Battery Relocation and Audio Installation DONE!, Finally finished project |
Jul 18, 2005 - 1:54 PM |
Enthusiast Joined Oct 25, '04 From Los Angeles Currently Offline Reputation: 0 (0%) |
So after hours slaving away at the car, taking apart pieces of dash, brackets and electrical tape, the car is finally DONE! So I'll start off by listing the new pieces that went in.
Pioneer DEH8600 MP (headunit)\ Pioneer 4" 2 way 100 watt speakers Stock Toyota Premium Tweeters Kicker SSMB8 Mid-bass drivers in the doors Pioneer 6.5" 3 wat 220 watt speakers for rear Kicker COMPVR 10" Sub Custom Enclosure in MDF housing both battery and sub. LOADS OF DYNAMAT! I'll start off by saying we ran 4 gauge wiring from the starter to an opening in the firewall near the steering column. Mounted a fuse holder with fuse on the firewall within easy reach. Ran the wires near the fuses of the interior and down the same factory wiring channeling to the back. I replaced all of the old speaker wire 12, 14, and 16 gauge wires. 14 gauge wire and a pair of 16 gauge wires were able to fit through the old sleeve in the door, NO SLOPPY WIRES! For the 4's I had to compeletly destory the old speakers because they were built in to the brackets, it required dremeling out enough room to put the pioneers in place. The 8's were the hardest, they DID NOT fit directly into the bracket, I had to cut about a 1/4 - 1/2 inch ring out of the bracket to get the door panel to close properly, in addition to mounting the driver on small pieces of 4 gauge wire sheath. Later this week I will be modifying the rear sets so they come down as one, the amps will be drilled to the backs of those seats and I will put some 80 mm computer case fans on top of the "hatch cover" to provide for enough air flow. I will post some pictures when the interior is all cleaned up and in place |
Jul 18, 2005 - 2:11 PM |
interesting
Jul 18, 2005 - 9:05 PM |
What amps are you going to use?
It sounds like your battery-relocation wiring is the same as mine. I've got four-gauge running from my battery to my starter as well. I also ran all new 14-gauge speaker wire throughout the car for my front speakers. -------------------- New Toyota project coming soon...
Jul 19, 2005 - 12:16 PM |
QUOTE(Coomer @ Jul 19, 2005 - 2:05 AM) What amps are you going to use? It sounds like your battery-relocation wiring is the same as mine. I've got four-gauge running from my battery to my starter as well. I also ran all new 14-gauge speaker wire throughout the car for my front speakers. [right][snapback]314019[/snapback][/right] I am actually using two Kenwood Amps, one 4 channel (4x75 w) and a kenwood 2 channel pushing 300 watts over each channel. Did you close up the battery in your subwoofer box? What design did you use to hold down the battery? Also, would you say that handling improved? |
Jul 19, 2005 - 1:44 PM |
Enthusiast Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
pictures please !!
-------------------- ----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Jul 19, 2005 - 2:47 PM |
QUOTE(jbcustom @ Jul 19, 2005 - 10:16 AM) I am actually using two Kenwood Amps, one 4 channel (4x75 w) and a kenwood 2 channel pushing 300 watts over each channel. Did you close up the battery in your subwoofer box? What design did you use to hold down the battery? Also, would you say that handling improved? [right][snapback]314211[/snapback][/right] My battery is located on the driver's side rear corner of the trunk. It's not part of the subwoofer box, and is held down by a piece of metal with two holes in it, with bolts sticking through the holes and nuts on those bolts. I drilled two holes in the trunk floor and used 1/4" bolts with fender washers underneath the car to hold the battery in place. The whole battery is located in a battery box as well, though I lost the top so it's not completely enclosed. The battery is definitely not moving anywhere though. I can take pictures of the setup if you'd like. And I didn't notice a handling improvement. But the wiring runs to my amps and the cleanliness of the engine bay and ability to run my CAI how it's run makes it worth it. I can't take my car to the track though, unless I mount a battery kill switch on the back of the car, which I'm not willing to do. -------------------- New Toyota project coming soon...
Lo-Fi Version | Time is now: November 30th, 2024 - 11:59 AM |
