3 Pages V   1 2 3 >
> Brake Upgrade for ST, ST165 brakes on AT200
post Aug 7, 2005 - 1:54 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
Well, i was looking for an option for my car brakes... cuz they are $hity.....
And i did found one option, what is still better then stock brakes. It seems what ST165 has the same size brake disks, but it has dual brake pistons, witch would give us better and smother braking with them. So i bought a pair of used brake assemblys from ST165 and did a little test this weeken, and YES, they DO DIRECT BOLT ON. Nothing needs to be changed.
Here are few pics for ya:
<<<<<< DCw / JDMart >>>>>>>
post Aug 7, 2005 - 1:59 PM
macavely
Joined Nov 4, '02
DOGGY you did it againn.... nice find...
post Aug 7, 2005 - 2:00 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Would you know if the us 165 version would have dual piston? Also how much did they improve or help? Also im guessing that would be the 89 or so, alltrac?
This post has been edited by Digndoug: Aug 7, 2005 - 2:05 PM
post Aug 7, 2005 - 2:07 PM
doGGy
Joined Oct 28, '02
Dunno about US version, but these came from All track ST165. About improvment - dont know yet, aint tested them.
I do know another thing what brake systems from ST185 bolt on directly on ST165 (rally guys with ST165 use ST185 disks and brakes cuz they are bigger, and everything fits nicly)
So i do think what ST185 brakes MIGHT fit ST as well without major problems...
QUOTE(Digndoug @ Aug 7, 2005 - 12:00 PM)
[right][snapback]321539[/snapback][/right]
post Aug 7, 2005 - 2:38 PM
Crazy! I just realized this a couple days ago too. Here was my predicament and I tried the AT200 rotors and was surprised to find that they fit. smile.gif
Unfortunately, I can't find pads for these calipers ANYWHERE.
post Aug 7, 2005 - 7:14 PM
Doggy, did you just swap the calipers or the entire assemblies ?
post Aug 7, 2005 - 7:54 PM
I didn't have to swap the whole assembly. I just swapped the caliper and caliper bracket.
post Aug 7, 2005 - 7:55 PM
i have a set of dual piston calipers for sale. they came off my jdm st185 clip.... so pm me if anyone want to do this conversion too.
for pads, cant u just use nromal alltrac pads?
post Aug 7, 2005 - 8:15 PM
QUOTE(lagos @ Aug 7, 2005 - 5:55 PM)
[right][snapback]321638[/snapback][/right]
You can't use single-piston-caliper All-Trac pads...and that's all I found on my quest for brake pads today. I hit six different auto parts stores and nothing they had for the ST165 or ST185 fit.
post Aug 8, 2005 - 1:17 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Try
https://www.1sttoyotaparts.com/partscat.html
use the mechanical parts, brake components
They're attached to a Toyota dealership -- in Washington state, as a matter of fact -- so you can call them to check details, but the prices are the best I've found for Toyota parts.
This post has been edited by Galcobar: Aug 8, 2005 - 1:22 AM
post Aug 9, 2005 - 5:47 PM
Mr_E
Joined Nov 16, '04
From UK
Nice job, but the brakes from the ST165 are, frankly, ****. Why on earth did you choose to fit them?
Most ST165 owners I know have moved to late spec ST185 brakes (single caliper), or aftermarket.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Aug 9, 2005 - 5:58 PM
vote for sticky when tested?!@
post Aug 10, 2005 - 2:45 PM
the US did have dual pods here are links
front left:(loaded)
http://www.partsamerica.com/ProductDetail....pe=5003&ptset=A
front right: (loaded)
post Aug 10, 2005 - 2:55 PM
nik
Joined Sep 30, '02
QUOTE(playr158 @ Aug 10, 2005 - 12:45 PM)
front left:(loaded)
[right][snapback]322686[/snapback][/right]
links are not working i'm very interested in this swap keep us updated
post Aug 10, 2005 - 3:02 PM
works for me?!
just go to
toyota celica all trac 1989
calipers
(thats advanaced auto parts)
post Aug 11, 2005 - 11:19 PM
Interesting...they have the calipers on there, yet Autozone, Schucks, Carquest, and the non-chain local shops here can't find pads that fit them.
post Aug 12, 2005 - 1:43 AM
post Aug 12, 2005 - 2:34 AM
QUOTE(playr158 @ Aug 11, 2005 - 11:43 PM)
[right][snapback]323287[/snapback][/right]
They had plenty of pads for ST165s in stock at some of the stores I went to as well...but none of them came close to fitting the dual-piston calipers.
post Aug 12, 2005 - 7:47 AM
i ment on the website..... unless i'm seeing sumthing your not?!
post Aug 12, 2005 - 12:05 PM
QUOTE(playr158 @ Aug 12, 2005 - 5:47 AM)
[right][snapback]323344[/snapback][/right]
Well, they're probably the same pads they have in Schucks, which didn't fit at all.
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 30th, 2024 - 8:11 PM
