new interior gauge pic, LEDs |
Aug 11, 2005 - 11:03 PM |
just trying something new...something blue -------------------- |
Aug 11, 2005 - 11:21 PM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Very nice work Dustin. BTW.....is that a boost gauge I see to the left?? Fill me in.
-------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Is it just the pic or are some areas brighter than others? When I put LEDs in my cluster parts were bright while other parts were dark and it didn't look so good.
Aug 11, 2005 - 11:30 PM |
when I resized the pic with MS paint it did distort it a bit. There are some areas that are brighter than others, getting the right LEDs are the key. Here is a more accurate pic
Aug 11, 2005 - 11:38 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Looks awesome, this is 194 led right? I think I might do mine in white like the new Toyotas
Aug 12, 2005 - 12:50 AM |
gald the leds worked out for u ... did u go with the 6led 194 bulb for the oil gauge, or the 9 led one?
Aug 12, 2005 - 7:30 AM |
actually I used the 6. The size of the 9 I don't think would of fit through the hole in the back of the cluster
Aug 12, 2005 - 9:13 AM |
Looks pretty good. I especialy like the look of the single gauge.
As far as replacement bulbs go the standard diameter of any 194 should not be more than 15 millimeters. All you should have to worry about is the length. "SUPER REFRACTOR" a.k.a. "matrix" 5 LED bulb will give you 100% even light distribution. That is what I bought and I am completely satisfied with the outcome. No "hot spots" at all. -------------------- Project ST204.5 99.88946% complete... |
Aug 12, 2005 - 12:26 PM |
Thats B.A.
Aug 12, 2005 - 10:57 PM |
Enthusiast Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
Looks good man, I got thoes wide angle led's and they did the same thing to me. I got a new set though that have the wide angle with like 4 led's pointing sideways on it, pretty expensive but check em out if the uneaven lighting bothers you. I imagine mine are like wanabegt4's
This post has been edited by slipgun: Aug 12, 2005 - 10:59 PM |
Aug 13, 2005 - 8:57 AM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
last pic looks good
Aug 13, 2005 - 11:26 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
mine are brighter and darker in places too... The speedometer is the brightest.. the fuel and temp are a little dimmer.. and the tach is almost not lit
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Aug 14, 2005 - 2:19 AM |
Enthusiast Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
batman, what did you use for the blinkers?
Aug 14, 2005 - 11:43 PM |
QUOTE(rocky2006 @ Aug 14, 2005 - 2:19 AM) batman, what did you use for the blinkers? [right][snapback]323936[/snapback][/right] I used blue LEDs from ebay (bulb #74) First I replaced the green directional covers with clear ones then replaced the bulbs with the blue LED bulbs. I was thinking about changing the blue turn bulbs to amber or yellow ones instead for a better contrast. opinions ...? -------------------- |
Aug 15, 2005 - 1:18 AM |
i think they look grat as-is. i put in blue tinting over blue plastic (took out stock green plastic blinkers) for my blinkers and they turned out a tealish. what is the link to the LED's you bought?
Aug 15, 2005 - 2:27 AM |
for the directionals, ebay item # 7992960540
I first tried the blue lighting stuff that is over my clock but they were more purple than blue. Then I tried replacing the green covers I used part of a plastic milk/water gallon jug (near the handle of the jug). I wanted to find something with the same texture of the green covers and the jug was perfect. I needed something that wasn't clear, but was see through and frosted/white. I put 2 jug peices on each side and the LEDs in and it is wicked bright and blue. -------------------- |
Aug 23, 2005 - 9:54 PM |
Enthusiast Joined Aug 22, '05 From Saskatoon, SK Currently Offline Reputation: 0 (0%) |
I just purchased an st204, and the dash lights are way too dim for me, even when cranked to max. how do LEDs work? i don't want to know how they work technically, but do you just plug them into the existing bulb sockets? is any capacitor soldering going to have to be done?
Aug 24, 2005 - 12:28 AM |
You can buy type 194 LEDs that will fit into the existing sockets.
Aug 24, 2005 - 1:20 AM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
i just put blue matrix LEDs in my gauges the other day, they look great! pics to come
-------------------- 1999 Celica GT
Lo-Fi Version | Time is now: January 11th, 2025 - 11:00 AM |
