![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) ![]() |
Not alot of things... but alot of things...
1. Engine ( New one is going in as we speak ) 2. Wiring. ( Guy before me put in a 3sfe and cut and spliced got knows how many wires.... hot wires were cut and spliced under my steering column, every wire has been replaced. 3. Passenger axle keeps breaking for some reason no idea why, boot busted but i replaced them both a few days ago. 4. Needs brakes, i bought some new pags just havnt put them on, need rotors tho. Any reccomendations ? 5. LOUD, i want to quiet it down from road noise and exhaust. 6. Needs a new gas door hinge, mine broke ! 7. Clear coat it chipping and the 10yr old window tint is fading. 8. The scratch on the passenger side is starting to get cancer. Hopefully will be fixed soon. 9. Needs debadging !! Cant think of anything else, but im pretty sure if i thought about it for a little while longer I could come up with more things. |
Enthusiast ![]() ![]() Joined Mar 28, '10 From Columbia, South Carolina Currently Offline Reputation: 1 (100%) ![]() |
okay, since I started, there was a lot of problems, but now, not so much ^^ (255 xxx miles on the clock)
1. antenna literally just doesn't exist. There is no antenna in this car. It just disappeared. 2. If I had a vacuum/boost gauge, it wouldn't read boost, because I need a turbo oh so badly. 3. transmission leaks at the axle, I've replaced the seal, but I think it's where the seal holder attaches to the transmission. 4. Still no boost. This post has been edited by SleekCelica: Sep 11, 2010 - 12:17 PM -------------------- ![]() 1994 Celica GT, coupe, 5 speed. Front strut brace, cherrybomb glasspack, intake. |
Mine, .....mmmh,
the driver!. Nothing wrong with it. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
'94 GT Hatchback. 156,xxx miles. Just did an oil change this morning! Can't heel-toe. Gas pedal and brake are different heights. Leaking Oil. Need to replace valve cover gasket ya about that heel-toe situation. Im having the same problem. Like you said, different levels, and kinda no room i think. how is that fixable. Valve cover gasket is easy to fix if you have tools shouldn't take you more than 15 min. i use the side of my foot on the brake and rolll to the side and hit the gas w/ the other side of my foot Defiantely took me a while to get down but I got it good now. My buddy wa in my car the other day and asked why my car was revving so weird(he drives standard too) And I told Him I was jsut rev matching when I down shift. He couldn't even tell i was downshifing that's how smooth it was. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Enthusiast Joined Aug 7, '09 From Denville, NJ Currently Offline Reputation: 0 (0%) ![]() |
It's 3 different colors.
The steering wheel is bent just enough from the airbag going off that the new airbag can only bolt in on one side, so whenever I make a turn it slaps against the steering wheel. Semi-large dent on the back quarter panel. Radio antenna is broke, so I only get one station in my area and its only in certain spots. CD player doesn't work. It hasn't been driven since march, but that will change next week. Hasn't had an oil change since sometime last year. If I push the cigarette lighter too hard, it pops out the other side. But despite all this, for being 16 years old with 196k miles, it runs and drives excellent. |
![]() Enthusiast ![]() ![]() ![]() Joined Jun 2, '10 From Davenport, Florida Currently Offline Reputation: 0 (0%) ![]() |
2. Drivers side motor for vert spins but not pulling top 3. rear speakers blown 5. aftermarket stereo thats installed is terible 6. dent from aaa towtruck still not fixed (they basicaly told me to piss off) 9. ripped drivers seat and bent driver seat lower framing 8. door panels and rear interior panels marred up from previous owners dog **** edit ***** all mods are on hold till i have this list under control but it seems every time i cross something off something new gets added to the list This post has been edited by b22ri22an: Sep 16, 2010 - 1:54 PM -------------------- ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
the only problem i have is i keep throwing a CEL for EGR over and under flow.
I can't shift gears myself. This might be rectified soon enough.
And sadly, I haven't seen her since the first of July. That will be rectified tomorrow though. This post has been edited by SwissFerdi: Aug 18, 2010 - 1:16 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Enthusiast ![]() Joined Nov 27, '09 From New Zealand Currently Offline Reputation: 1 (100%) ![]() |
1) Annoying high pitched squeak coming from somwhere at the rear of my car. Comes and goes, no freaking idea what it is. 2) Power Aerial doesn't work (don't really care enough to fix it, prefer to have it permanently down) 3) Couple of very minor dents in bonnet where it looks like someone has pushed too hard when shutting it. Subtle, but I find it irritating 4) Couple of symmetrical dents at bottom of drivers door. Quite strange, and can't really figure out how it might have happened 5) Eats gas, but that's what you get for owning a turbo and living in a valley with only one way in and out: Steep Windy Hill, with 80km hour speed limit that no one pays attention to 6) Very minor curbing on one of my beautiful Konig 18inch mags, wanted to slap myself in the face when I did it It's trivial stuff really. The car puts a big freaking smile on my face everytime I take it out, and I've only ever seen two other GT-4's on the road since I've owned it. Make you feel kind of special lol |
![]() Enthusiast ![]() ![]() Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) ![]() |
Hasn't had an oil change since sometime last year. For the love of God change your oil -------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
Well, there finally is something wrong with it. I've broken the small clip that keeps the cupholder tray from sliding out of position.
This post has been edited by SwissFerdi: Aug 24, 2010 - 2:52 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Enthusiast ![]() Joined Aug 2, '10 From Melbourne, Australia Currently Offline Reputation: 0 (0%) ![]() |
Just picked her up tonight and after seeing other people's list of problems I don't feel quite so bad...
1. Rear tyres are almost bald - hopefully I'll manage to get some 17" rims before I replace the tyres, then I'll change all four and get the profile I want. 2. Rear left wheel bearing needs replacing - wil raid the wreckers/junkyard 3. Rear suspension is noisy - will replace bushes and all four shocks, probably go KYB 4. Antenna is broken off in the middle somewhere, doesn't go up/down - junkyard again for this 5. Passenger side mirror won't move and the surround is busted at the bottom - hopefully the wreckers has one of these 6. Interior roof lining is sagging a bit - don't know if I'll bother with this just yet 7. Nasty dent/crumple in rear driver's side quarter panel - panelbeater's job for sure 8. Bit of a scratch opposite quarter panel - might be able to get this out myself, I'll have a bash anyway (heheh) 9. Passenger side guard has a bit of a nasty dent. I'll have a go at beating this out as well but I think it's more a job for the panelbeaters 10. There's a number of dents in a few random places 11. Previous owner was an in-car smoker. I like my cars to smell good on the inside, not like a Lucky Strike powered gas-chamber That's all I've found since the inspection before making the purchase and on the 1hr drive home. 12. Not sure if its a clunk or a pop but there's definitely a noise coming from somewhere when I change gears or if I'm stationary and give it a quick squirt. Unsure if there's unburnt fuel detonating somewhere it shouldn't be or if it's an engine mount??? I'm suspecting engine mount because it's not loud and the engine seems to be running pretty well. I'll be doing a service on it soon because I don't think the timing belt has ever been changed (and it's on 204K kms) and I just want to make sure I have no nasty surprises on my next weekend drive. This post has been edited by m4dm4n: Aug 27, 2010 - 8:09 PM |
the only problem i have is i keep throwing a CEL for EGR over and under flow. this did the trick for me... i was getting under flow cel's till i replaced this http://www.partsgeek.com/catalog/1996/toyo...cuum_valve.html ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) ![]() |
It is not in my garage
![]() -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
its lacking a warm, moist... wait.... nvm
It is not in my garage ![]() Still in Parma? This post has been edited by SwissFerdi: Sep 11, 2010 - 11:19 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Enthusiast ![]() Joined Sep 12, '10 From Scottsboro, AL Currently Offline Reputation: 0 (0%) ![]() |
Hmm...
1)It's 4 different shades of silver/gray. 2)Wonderful flame/lightning bolt graphics that turned into paint scars. 3)Missing high beam lens. replacement has broken mounts... 4)Black leather seats are ripped. Bad. 5)Missing knob for driver's seat. Not sure what it does though. 6)Cigarette lighter is rusted and not connected. 7)I need brakes... 8)Needs struts and shocks. 9)Tail light is out. 10)Needs new shifting knob and boot 11)It has 3 shades of tint. 12)Missing middle hubcap of rims on 2 13)Wires run for a system. Including amp power/ground. Audio to radio. some kind of telephone cable... about 10 total. 14)Most trunk panels are falling off. 15)Front end is out of allignment. 16)Hood doesn't close straight. 17)Missing bumper reinforcement. 18)Muffler is dented 19)It has the wrong radio install kit so my fancy iPod dock radio catches the back of the console so it doesn't go all the way back into place. 20)Half of my gauges are out. 21) I'm out of time but there is more... But I love it to death =] |
Enthusiast ![]() Joined Aug 18, '10 From champlin,MN Currently Offline Reputation: 0 (0%) ![]() |
1. dented pass fender since i bought it
2. brakes shake when slowing down 3. shakes around 80 4. has an old ass deck Well its also missing a ton of mods i will be doing throughout winter ha This post has been edited by tony55343: Sep 16, 2010 - 8:06 AM |
Enthusiast Joined Sep 6, '10 From Lancaster, CA Currently Offline Reputation: 1 (100%) ![]() |
Most notably... The engine is in pieces on my friends garage floor, and some idiot did a horrendous paint job with yellow paint.
Nothing that can't be fixed. ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) ![]() |
lets see:
-paint in horrible shape -a gazillion dents -flex pipe busted -muffler hanging by 1 hanger -weatherstripping crumbling -egr cel #71 -taillights have teeny cracks -headlights are dirty on the inside -interior trunk panels are cracked/not correctly affixed/wont line up -left front brake squeals -needs f/r sway bar bushings -needs bump stops -needs strut dust boots (disintegrated) -miscellaneous untraceable rattles -passenger window is ultraaa slow. -rear window washer nozzle never works. -needs new strut tops (probably the source of untraceable rattles) -i *think* the throw out bearing is making noise forgot -both front turn signals are cracked/broken in their own way. -front bumper has more stone chips than paint -some gears grind when they feel like it ... all that i can remember so far. This post has been edited by samir0189: Sep 22, 2010 - 12:53 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Lo-Fi Version | Time is now: April 23rd, 2025 - 8:07 PM |
