> celica starting trouble, problems starting on hills
post Aug 9, 2005 - 6:35 AM
deaneop
Joined Aug 9, '05
From New zealand
hi new to the site see my problem is that when i park on a hill facing up my car wont start i have to either roll onto a flat spot and start the car or keep trying to start it leave it for ten minutes try again then it will start any ideas as the problem is well annoying
post Aug 9, 2005 - 9:15 AM
QUOTE(deaneop @ Aug 9, 2005 - 7:35 AM)
[right][snapback]322208[/snapback][/right]
sounds like a fuel filter, line, or pump problem.
post Aug 9, 2005 - 9:53 AM
macavely
Joined Nov 4, '02
you could also have a lose ground cable check those out too..
post Aug 9, 2005 - 5:14 PM
deaneop
Joined Aug 9, '05
From New zealand
Hi thanks for the replies now with the battery connection the earth does have a dodgy connection sometimes when i try and start the car with the lights on every thing dies so i have to get out and hit the eart connection then it goes. this completly crossed my mind off out now to give it a go cheers
Now car seems to be ok now last night it would not start at all went back this morning tightened the power connection on the battery(thought it was the earth that was lose turned out to be the power)and the car started strait away thank for all your help
This post has been edited by deaneop: Aug 9, 2005 - 8:12 PM
Lo-Fi Version Time is now: November 24th, 2024 - 7:35 AM
