putting in the short shifter, problems with clip |
Aug 3, 2005 - 8:05 AM |
Enthusiast Joined Mar 12, '03 From shippensburg, PA Currently Offline Reputation: 0 (0%) |
I read the TWM how to article and they told me to use a exacto knife to remove the first clip after you have removed the consel, well i had a really hard time with it and it got dark before i could even get it off, doesnt anyone know another way to get it off. I tried for proabably an hour just on that part. Help.
Aug 3, 2005 - 10:30 AM |
Enthusiast Joined Jul 7, '04 From Germantown, WI Currently Offline Reputation: 0 (0%) |
Im putting mine in tonight. Sounds pretty easy, just use the exacto to make the gap wide enought to stick a screwdriver in and then pry it off with the driver.
Aug 3, 2005 - 11:01 AM |
screwdriver and pry. It is best to replace it so don't worry about damaging the old one.
Aug 3, 2005 - 1:42 PM |
did you guys take off the upper console too? and i tried the screwdriver thing and the white plastic gives too much to get any force behind the clip.
Aug 3, 2005 - 6:48 PM |
needle nose pliers and pull.
Aug 3, 2005 - 8:26 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I was able to take a screwdriver to mine and it popped off... almost lost it thought cuz i had to re-use it. I didn't remove the upper console.. when you release it, you can move the assembly up to get more access.
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Aug 3, 2005 - 9:40 PM |
all you need to do is take your screwdriver and wiggle the top, left side, right side, and everywhere in between. Just work your way all around the clip. you can twist the flat tip so that it forces separation.
Aug 4, 2005 - 9:11 AM |
thanks for the help guys, im gonna try and put it in tonight so ill let ya know how it goes....
Lo-Fi Version | Time is now: November 25th, 2024 - 1:47 PM |
