Projectors |
Projectors |
Aug 4, 2005 - 8:15 AM |
Enthusiast Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
Ok I’m writing this because I keep getting PMs and stuff. I did a search and put in some useful info. Idk if this is useful to anyone but if it's not and its just taking up space then delete it
Add or correct me if I’m wrong. First off here are the part numbers: LOWS 81014-20100 (Left) 81012-20100 (Right) HIGHS - 81130-20050 81170-20050 Second: Where can you get them… If you have a Toyota near you that has a parts department they can most likely get them for you. Give them the part numbers. The Toyota near me could have gotten them BUT it would have cost me more then what I paid through Toyota World. Most people on this sight have gone through Jeff at Champion Toyota in Texas (Toyotaworld.com) the price to get them there has gone up though. Call him, its much easier to call then have to wait for an e-mail response. ( (713) 943-7010 ) Another option is to e-mail tbrd2005@gmail.com. TBRD is a e-bay seller that can get them for around 750 USD. ebay profile: http://feedback.ebay.com/ws/eBayISAPI.dll?...-1&frm=2624 he’s a good seller I bought my JDM tails off of him. Ok so now that you ordered the Projectors your going to need to get go to Autozone and ask for a couple of H4 connectors for the Lows. ( like $4 ) The high beams use the same connection as the stock highs. Also while you are at Autozone get one of these your going to have to crimp the wires for the low beams. I used the smallest size which is red worked great- cost me about $ 7.00. I’m pretty sure that the lows come with bulbs in them, mine did. If not then you can get any H1 bulb for them. (go to autobarn u get some Hella H1's for like $5 a piece. AutoBarn) The highs use the same bulb as the stock lights. Another option on lighting is to get a H.I.D. kit. H.I.D. is about $300-$400 for a kit. Longer lasting bulbs, brighter bulbs. Since the projectors are from Japan they are made for RHD cars. Kadett made a how-to to convert them to LHD here : http://www.6gc.net/index.php?action=howto&itu=142 This is also helpful : http://www.6gc.net/forums/index.php?showto...19182&st=40 Also you can use the side-marker lights in the "accent" bulb on the low beams. Since I don’t have this done to mine I’m not positive how you do it. I think the accent lights use 194 bulbs? Ok so now that you have everything you need. You have to take off the front bumper. It’s not hard. The hardest part is getting to the top bolts up in the fenders. FYI: The JDM highs and Lows do NOT meet D.O.T safety regulations. In order for them to be D.O.T. approved they would have to have been offered in the U.S. to go through their regulations. Also, projectors are angled for RHD Celicas which makes the beam shoot the opposite way of regular u.s. cars. Most of us who have them have not had a problem with the police so far (knock on wood). Most Cops dont know the difference anyway so you should be fine. **UPDATE 3-29-07** took a couple of pics: In this thread there is an alternative to cutting the orig. wires: QUOTE(jason @ Mar 29, 2007 - 5:44 PM) [snapback]541160[/snapback] dont cut!!!!!! i just got h4 connectors, pulled the one wire out of it so it was just the 2 that i need so it looks all clean, then the other end of the pig tails i just stripped them and tinned? them (made stiff w/ solder) then just inserted into the existing 9006 harness - this way no cutting and going back to stock is still possible, plus it looks clean =) just get diff diameters of heat shrink and make it all weather proof then, im working on that now actually took 3rd wire out simple connection no cutting This post has been edited by ILuvMyCelica95: Mar 29, 2007 - 6:15 PM -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Aug 4, 2005 - 8:31 AM |
Enthusiast Joined Mar 4, '03 From Kirkland, Washington Currently Offline Reputation: 0 (0%) |
thanks for this... i get so many PMs on mine
-------------------- Cruisin down the street in my Infiniti...always lookin for my next trip to Sin City
Aug 4, 2005 - 8:34 AM |
Enthusiast Joined Nov 22, '03 From Tracadie-Sheila, NB (Canada) Currently Offline Reputation: 14 (100%) |
you did the LHD conversion?
after reading it...I dont want to do that....too afraid to hurt the projectors i guess alot of ppl use their projectors without that LHD conv.....how bad could it be without the conv? |
Aug 4, 2005 - 9:15 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
There are 3 people here that did the conversion as far as i know off.
Fietsbel (1st to it i believe) Kadett Mark 426 -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 4, 2005 - 11:45 AM |
QUOTE(ILuvMyCelica95 @ Aug 4, 2005 - 9:15 AM) Ok so now that you ordered the Projectors your going to need to get go to Autozone and ask for a couple of H4 connectors for the Lows. I’m pretty sure that the lows come with bulbs in them, mine did. If not then you can get any H1 bulb for them. (go to autobarn u get some Hella H1's for like $5 a piece. I put HIDs in mine so I am not sure if this is correct. You need an H4 connector for an H1 bulb? -------------------- |
Aug 4, 2005 - 11:54 AM |
H1 and H4 are the same for two; H4 has an extra prong, just like the 110v American outlets. The third is used in some cases, not in others. It doesn’t matter of you get a H4 connector. The middle plug is not needed for H1.
Aug 4, 2005 - 12:05 PM |
Exactly what Tina said.
This is what my connector looks like. -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 4, 2005 - 2:13 PM |
QUOTE(Kadett @ Aug 4, 2005 - 5:05 PM) Exactly what Tina said. This is what my connector looks like. [right][snapback]320480[/snapback][/right] 1 thing im wondering why the connector got 3 prong and the H1 bulb only got 1 pin to plug....you plug the bulb into any of the three prong or what? |
Aug 4, 2005 - 2:46 PM |
Like i said before H4 has an extra prong
It doesn’t matter of you get a H4 connector. The middle plug is not needed for H1. the wiring is really not as difficult as it sounds plug the 3 prong harness in to the projector...Cut off the existing harness from your OEM lights...then crimped them using butt connectors... then electrical tape and your done. -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Aug 4, 2005 - 2:50 PM |
You meany Had to go to my car take out the light and make a picture of it.
The left part is connected with the h4 connector. The bulb is fitted into the socket from the left. BTW the left part Has 2 prongs. but shot the picture from above so 1 is above the other. This post has been edited by Kadett: Aug 4, 2005 - 2:51 PM -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 4, 2005 - 2:56 PM |
haha i was tempted to do that when i got home but im glad you did it instead of me
Aug 4, 2005 - 2:57 PM |
No problem tina, only its 22:00 PM here now so its dark. And gotto get up at 4:00 am Ah well.
Aug 4, 2005 - 3:00 PM |
Enthusiast Joined Jul 7, '04 From Maryland Currently Offline Reputation: 0 (0%) |
how hard would it be to convert back to regular headlights? just incase you sold the car and had to put the other lights back in.
Aug 4, 2005 - 3:01 PM |
You mean. To replace the projectors for stock? Well it took me 3 hours total to remove bumper remove stock and install projector.
But i dont know where you can get the stock US/Euro 9006 connector. Other then that its easy work. -------------------- JDM Powerplant installed, BPU coming very soon!
QUOTE(Kadett @ Aug 4, 2005 - 7:50 PM) You meany Had to go to my car take out the light and make a picture of it. The left part is connected with the h4 connector. The bulb is fitted into the socket from the left. BTW the left part Has 2 prongs. but shot the picture from above so 1 is above the other. [right][snapback]320548[/snapback][/right] ok so do I need to buy a "socket" like that too (left part) in addition to the H4 connectors, or it' s the same part? |
Aug 4, 2005 - 3:03 PM |
Well for me it came with the lights. My bulb is replaced by a Philips Vision Plus.
So yes if you dont have the bulb with the projectors you will also need to buy the socket. I also got the Sidelights for the projectors but for now i just used the standaard 194 bulb socket that was already in the stock light and pushed it in the projector housing. Guess your parts dealer did not include the bulbs itself. My contact also got my the complete wiring for the JDM Tails. And the bulbs + sockets for the projectors. Only not for the highbeams since they are the same 9005 lights. This post has been edited by Kadett: Aug 4, 2005 - 3:07 PM -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 4, 2005 - 3:09 PM |
HaRv3sTeR where did you order your projectors from?
Aug 4, 2005 - 3:12 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
I vote to put this as one of the HOW TO's
Aug 4, 2005 - 3:16 PM |
I didn't think that was needed because i already got the socket etc etc with the light. If i knew about you guys not getting that i would have made my how to more detailed. Ah well. Time for bed nowl!
Aug 4, 2005 - 3:25 PM |
Thats why i asked where HaRv3sTeR got his lights from. Mine came from Toyota world and included the bulbs for the lows.
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:18 AM |
