look into doing that depending on how long it will be before I can do any sort of major changes (turbo and all that good stuff)
May 5, 2003 - 1:21 PM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
At Streetstyler thay have the last header for the Corolla ARO 800960 which will fit 7AFE engine but will need a little modification to bolt on the exhaust pipe
May 22, 2003 - 11:06 PM |
Enthusiast Joined May 19, '03 From sf, ca Currently Offline Reputation: 0 (0%) |
Hmm, I just bought a 97 st and I am thinking about putting a new header on it. Anyone know which type would require the least amount of modification to install?
May 22, 2003 - 11:25 PM |
any faire muffler shop can add a pipe to a hpracing header
May 23, 2003 - 3:43 AM |
Enthusiast Joined Apr 15, '03 From Lonestar state Currently Offline Reputation: 0 (0%) |
I got mine at toysport. The other guy is right, installing the headers is pretty easy depending on the headers. After that you have to bring it to a muffler shop to put the extension to reach your Catpipe. MOst of them are made for Corollas not for Celicas.
May 23, 2003 - 3:48 AM |
In drag racing nothing much improved, but on the top end or 5th gear it really helps. I've raced trucks, cars that are v6/v8 some of the v6 I beat bad but v8s some of them I beat some of them I just keep up. Mine run me $220 shipped. |
Lo-Fi Version | Time is now: November 24th, 2024 - 8:46 AM |
