> Removing Brake Lines?
post Jul 31, 2005 - 9:18 PM
How do I remove the rear brake lines? I attempted to disconnect the solid line from the flexible one on my rear end because I'm doing a drum to disc conversion, but I ended up rounding off two corners of the 10mm bolt on the hard line.
How do you guys manage to get those off? I tried lots and lots of PB Blaster by the way, but it didn't help.
post Aug 1, 2005 - 2:22 AM
macavely
Joined Nov 4, '02
use vicegrip pliers ..
post Aug 1, 2005 - 6:22 AM
flare end wrenchs, christain. they're made to grip the flat section of the nut more than a normal wrench, so that you dont round them off.
worth the investment for brake, and fuel lines.. (right MAC???!!! wink.gif )
post Aug 1, 2005 - 4:12 PM
macavely
Joined Nov 4, '02
QUOTE(presure2 @ Aug 1, 2005 - 6:22 AM)
[right][snapback]319051[/snapback][/right]
Yea manny is rigth and they a little more the normal rencher ... but its better then twisting up a fule line to holy hell ...
Lo-Fi Version Time is now: November 30th, 2024 - 7:57 PM
