> Fog positioned, bored with pic's
post Jul 23, 2005 - 2:12 PM
macavely
Joined Nov 4, '02
i was bored can't really drive my car right now.. so i worked on the bumper and installed some lights...
post Jul 23, 2005 - 2:24 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
ok tip no 1 never permantely attatch anything to your car (especially on the exterior, wires and such are different) with ZIP Ties. most fog/driving lights come with screws for that,
look ok though
post Jul 23, 2005 - 2:25 PM
macavely
Joined Nov 4, '02
also did this to the broken edge.. dont done yet.. have to put some washers where
bolts go... where they connet the bumper to the finder.. I have done this on another car i owned .. looks ugly but works... there you go coomer..
This post has been edited by macavely: Jul 23, 2005 - 2:36 PM
post Jul 23, 2005 - 2:26 PM
macavely
Joined Nov 4, '02
QUOTE(celicaracer18 @ Jul 23, 2005 - 2:24 PM)
look ok though
[right][snapback]315919[/snapback][/right]
every car i have every owned the i used zip ties to hold down the fogs... never had a problem with it..
post Jul 23, 2005 - 2:34 PM
the bolts will good.. lucks ugly but don't it before on another car i owned..
If you don't bolt the lights into something solid, I bet that they'll wobble at high speeds or over bumps and stuff, because the front bumper is so flexible. If you are going to use zip-ties, I at least recommend zip-tieing the fogs to something solid.
My fog light brackets are bolted to my crash reinforcement bar with two 1/4" bolts per side, which seems to work well.
post Jul 23, 2005 - 2:37 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
exactly, plus zip ties seem so redneckish, and just don't look as good. work ok as a quick fix, but o permenately.
post Jul 23, 2005 - 2:39 PM
Well, if they work, more power to you, but I'd worry about shaking fog lights, or a zip-tie breaking and causing a fog light to fall off or something.
macavely
Joined Nov 4, '02
QUOTE(Coomer @ Jul 23, 2005 - 2:34 PM)
Can I get a translation on that? tongue.gif TRANSLATED ON TOP POST....
[right][snapback]315924[/snapback][/right]
don't worry about the fog they won't go anythere... if they do ... i don't mind getting another set ..
post Jul 23, 2005 - 2:43 PM
macavely
Joined Nov 4, '02
QUOTE(celicaracer18 @ Jul 23, 2005 - 2:37 PM)
[right][snapback]315928[/snapback][/right]
yes redneckish but it works... and i have more then a few holding it on
QUOTE(Coomer @ Jul 23, 2005 - 2:39 PM)
[right][snapback]315929[/snapback][/right]
never happened to me... but if it does... i can just add the to the list of many things i have destroyed.. lol ..
post Jul 23, 2005 - 2:45 PM
Cool...well post back with more pics when you get everything back on the car. smile.gif
Where are you mounting the fog light switch?
post Jul 23, 2005 - 2:50 PM
macavely
Joined Nov 4, '02
QUOTE(Coomer @ Jul 23, 2005 - 2:45 PM)
[right][snapback]315932[/snapback][/right]
i will ..but the bumper won't be on for a few days atlest
.. and they light switch is in the spot where i had my amp switch .. but since i took it out (the amp) the switch has just been there... so Fred ran the wires for me and its connected to that switch
Fred runing the wires for me
post Jul 23, 2005 - 8:01 PM
vangSTa_celica
Joined Jul 10, '03
From Appleton,WI
Cool, positioned like mine.
A Jaws4God Creation...
Lo-Fi Version Time is now: November 24th, 2024 - 11:37 AM
