Closed TopicStart new topic
> FAQ and HOW-TOs, ** UPDATED 07.25.07 **
post Aug 10, 2005 - 12:02 AM
Here are some links for everyone
Alarm Install Guide car alarm install guide
Adding a trunk popper to alarm/keyless entry - open your hatch with your remote
adding cupholders - from a Ford Taurus
color change some interior lights - great write up
changing the color of your clock - from green to red, blue, ect...
keeping your clock from dimming - when you turn your lights on
changing climate control light colors - using LEDS
Removing and changing the LEDS in your Climate Control Unit - A great How-To on removing and modifing the Climate Control Unit for aftermarket LEDS
changing you power window switch color - How to change the color of your window switch
7th gen short shifter - less expensive alternative to the TWM SS or TRD quickshifter
OEM speaker locations - and OEM amplifier locations
wiring an aftermarket stereo - link to .pdf install guide for 94-99 Celica
seat reupholstering how to how to re-upholster the front seats
Wiring Diagrams for Security Ect... - helpful post
projector info - Projector info and connector stuff
JDM power folding mirrors info - lots of info on how to wire the JDM power folding mirrors
lighting guide - Lighting info on your 6th gen celica
Battery Relocation - A how-to for battery relocation.
Shift Light Install - How to install a shift light.
AT200/ST204 to ST205 Combo Meter - This is a how to, showing you how to install a GTFOUR gauge cluster into your Celica.
4" front speakers - How to properly upgrade the 4 inch speakers on the 8 speaker system.
96-99 Fog Lamp Install Guide - How to install OEM fogs into your 96+
Convertible Top Motor Fix - How to fix your Convertible Top Motor
HID install into JDM projectors - How to install HID lighting into your JDM projector headlights
HID wiring install - How to install HID wiring
HID install in stock headlights - How to install HID lighting into stock headlights
Aftermarket Seat and Seatbelt info you NEED to know - Great post with saftey info about seats and seatbelts
How to remove interior door panels
Modifying the stock door speaker for a 6.5" aftermarket speaker - How to modify the stock 8" door speaker for a 6.5" aftermarket speaker
Rear Speaker install - How to install aftermarket rear speakers
Aftermarket stereo install - Quick guide for installing an aftermarket stereo
LED Dash light conversion - UK guide to LED dash lights
How to install MR2 seats - How to install MR2 seats in your celica
How to Test, Remove and Reinstall the Alternator on your ST (7afe) celica - Great How-To by GriffGirl on how to remove, test, and reinstall the alternator on your ST (7afe) celica
have somthing you wanna add? pm a mod, we'll add it in!
Lo-Fi Version Time is now: November 24th, 2024 - 6:15 PM
