> TRUNK LOCK, 94 COUPE TRUNK STUCK!
post Aug 2, 2005 - 10:35 AM
DOODLE
Joined Feb 18, '05
From NEW JERSEY
YO, I am having a problem with openning my trunk. Here is the situation.
Key fits in lock. But, will not open when turned. The trunk mechanism will not release. Also, the cable release next to fuel release lever was broken off by previous owner. So, can't use that feature. Is there any other way to open trunk so I can try to see what the problem is? Any help is greatly appreciated. frown.gif
post Aug 2, 2005 - 10:39 AM
Cutrara
Joined May 6, '05
From PA
post Aug 2, 2005 - 10:41 AM
DOODLE
Joined Feb 18, '05
From NEW JERSEY
I did that to grab my stuff out of the back. But that space to enter trunk is limited even with seats down.
post Aug 2, 2005 - 11:01 AM
Cutrara
Joined May 6, '05
From PA
Ok, pull up your carpet in the area where the release handle is broken off, find the cable, it will probably be in a plastic tube. Cut away part of the tube and pull the cable.
Edit: Use this as a temp solution until you get a replacement release handle. Check salvage yards. If this doesn't work, then you need to fold down the seats, crawl in there with a flashlight and pull off that plastic and replace the whole cable, because it's probably broken in the plastic tube somewhere.
This post has been edited by Cutrara: Aug 2, 2005 - 11:04 AM
post Aug 2, 2005 - 11:06 AM
DOODLE
Joined Feb 18, '05
From NEW JERSEY
Thanks! I will give it a try tonight after work.
D
post Aug 3, 2005 - 10:53 AM
DOODLE
Joined Feb 18, '05
From NEW JERSEY
Cutrara,
Thanks! for the info. It really helped. I finally got the trunk open using pliers and interior cable. I found the problem was a corroded lock. All the teeth were shot. Now I need to get a new lock and key. Know any places, dealers that sell them? And, hopefully not that expensive.
Thanks again
post Aug 3, 2005 - 2:38 PM
Cutrara
Joined May 6, '05
From PA
Good, glad I could help
Lo-Fi Version Time is now: November 29th, 2024 - 7:43 AM
