> What gauges do I need??, For a 7afte
post Jul 14, 2005 - 10:08 PM
SnowMan
Joined Mar 28, '05
From New Jersey
Hey everyone, I just wanted to know, besides a boost gauge,
what gauges are needed or highly recommended to have with
a 7afte that won't be boosting more than 10 psi??
Thanks in advance
post Jul 14, 2005 - 10:24 PM
FallenHero
Joined Dec 26, '02
From Alabama
I'd get oil pressure and fuel pressure. You know... personally. An EGT guage would be nice also.
post Jul 14, 2005 - 11:01 PM
fuel pressure
oil pressure
oil temp
water temp
egt
wideband o2
post Jul 15, 2005 - 12:13 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
if # is no limit, wideband, boost, and oil pressure???
i know the egt can be used to tell if running too rich/lean by the temp change, but not sure what else it can do...if not oil pressure, then EGT tongue.gif
This post has been edited by Consynx: Jul 15, 2005 - 12:14 AM
post Jul 15, 2005 - 12:52 AM
FallenHero
Joined Dec 26, '02
From Alabama
I'd scrap it all for a wideband if $ is limited.
post Jul 15, 2005 - 1:00 AM
WIDEBAND o2 (biggest mistake people make by not buying one)
EGT
BOOST
post Jul 15, 2005 - 1:22 AM
Consynx
Joined Dec 25, '02
lol
post Jul 15, 2005 - 1:23 AM
Illyont
Joined Apr 8, '05
From Norway
QUOTE(Consynx @ Jul 15, 2005 - 1:22 AM)
lol
[right][snapback]312587[/snapback][/right]
Lagos doesn't have a 7A-FTE either..
post Jul 15, 2005 - 6:57 AM
id say for any home brew setup,
oil pressure
wideband(for tuning)
egt
This post has been edited by presure2: Jul 15, 2005 - 6:58 AM
post Jul 15, 2005 - 8:27 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
i don't even have fuel pressure. which is something i was wandering about, i will have a 3s boosting around 25 psi (when racing only, not daily of coarse), wiht a walbro fuel pump (255 i think, will be installed by XAT and they said what ever size pump i end up needing, depending on the fule consumption. i think they normally install a 255 wiht the swap, but i'm not getting the normal swap). and also upgrade injectors, i have been told by several people that i don't need a fuel pressure gauge, does anyone have any imput on that, and if you say i do need one, can you please tell me why.
This post has been edited by celicaracer18: Jul 15, 2005 - 8:29 AM
post Jul 15, 2005 - 8:28 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
oops
post Jul 15, 2005 - 8:34 AM
edo17982
Joined Dec 21, '02
From Italy
U know what? if u want to be safe in monitor your data u'd need almost all of them.
Fuel press: to check pressure loss or pump failure
Oil press: to check oil pump is ok and press not excessive or not too low
Oil temp: important cuz too high temp doesn't allow oil to keep it's properties
A/F: needless to say for what I think.....
EGT: high boost=high pressure=high temperature and they need to stay in limits
Boost: I'd suggest EBC which allow u to control boost spikes and monitor is safely
If u miss monitor one of those things and the one u're not lookin at goes wrong, 90% is too late to save your engine so....everything is up to you biggrin.gif
Just my 2 cents opinion anyway.....
post Jul 15, 2005 - 11:02 AM
SnowMan
Joined Mar 28, '05
From New Jersey
Thanks for your opinions/advice, I never thought of O2 or egt
post Jul 15, 2005 - 12:31 PM
nik
Joined Sep 30, '02
on my old 7afte set up i had
boost
oil pressure
oil temp
air/fuel not wideband but i have one now
EGT must have IMAO
e-01 watch most everything else
how close are you to boosting?
post Jul 15, 2005 - 12:41 PM
FallenHero
Joined Dec 26, '02
From Alabama
what wideband did you use? Surely a cheap one will come out one of these days... Right now $300 is the best I've seen.
post Jul 15, 2005 - 12:43 PM
SnowMan
Joined Mar 28, '05
From New Jersey
Close I hope, the toughest thing is tryin to convince my dad to let me spend the money, which I have. Hopefully I'll get custom exhaust in the next two weeks, and then next month to work on the setup before school starts. (is an oil pressure gauge 0-80 psi high enough)
nik
Joined Sep 30, '02
QUOTE(FallenHero @ Jul 15, 2005 - 10:41 AM)
[right][snapback]312743[/snapback][/right]
post Jul 15, 2005 - 1:05 PM
lol
i have a factory turbo motor. all the tuning is already done by toyota. no need for a wideband.
if you are doing a 7afTe or 5sfTe you will need one to know if the stock ecu and piggy back combo is making you run lean or ritch.
post Jul 15, 2005 - 2:12 PM
Consynx
Joined Dec 25, '02
post Jul 15, 2005 - 8:17 PM
SnowMan
Joined Mar 28, '05
From New Jersey
is an oil pressure gauge 0-80 psi high enough??
Lo-Fi Version Time is now: April 22nd, 2025 - 1:17 PM
