car wont stay on, starts up, dies |
Jul 29, 2005 - 11:03 AM |
Enthusiast Joined Feb 19, '05 From Indianapolis Currently Offline Reputation: 0 (0%) |
car starts up but dies in like 2 seconds after fluttering rpm's. Since it starts, it shouldnt be the spark plug, what could it be? Sometimes i can push the gas in to keep the rpms up but sometimes pushing the gas has no effect.
Jul 29, 2005 - 11:21 AM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
do u get engine light on?
Jul 29, 2005 - 11:36 AM |
sounds like you almost have what i got, the Idle air control valve needs to be replaced.
Jul 29, 2005 - 12:12 PM |
the check engine light comes on after it dies, but so does the oil light and battery light.
Jul 29, 2005 - 12:14 PM |
where is the the idle air control valve at?
Jul 29, 2005 - 12:33 PM |
on the throttle body.... chances are u can just take it out and spray it with some carb cleaner.
good question, im gonna pick it up at lunch, hope my manual has pics of it and how to install.
Jul 29, 2005 - 12:40 PM |
ok, now the car does the same thing, it starts up stays one for five seconds than dies. If I try to give it gas, the car just dies instantly.
Jul 29, 2005 - 2:46 PM |
Enthusiast Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
make sure the butterfly valve is still connected. my g/f's fell off and did that. the valve conected to the turbo shooting off to the right of the engine.
Jul 29, 2005 - 3:34 PM |
does one need to take out entire throttle body to change out the valve?
Jul 29, 2005 - 3:58 PM |
Enthusiast Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) |
check ur sensors - could be linked to the MAP or MAF sensor - I had same problem a while back -- if it is the sensor - go to junkyard - that thing cost like over $200 for new one -- one little small piece of
Jul 29, 2005 - 4:56 PM |
well, i just tried it again and now it wont even start up.
Jul 29, 2005 - 5:17 PM |
Enthusiast Joined Apr 22, '04 From Rhode Island Currently Offline Reputation: 3 (100%) |
QUOTE(LewFX @ Jul 29, 2005 - 4:36 PM) sounds like you almost have what i got, the Idle air control valve needs to be replaced. [right][snapback]318137[/snapback][/right] i had same problem... thats what it is. |
Feb 17, 2006 - 4:09 PM |
Enthusiast Joined Nov 29, '05 From Florida Currently Offline Reputation: 0 (0%) |
QUOTE(Terzin1 @ Jul 29, 2005 - 11:03 AM) [snapback]318118[/snapback] car starts up but dies in like 2 seconds after fluttering rpm's. Since it starts, it shouldnt be the spark plug, what could it be? Sometimes i can push the gas in to keep the rpms up but sometimes pushing the gas has no effect. my cars doin the samething now?? if i keep push the gas and rev it ,it stay on but it won't stay in idle ????? any anwsers??? valve trottle , map sensor , fuel pump |
Feb 17, 2006 - 4:40 PM |
Feb 17, 2006 - 5:09 PM |
Enthusiast Joined Oct 30, '05 Currently Offline Reputation: 0 (0%) |
How's the weather were you live? Is this a recent problem? I just got vapor lock and I don't think it's gonna be warm enough to start for several days.
Feb 17, 2006 - 6:25 PM |
IAC valve.
13.6@108MPH, 5SFTE Powered |
Feb 18, 2006 - 12:42 AM |
Enthusiast Joined Jun 28, '05 From Bay Area, CA Currently Offline Reputation: 0 (0%) |
Does it stay on after it's warmed up? I've got the same problem with mine, but only when the engine is cold. If I rev it up to about 4000-5000RPMs and let it drop, most of the time it will start to idle, although usually low, around 800, even though it's not warmed up yet.
I was thinking it could be the EGR being dirty, since it's fine after I stomp on it, I think that's warming up the engine enough that the EGR being clogged doesn't affect the cold idle... |
Feb 20, 2006 - 7:19 PM |
Enthusiast Joined Oct 27, '05 From Olympia, Washington Currently Offline Reputation: 1 (100%) |
Where is the IAC? Pictures?
Where is the IAC? Pictures? -------------------- !!KANER!!
Feb 20, 2006 - 7:35 PM |
Lo-Fi Version | Time is now: November 22nd, 2024 - 3:36 PM |
