tranmission fluid leak |
Jul 21, 2005 - 7:42 PM |
Enthusiast Joined Feb 17, '04 Currently Offline Reputation: 0 (0%) |
well ive noticed tranmission fluid leakin and i need to know wut the possible probelms could be ?
Jul 21, 2005 - 8:00 PM |
im guessing this is on a manual, right?
check for loose drain or fill bolts. check seals around axels. thats about it -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 21, 2005 - 8:20 PM |
check your seals jack up your car and slide under their and see whats wrong .
Jul 21, 2005 - 9:12 PM |
QUOTE(lagos @ Jul 21, 2005 - 8:00 PM) im guessing this is on a manual, right? check for loose drain or fill bolts. check seals around axels. thats about it [right][snapback]315225[/snapback][/right] auto -------------------- |
Jul 21, 2005 - 11:05 PM |
Maybe it's leaking from the tranny pan...the one you have to pull to change the filter. But looking at where the leak is coming from would be best.
Jul 22, 2005 - 12:23 AM |
QUOTE(Coomer @ Jul 22, 2005 - 4:05 AM) Maybe it's leaking from the tranny pan...the one you have to pull to change the filter. But looking at where the leak is coming from would be best. [right][snapback]315307[/snapback][/right] oh ok hm i guess my tranny has an oil pan hey does anyone know if our tranny auto is 2 parts cause if it is woudlnt there be a gasket between then? |
Jul 22, 2005 - 1:03 AM |
Yes, it's two parts, and yes, there's a gasket. On my '88 GT I got a tranny filter kit and it included a filter and new gasket and was only $18 or so.
Jul 22, 2005 - 3:45 PM |
ok i was under my car today umm i think it was the oil pan bolts cause they were fairly loose almost all of them so i tighten them hopefully that did it
Jul 23, 2005 - 8:14 AM |
QUOTE(latinomasfino @ Jul 22, 2005 - 3:45 PM) ok i was under my car today umm i think it was the oil pan bolts cause they were fairly loose almost all of them so i tighten them hopefully that did it [right][snapback]315605[/snapback][/right] forgeta bout your engine, and buy my 3s-ge. Simple fix. |
Lo-Fi Version | Time is now: December 3rd, 2024 - 6:12 PM |
