2 Pages V  < 1 2
> 7afe JDM vs USDM, specifications
post Oct 29, 2005 - 12:53 PM
FallenHero
Joined Dec 26, '02
From Alabama
JDM head has eight individual ports with the injector bungs cast into the head like a 4ag. The JDM head is subsiquently Much wider than the US 7a. As for the cam differences, I have them and have not measured them. They do, however, have different part numbers though.
post Oct 29, 2005 - 11:26 PM
normality78
Joined Oct 27, '05
yeah, mine has eight individual ports with the injector cast into the head
post Oct 30, 2005 - 1:11 AM
FallenHero
Joined Dec 26, '02
From Alabama
yup, that's the euro or "JDM" head. Either way it was not offered in the US. 8 ports should increase intake velocity and thus make power, but there is really no telling. I'm told the cams are what makes the power difference.
post Oct 30, 2005 - 3:05 AM
Hanyo
Joined Aug 16, '03
From Bay area
now the question is, will you still pass smog with the jdm head? hmmmm...
post Oct 30, 2005 - 10:46 PM
FallenHero
Joined Dec 26, '02
From Alabama
Yep, looks completely stock and all the EGR work can bolt right up... even if it's not functioning. wink.gif
post Oct 31, 2005 - 9:12 PM
normality78
Joined Oct 27, '05
yeah, its in total stock base. GE head is going in. now still thinking wat else to do. 1 thing i notice, max torque was at 2800rpm / 110lb ft. should i swap to GE head, would the torque band be affected which most likely do
post Nov 2, 2005 - 11:19 PM
FallenHero
Joined Dec 26, '02
From Alabama
what are you asking?
post Nov 3, 2005 - 2:19 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
I think hes asking if he swaps on the ge head will he lose torque.
post Nov 3, 2005 - 2:22 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(94ST2 @ Nov 3, 2005 - 7:19 AM)
[right][snapback]352413[/snapback][/right]
No... the torque curve will change and he might not make as much torque at 1500 rpms... but torque will most definately increase in the higher rpm range.
post Nov 3, 2005 - 10:58 PM
normality78
Joined Oct 27, '05
94ST2,
tks for the clarification.
Kwanza,
point noted.
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 22nd, 2024 - 9:17 PM
