Door Panels, Pics Wanted |
Apr 19, 2006 - 5:42 PM |
Enthusiast Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
would you guys recommend replaced the blown 8" drivers in the premium door setup or making a bracket and installing replacement 8" subs??? I was looking at 8" rockford punch, they are cheap...
-------------------- -Rémy 02 SiR, 08 250R |
Aug 4, 2006 - 9:27 PM |
Enthusiast Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) |
I have an ST (4 speaker panel), my panels are getting old and I would like to replace them.
Would the 8 speaker panel one fit? Thanx |
Aug 4, 2006 - 10:34 PM |
Enthusiast Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
I know the stock speaker that was in my door was 8"
But when I put my Kicker 8" midbass drivers I had to cut & trim the mount and got them to fit pretty easily. |
Aug 17, 2006 - 10:32 AM |
Enthusiast Joined Apr 4, '05 Currently Offline Reputation: 0 (0%) |
QUOTE(jbcustom @ Jul 28, 2005 - 1:18 PM) [snapback]317742[/snapback] 8 speaker (1 tweeter in each mirror triangle, 2 in each door (4"and 6.5"), 1 in each rear panel) actually in the premium audio package the doors house 8" drivers, some models such as the Kicker SSMB8's will not fit the bracket perfectly, thus require some modifications Damn I want those door panels they look so ummm NEW!!! =) |
Aug 17, 2006 - 1:33 PM |
Enthusiast Joined Jul 10, '06 From South Carolina Currently Offline Reputation: 6 (88%) |
QUOTE(dlx742 @ Mar 9, 2006 - 2:12 AM) [snapback]404988[/snapback] how would you put a 6.5" speaker in the door where the 8" normally goes. would use some kind of bracket? http://cgi.ebay.com/ebaymotors/Speaker-ada...sspagenameZWDVW I have these, they worked great. Samantha |
Feb 9, 2007 - 7:58 AM |
Enthusiast Joined Dec 24, '06 From Okinawa Japan Currently Offline Reputation: 0 (0%) |
I bought the midbass Kicker 8" for my door panels. Whoever said it needs modification is correct, if you dont then your door wont be able to go on correctly. So what I did is just cut the bracket to where it will flex around the kickers, wrapped it around the kicker put a screw in it and sealed the entire thing with sealant.
Sounds nice and works. |
Feb 9, 2007 - 10:26 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(jbcustom @ Jul 28, 2005 - 5:18 PM) [snapback]317742[/snapback] 8 speaker (1 tweeter in each mirror triangle, 2 in each door (4"and 6.5"), 1 in each rear panel) actually in the premium audio package the doors house 8" drivers, some models such as the Kicker SSMB8's will not fit the bracket perfectly, thus require some modifications There is another option too. I had stock the 8"s in the door, the tweets in the mirrors and the 6"s in the rear with one amp, CD/Radio and no tape deck. The only 8 speaker setups I have seen have been in verts. IDK if that's always true just what I have seen. -------------------- |
Mar 1, 2007 - 3:47 PM |
Enthusiast Joined Mar 28, '06 From Brooklyn, New York Currently Offline Reputation: 1 (100%) |
premium sound rocks made me stay stock for awhile now I have a GT 94 hack
This post has been edited by LeonStryfe: Mar 1, 2007 - 3:48 PM |
Mar 1, 2007 - 6:36 PM |
yup, the stock 8 speaker system is good enough for me to stay stock. the only thing different now is my headunit. now i just need to fix all the buzzing in my doors...
Jul 4, 2007 - 11:43 AM |
Enthusiast Joined Jun 28, '07 Currently Offline Reputation: 0 (0%) |
Do the 4 speaker systems have the external OEM amp?
Hopefully not, sounds like a hassle(don't want to add amp/wires). |
Jul 4, 2007 - 6:07 PM |
there are no external amplifiers with the 4 speaker system..
Jul 5, 2007 - 11:55 AM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
QUOTE(Negative @ Feb 9, 2007 - 10:26 AM) [snapback]525384[/snapback] QUOTE(jbcustom @ Jul 28, 2005 - 5:18 PM) [snapback]317742[/snapback] 8 speaker (1 tweeter in each mirror triangle, 2 in each door (4"and 6.5"), 1 in each rear panel) actually in the premium audio package the doors house 8" drivers, some models such as the Kicker SSMB8's will not fit the bracket perfectly, thus require some modifications There is another option too. I had stock the 8"s in the door, the tweets in the mirrors and the 6"s in the rear with one amp, CD/Radio and no tape deck. The only 8 speaker setups I have seen have been in verts. IDK if that's always true just what I have seen. I have the premium 8 speaker package in a hatchback... 95 GT...so it was available on others than the convertible but my GT is fully loaded . Your eights are actually 6.5's in "custom" stock brackets to fit the eight inch holes. and they are 6.5's in the back and thats the same for every option on another note... i know from taking out the premium sound that the HVAC amp in the eight speaker is the same as the 6 speaker and the one under the driver seat powers the 25W (compared to 15W) 8 inch sub woofers in the door (yes they are subs) AND both amps are Fujitsu Ten meaning we have ECLIPSE amps stock in our cars much love to ECLIPSE for some of the best sounding equipment... i've always used there stuff and will til i die also i will be posting in the for sale topic my premium sound amps (both of them) and the wiring for it all in good and working condition since i now have an eclipse touch screen head unit powering it all This post has been edited by pittfirefighter: Jul 5, 2007 - 11:56 AM -------------------- Breaking Axles...
Aug 11, 2007 - 5:57 PM |
Enthusiast Joined Jul 18, '07 From Arlington, VA Currently Offline Reputation: 0 (0%) |
QUOTE(rad1an7 @ Feb 9, 2007 - 7:58 AM) [snapback]525361[/snapback] I bought the midbass Kicker 8" for my door panels. Whoever said it needs modification is correct, if you dont then your door wont be able to go on correctly. So what I did is just cut the bracket to where it will flex around the kickers, wrapped it around the kicker put a screw in it and sealed the entire thing with sealant. Sounds nice and works. Are you referring to the Kicker SSMB8 speakers? I was considering a pair to replace the stock speakers which have crumbled surrounds. At $99 online they sound like a pretty good deal. With the stock speakers costing $160 / each, it doesn't make sense to go stock. However, I'm concerned that the Kickers are 4 ohm rather than the stock 2 ohm. Do they sound all right, or do they sound excessively quiet, given they have double the resistance of the stock speakers? Either way, I'm sure they sound better than speakers with completely disintegrated surrounds!! Also, does anyone have recommendations for replacements for the 6.5" speakers in the rear? Thanks, Matt |
Aug 11, 2007 - 6:49 PM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
Why do you say that it is 2ohm? both my celica come with 4 ohm speakers and 2ohm speakers is not common at all.
Aug 12, 2007 - 8:58 PM |
QUOTE(soven @ Aug 11, 2007 - 6:49 PM) [snapback]587272[/snapback] Why do you say that it is 2ohm? both my celica come with 4 ohm speakers and 2ohm speakers is not common at all. I know 2-ohm is not common...that's why it's next to impossible to find a 2-ohm replacement. From looking ath the drivers int the doors, the 4" midrange and the tweeters are both marked 4-ohm, while the stock 8" drivers are marked 2-ohm on the back. Putting a 4-ohm speaker where there had been a 2-ohm will effectively reduce the power of the amp, so I was concerned about them sounding too quiet relative to the rest of the system. |
Aug 21, 2007 - 1:12 PM |
Enthusiast Joined Dec 12, '06 From Fob Sharana, Afghanistan Currently Offline Reputation: 2 (100%) |
OK. Let me get this straight. So, it's TWO 6.5" Tweeter Speakers in the front (for the 2 big ones)? Alot of people are saying 8" speakers and it's really confusing.
Aug 21, 2007 - 2:10 PM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
QUOTE(FortuneCookie @ Aug 21, 2007 - 7:12 PM) [snapback]589690[/snapback] OK. Let me get this straight. So, it's TWO 6.5" Tweeter Speakers in the front (for the 2 big ones)? Alot of people are saying 8" speakers and it's really confusing. There are at least five configurations of speaker system for the Celica: 1. 6.5" in the rear, 6.5" in the front. I believe this is standard for the US and the ST in the UK 2. 6.5" in the rear, 8" in the front. I believe this is standard for the GT in the UK 3. 6.5" in the rear, 8" and tweater in the front 4. 6.5" in the rear, 6.5" and tweater in the front 5. 6.5" in the rear, 4", 8" and tweater in the front I think it is this last configuration that most people here are talking about. This post has been edited by BloodyStupidDavey: Aug 21, 2007 - 2:11 PM -------------------- Davey
Items for sale |
Aug 21, 2007 - 2:58 PM |
Enthusiast Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) |
It's not an 8" speaker, it's a 6.5" speaker in an 8" hole.
Sep 1, 2007 - 12:40 AM |
Enthusiast Joined Jul 10, '07 From us Currently Offline Reputation: 0 (0%) |
OMG noob moment!!! i totally didn't even know that that box under my seat was an AMP!! i just shrugged it off and thought it was the ecu or something. So i have a question...i have an aftermarket kenwood deck and when the shop installed it, they had to bypass the internal amp. So, my deck alone doesn't push enough power for the 8 speakers. (actually its only six, as i have removed the back speakers because they were blown) Since it doesn't produce enough power, my 8" subs don't hit as hard as they did with factory deck. ( I would have stayed stock but my factory deck skipped on every little bump) So my question is can i somehow still use that external amp??? Thanks everyone for the info!!
Sep 2, 2007 - 3:00 PM |
QUOTE(BloodyStupidDavey @ Aug 21, 2007 - 2:10 PM) [snapback]589699[/snapback] QUOTE(FortuneCookie @ Aug 21, 2007 - 7:12 PM) [snapback]589690[/snapback] OK. Let me get this straight. So, it's TWO 6.5" Tweeter Speakers in the front (for the 2 big ones)? Alot of people are saying 8" speakers and it's really confusing. There are at least five configurations of speaker system for the Celica: 1. 6.5" in the rear, 6.5" in the front. I believe this is standard for the US and the ST in the UK 2. 6.5" in the rear, 8" in the front. I believe this is standard for the GT in the UK 3. 6.5" in the rear, 8" and tweater in the front 4. 6.5" in the rear, 6.5" and tweater in the front 5. 6.5" in the rear, 4", 8" and tweater in the front I think it is this last configuration that most people here are talking about. as far as i know.. the only 8" were available in the 8 speaker premium sound with the 2 amps (number 5)... the other options have a 6.5 inch speaker in a molded metal adapter so numbers 2 and 3 don't exist but all front holes are 8" and all backs are 6.5" -------------------- Breaking Axles...
Lo-Fi Version | Time is now: December 2nd, 2024 - 3:53 AM |
