> Help for 2din console
post Apr 28, 2003 - 5:12 PM
Sthen
Joined Dec 21, '02
From Europe Italy Lodi
Hello i'm interested to mount a 2din consoleon my celi...in itlay we have single-din console.....
one question for you...in the rear part of console(plastic) do you have a frame or other items that allow to fit 2 separated radio?????
i'll mount in the upper spot an tvradio and in the lower a JVC kdsh909 or sh9101.....
help me pleaseeeeeeeeeeeeeeee
Sthen
Sthen Italy
post Apr 28, 2003 - 6:29 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Yeah, you could do that. I know that in order to install a single din unit in a double din opening youre supposed to use a pocket filler, and that has a metal bracket on the back to mount the stereo and pocket. You could proably buy one and install both stereos on the adaptor, as long as you know how to wire the stereos to both work. Either that, or you could buy a double din unit online and have it shipped to Italy. Hope that helps. By the way, i love youre car wink.gif
post Apr 29, 2003 - 3:18 AM
Sthen
Joined Dec 21, '02
thank's a lot.......
can you help me to find the metal bracket??? is a toyota original part????
Ciao
Sthen
Sthen Italy
post Apr 29, 2003 - 4:52 PM
Silver94CelicaOw...
Joined Oct 13, '02
The bracket is found on a universal din-sized pocket you buy if you need to fill a second din space. Its not an original Toyota part. It looks something like this ---->din-sized pocket
The reason i mentioned the bracket was that you may be able to take out the plastic pocket and just use the metal frame part to mount both stereos, if this is the kind of mounting system thats in your car right now........If not, i would check to see how the existing stereo is mounted, and do the same on the bottom unit, or use the stereo you have now and see if you could mount it on bottom. If that works, you should be able to install both with one on top of the other. Im not an expert, so maybe somebody else knows for sure, but i hope that helps.
This post has been edited by Silver94CelicaOwner: Apr 29, 2003 - 4:57 PM
post Apr 30, 2003 - 2:13 AM
Sthen
Joined Dec 21, '02
Great!!!!
i write to them for have some info.......i think that the frame is good for me....
This is a very good help to me.......
Thank's very very much
Sthen
Sthen Italy
post May 21, 2003 - 2:02 AM
gdog477
Joined May 21, '03
From NYC, New York
i would just suggest installing a double din radio. if u want a cd/mp3/cassette/ and radio all in one, kenwood makes some nice double din stereos. That what i did
post May 29, 2003 - 6:26 PM
exxtractor
Joined Mar 31, '03
From BC
I have an older blaupunkt system with a single CD headunit and a five disc in dash below. I think a tape deck is pointless, and I like the fact I don't have to open the trunk or put my hand under the seat to change a magazine of CD's.
Lo-Fi Version Time is now: February 21st, 2025 - 8:12 AM
