8 Pages V  « < 3 4 5 6 7 > »
> What is wrong with your car?
post Sep 1, 2008 - 11:34 PM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
QUOTE (sawny @ Aug 31, 2008 - 1:54 AM) *
*Le Sigh*
(\__/)
post Sep 2, 2008 - 12:04 AM
Rusty
Joined Nov 5, '07
From New Zealand
needs new gear stick boot (getting sorted)
needs rear strut brace covers (getting sorted)
needs SS-III side skirts (getting sorted)
needs SS-III Rear Spiltters (getting sorted)
needs cold airbox
one of the wheel covers is different kindasad.gif (I dont really mined)
thanks this thread really helped me, get things inline on what I need to fix
post Sep 5, 2008 - 10:54 PM
-Samurai-
Joined Jun 2, '08
From Wisconsin
Well not too much...
1. drips a drop of oil every now and then, not enough to do anything.
2. sun damage on the drivers side door panel and arm rest
3. paint is a little faded, but still shiny :-)
4. has 156,000 miles
thats all I can think of at the moment...
1997 Toyota Celica GT Hatchback- Sold :(
2000 Toyota Celica GT- Sold :(
1997 Lexus SC400- Daily :D
post Sep 10, 2008 - 10:06 PM
mr-belowaverage
Joined Feb 4, '07
From Ontario, Canada
Not counting cosmetic? (ie: badly needs reupholstering, needs a paint job, has plenty of dings from 14 years on the road)
1. Right front wheel bearing
2. Gas tank and filler neck leaking
3. Oil leaks from valve cover, rotor, oil pan gasket and main seal (my fault after doing the clutch frown.gif )
4. Internal oil loss from sweeper rings (likely) common to the 7A and other 'yota fours.
5. Occasional coolant odour (heater core? who knows)
6. Mystery loss of power/acceleration. I'm blaming the wheel bearing now
7. Exhaust leaks from downpipe and midpipe at the muffler. Flanges are rotted. Nice SS exhaust, too.
What I just did recently:
8. Alternator replaced
9. All drive belts
10. 2 transmission fluid changes thanks to clutch install
11. Said clutch install
12. Earlier exhaust leak repaired.
13. E-brake cable seized and binding rear brakes. Replaced one cable, have the next for when it goes.
The biggest problem is that the motor won't die! 376,000kms on it now, and it purrs like a grisly old kitten. I'm not sure how much more $$ to put into the 7A and stock composition before putting on blocks and eviscerating it. I planned to do a 3MZFE swap from day 1, but I was going to use it as a daily driver until the motor went. Stupid Toyota quality!
It's getting to be make-or-break time. Hopefully you guys can talk me into a decision.
post Sep 11, 2008 - 2:05 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
1. New Passenger side Axle (the boot split open there is tons of grease the on inside or the front right rim)
2. Install Pre-Cat Oxygen Sensor (Still original denso o2 sensor with 110,000 miles on it)
3. New Battery
6. when downshifting into 2nd gear going really fast, i tend to hear a little tearing noise. (Need to fix the synchronize of the gears) HOW MUCH WHO KNOWS??
5. Sew together driver seat, starting to slowly rip apart.
6. Fix small dent on rear right side of car. nothing to noticeable but annoying to know its there (Plus i just recenlty painted my car)
7. Fix up my car asap. I need some money now!!
9. Eventually get a 3rd gen 3s-ge engine swap!!! sometime in the future like 3 years from now...
post Sep 11, 2008 - 6:56 PM
slvr_celica_GT_8...
Joined Jul 18, '06
From plymouth, MA USA
mine needs tires, e-brake cables, ac recharge and could use a full tune-up
IPB ImageIPB ImageIPB Image
post Sep 11, 2008 - 10:24 PM
ZGear
Joined Feb 16, '07
From BP, MN
post Sep 11, 2008 - 11:45 PM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
1) water pump + timing belt needs to be changed
2)paint flaking off by the left low beams and front license plate
3) slight dent in rear right quarter panel
4) few dings on the rear bumper and random ones here and there
5) trunk window's spray nozzle not spraying out windshield washer solution properly
6) need a new tire for the spare
that's bout it...
post Sep 11, 2008 - 11:53 PM
CelicaST_CALI
Joined Feb 28, '07
o jesus where to start...
my hood and trunk have horrid sun spots
the arm rest is cracking
one rim is missing a cap
the antenna is broken off
radiator is weird..
rear struts are blown
pas door has dents
fenders have dents
front tire has small hole
This post has been edited by CelicaST_CALI: Sep 11, 2008 - 11:54 PM
BANNED. for life, you moron.
post Sep 16, 2008 - 10:38 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
wow.. uhm long list here.. lol
Red Celica(keep in mind i bought this one for $700):
  1. Bumper scuffed pretty bad
  2. Chip in pass. high beam
  3. Pass. fender beat to hell by previous owner
  4. pass door has ugly burnt in tape residue
  5. pass window was broken by previous owner and cheap aftermarket window doesn't seal right
  6. GF spilled 44oz Dr Pepper on pass seat and floorboard
  7. no underplastics at all
  8. rear 1/4panel has dent from some stupid f150 hit&run
  9. over all dented and dinged from previous owner && hail storm
  10. strange cooolant leak yet to be found
  11. CEL code 71: corrected by a paperclip on the EGR temp sensor
  12. throw out bearing clicks while idling, sometime
  13. all 4 rims are a little scuffed
  14. horribly balanced tires
  15. extremely bald front tires (i love corners tongue.gif )
  16. rear suspension pretty much gone, looks 2 inches lowered
  17. creeking noise while turning steering wheel
  18. bumpier ride than normal
  19. squeeks and rattles over bupms
  20. horribly stained carpet from prev. pwner
  21. slightly weathered steering wheel
  22. front fabric seats/rear leather seats that are in bad condition
  23. drivers side hatch plastic interior piece missing
  24. rear bumper scufffed bad
  25. AC smells like... old AC sometimes
  26. previous owner left some disgusting stuff under the spare tire for quite some time, therefore rusting two timy holes through the floorplane
  27. engine sits a little los on passenger side
  28. 2nd grinds when shifting fast
  29. dome light work when it feels like it
  30. injector wires short out sometimes causeing occasional misfire
  31. Dist. gets wet easily causing misfire
  32. no antena. lol
but its still getting me wherever i need to go, and looks pretty good still
post Sep 17, 2008 - 2:55 AM
bizzerk
Joined Nov 6, '07
From seattle
my problems:
my roof paint is oxidizing(planning on repainting soon)
rear bumper was repainted poorly by previous owner(replacing and repainting soon)
repainted my side mirrors(friend did a perfect color match)
driver seat has minor wear (not ripped yet)
friend girls dono there purses are big and ends up making minor dings and scratches on side >:|
engine bay dirty =]
power antenna (glad its broken)
when i go to my friends house squirrels throw nuts at my car now there are small nut dings =[(seriously)
otherwise car itself is perfect.
This post has been edited by bizzerk: Sep 17, 2008 - 2:57 AM
post Sep 17, 2008 - 7:40 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Has two big dents in the passenger fender and two smaller ones on my side. frown.gif
It idles rough.
I also feel like I'm using more gas than I should, 25 MPG doesn't seem all that great.
post Mar 4, 2009 - 6:08 AM
whatthe
Joined Aug 13, '08
From Australia
Well whats wrong... i got my first minor gutter rash on one of my rear rims. Im so cut up about it, and not sure if i should repair it frown.gif
Also both my rear quater panels have a dent in em, and passanger side has part of the rear quater panel scrapped. Its not that noticeable but yeh. All that was done by previous owner. Dont know if id be fixing it up but yeh really cut up about my rim.....frown.gif
post Mar 4, 2009 - 7:01 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
QUOTE (whatthe @ Mar 4, 2009 - 6:08 AM) *
Shup your car is nearly perfect, should see all the dents on mine haha.
I have a rattle somewhere when reving, sounds like exhaust rattle, steering rack boot is torn, bad shocks, bumper is slightly cracked cause I hit a kangaroo, interior side bits have sun damage.
post Mar 4, 2009 - 8:51 AM
trdproven
Joined Aug 2, '05
From Guam
rust on doors
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Mar 4, 2009 - 11:44 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
3. Pass. fender beat to hell by previous owner FIXED
8. rear 1/4panel has dent from some stupid f150 hit&run FIXED
10. strange cooolant leak yet to be found FIXED
11. CEL code 71: FIXED by a paperclip on the EGR temp sensor
22. front fabric in bad condition
25. AC smells like... old AC sometimes FIXED
29. dome light work when it feels like it FIXED
30. injector wires short out sometimes causeing occasional misfire FIXED
32. no antena. lol FIXED shaved antenna y0
post Mar 4, 2009 - 1:08 PM
Rusty
Joined Nov 5, '07
From New Zealand
sweet almost done everything on my list just needs cold airbox
post Mar 4, 2009 - 4:10 PM
richee3
Joined Jun 29, '08
From Denver
Oh man, don't even get me started...
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 4, 2009 - 4:32 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
burns oil. exhaust is rusted out, green/blue front bumper on a red car.
post Mar 4, 2009 - 4:33 PM
jimmykay
Joined Jul 14, '08
From St. Louis
ok, here we go.
Exterior
  • rear bumper hit in a parking lot
  • dent in my C pillar from a limb
  • missing front toyota emblem
  • flaking paint on front lip
  • various chips in the paint
  • rust on the doors
  • rust stains on my ground effects from my rusty doors
  • a high pressure in the top of my windshield seal (found it going through the automatic car wash)
Interior
  • cracked leather on the center armrest
  • broken courtesy cover(took it out)
  • stained carpet
  • cigarette burn in the back seat (previous owner)
  • RATTLES
Mechanical
  • some sort of very slow leak coming from somewhere (none of my fluids get low)
  • some heat shield is broken loose on my exhaust and rattles
overall, nothing really bad, just a bunch of little things that drive me crazy
'99 Celica GT - Sold
'11 Mazdaspeed3
Lo-Fi Version Time is now: April 23rd, 2025 - 4:00 PM
