![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) ![]() |
Ok, so im still thinkin of duin a 5sfte kit, and the stupid 3s map sensor is 2 hard/2 expensive to find, but since i used 2 b a part of the supra comunity here in toronto, i have access to any thing that ever came on a supra for cheap. So i was wondering, would a map sensor off a 7MGE or 7MGTE work for the 5sfe turbo setup??..if so i should take a walk over 2 my grandparents place and grab the one on my supra off it.
bump......
no one knows??..any one?? |
![]() Enthusiast ![]() ![]() Joined Aug 27, '04 From Orange County, CA Currently Offline Reputation: 0 (0%) ![]() |
I don't think so.
Try the mr2oc.com boards. There is usually some floatin around there. -------------------- ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) ![]() |
It doesn't...use a 3S-GTE one.
OR...get a Missing Link bypass...I think it's the ML002, which is not particular to any Honda engine like the ML001 or ML003.
![]() Enthusiast ![]() ![]() Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) ![]() |
if your going 5sfte you can use a gm map sensor off of a 93-94 GMC Typhoon($28 at advance auto parts) I beleive it is a 2bar stock you can also get a 3bar , 2bar should be enough though.
As for the harness you can get it at just about any junkyard that has 81-01 gm vehicles($4-$7) so it's easy to find parts for this To convert the signal if you need to you can use a SAFC-II or other piggyback to do so. as far as converting the signal I did not need to change anything other than minor adjustments since I have larger injectors Also if you use the search for <map sensor> you can probably find where I had a topic over it when I first started my project -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
QUOTE(dans_st @ Dec 6, 2005 - 11:15 AM) [snapback]363979[/snapback] if your going 5sfte you can use a gm map sensor off of a 93-94 GMC Typhoon($28 at advance auto parts) I beleive it is a 2bar stock you can also get a 3bar , 2bar should be enough though. As for the harness you can get it at just about any junkyard that has 81-01 gm vehicles($4-$7) so it's easy to find parts for this To convert the signal if you need to you can use a SAFC-II or other piggyback to do so. as far as converting the signal I did not need to change anything other than minor adjustments since I have larger injectors Also if you use the search for <map sensor> you can probably find where I had a topic over it when I first started my project Can't search for map since it's only 3 letters but here is the thread: http://www.6gc.net/forums/index.php?showtopic=29180 I know I asked before but what did your corrections on your AFC end up being and what size injectors are you running now? Good to know my advice worked out well for you. This post has been edited by WannabeGT4: Dec 6, 2005 - 1:58 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
here it is
![]() alot of information is also in the link that was posted on there as well dans_st -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
QUOTE(dans_st @ Dec 6, 2005 - 5:14 PM) [snapback]364103[/snapback] here it is ![]() alot of information is also in the link that was posted on there as well dans_st Do you even read my posts? LOL -------------------- ![]() Project ST204.5 99.88946% complete... |
QUOTE WannabeGT4 Posted Yesterday, 07:17 PM Do you even read my posts? LOL sorry iwas at work and just went back and posted and didn't even see if someone already did it for me.....thanks ![]() -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
It should work as long as it has the same amount of wires going into it and out of it.
You might just have to find which wires are which and cut and splice unless they hook right up. Im guessing the 5S has about 3 wires going into it so the 7M might have the same amount too, unless its a MAF type sensor, then its not possible. |
Lo-Fi Version | Time is now: February 23rd, 2025 - 5:24 AM |
