what tranny is best for a 3gste swap? |
Aug 2, 2005 - 12:35 PM |
Enthusiast Joined Jul 20, '05 From Philly Currently Offline Reputation: 0 (0%) |
im trying to do a swap and need a fwd tranny. what tran would you guys recommend? right now it is only the front clip do i need the rear to make the swap work? the person told me i need the belts etc and the fwd because the 3gste is awd is that true that i need to get a fwd.
This post has been edited by TruXSaMuRai: Aug 2, 2005 - 12:37 PM |
Aug 2, 2005 - 1:17 PM |
type in 3sgte swap in the search here and on celicatech.com . tons of info out there
This post has been edited by lagos: Aug 2, 2005 - 1:17 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 2, 2005 - 7:31 PM |
look for a recent thread with the word "axels" in the title. Also, look for a thread entitled "trannys worthy of power". Good luck.
Aug 2, 2005 - 11:25 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
The simplest tranny to use is the Celica GT tranny. It bolts right up, you need a GT tranny clutch kit but a 3SGTE pressure plate.
The stronger tranny is the E153 which can be found in the Camry (Solara) V6 5-speed, along with the MR2 Turbo. The one from the MR2 Turbo needs gear selector parts from the Camry since the MR2 has the parts on the opposite side. There's more info on that here if you search. With the E153 you use the Celica GT4 mounts, and a Celica GT4 (alltrac) clutch kit. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Aug 3, 2005 - 1:28 AM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
How about the Matrix 6-speed tranny?
Aug 3, 2005 - 1:39 AM |
QUOTE(tomazws @ Aug 3, 2005 - 1:28 AM) How about the Matrix 6-speed tranny? [right][snapback]319824[/snapback][/right] umm NO -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:50 AM |
