AIRBAG QUESTION..., Phat99.. Kristen... |
Aug 8, 2005 - 4:36 PM |
Enthusiast Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) |
I got the strut kit.. and the hoses POP right in,, no tightening or anything, i called the company and called them like 'quick connects' or some ****.. these things look like with some air there gunna rip right off... did u have to just pop yours in with out tightening them????
thanx. SS.izzle -------------------- |
Aug 8, 2005 - 8:17 PM |
My brother has air struts and they pop right in, but there are connectors i think that go inside or somthign so when pressure is applied theres a back force to hold it in. But he is always having problems with lines breaking leaking, or valves stop working.. but man are they fun.
Aug 8, 2005 - 8:35 PM |
Enthusiast Joined Jan 26, '05 From Ashville, Ohio Currently Offline Reputation: 2 (100%) |
WHY can't anyone spell my name?!?!?!?!?! lol
Well, I wish I had the answer for that, but...... I paid a place to put my air ride on so I don't know....sorry |
Aug 8, 2005 - 10:19 PM |
Enthusiast Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
lol hey i'm with you on that.. my name is krysten as well.. but everyone wants to spell it your way
Aug 9, 2005 - 12:11 PM |
my sisters name is spelled kristin... ts rare so i figured urs was the usuak kristen.. lol
Aug 9, 2005 - 12:12 PM |
ne probs w ur air ride kris??
Aug 9, 2005 - 6:08 PM |
nope none at all
Aug 9, 2005 - 9:08 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
well, i dont know about your specific application, but I have used push connect "macro" air fittings. They seal when they're pressurized.. they're like chinese finger traps
with the ones i have used, if they look like this, theyre good to about 1000psi of air: -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Aug 9, 2005 - 9:51 PM |
Enthusiast Joined Aug 30, '02 From Ohio Currently Offline Reputation: 0 (0%) |
u put the hose in and slightly pull on it. it is suppose to lock in the connector.
mine r like the pic, but i have plastic ones. im not pushing mass psi to upgrade to the brass ones. -------------------- Jared Harwell
Aug 10, 2005 - 12:07 AM |
my front driver side keeps blowing out.. and i checked for leaks ,, i got mad leaks... they make thsee kits like ****
Aug 10, 2005 - 12:08 AM |
thanks for the input guys.. my damn compressor dont shut off either.. it was ruinnign for over 15 mins, i have to shut the car..
Aug 10, 2005 - 12:37 AM |
when the hose pops out, u can't just pop it back in.
look at the end of the hose that keeps popping out. if it is gouged(sp?) u need to take a razor(NOT CUTTERS)and cut the bad off of the hose. what psi pressure switch do u have? what size compressor? how big of a tank? i have a 5gal. tank with 2 thomas 377 1/4hp compressors. takes about 5 minutes to fill my tank. -------------------- Jared Harwell
Aug 11, 2005 - 1:07 AM |
ok... i changed all the fittings... becuz the fittings they gave me blew goat cock.. i checked for leaks... i had about 40.. i changed all the connectors too.. the other hoeses with the old fittings kept blowing rite out....
as far as the compressor problem... my switch was 175psi... it holds 150psi... i just bought one for 135psi... for the cuttoff -------------------- |
Aug 11, 2005 - 3:34 PM |
1 more question maybe you would know phat... you have a 19" rim on bags, what size tire and does it rub / how much clearance do u have, I made my car alot wider.. and i was going to go with a wider size 19" rim... do u do any modifications?? thanks alot
Aug 11, 2005 - 5:08 PM |
i have 18's
the widest i cacn get on the rear is 215-35-18. im not sure of the offset, but u cann't even get your pinky between the tire and the wheelwell lip. u can try and email bkohler81. she has 19s with bags. -------------------- Jared Harwell
Nov 22, 2005 - 6:29 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
Do you guys have any problems with the fronts and turning? The steering is very jerky and doesn't feel right at all...
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Lo-Fi Version | Time is now: December 12th, 2024 - 6:29 AM |
