> st185 front brake calipers on 95 st.
post Jul 22, 2005 - 6:23 PM
Rjb23
Joined Feb 8, '04
From KY
Is it possible to put the st185 dual piston calipers on the front of a celica st without modification?
post Jul 22, 2005 - 6:41 PM
You need bigger rotors from what I understand...ST184/5 or ST204 rotors should work fine. My dual-piston All-Trac calipers are on their way and I just ordered Brembo rotors for a '90 Celica All-Trac. I'm going to run Satisfied ceramic pads in front as well. I'm almost positive that everything will bolt right together, but in a couple weeks I should be able to let you know for sure.
post Jul 22, 2005 - 7:26 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
if it works, i can sell my st185 calipers as well
post Jul 22, 2005 - 9:10 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Hmmm...increasing the size of the front calipers and switching to rear discs, would a new proportioning valve not be a good idea as well?
post Jul 22, 2005 - 10:00 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
The calipers will bolt up just fine, use the ST185 rotors.
DEF
I will return one day.
post Aug 18, 2005 - 9:43 PM
Rjb23
Joined Feb 8, '04
From KY
Ok looking at coomer and doggy's post it looks like the at200 rotors will work on the front.
But when I switch to rear discs will I need a new proportioning valve?
Lo-Fi Version Time is now: December 2nd, 2024 - 12:12 PM
