2 Pages V  < 1 2
> installed something today, pic
post Nov 28, 2005 - 12:40 AM
dans_st
Joined May 24, '03
From Andrews TX
sorry to be asking so many question but
Will this have to be installed under/along with the sandwich adapter that I already have for the actual filter relocation kit?
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Nov 28, 2005 - 1:05 AM
ok if you do not have the relocation kit, then the adapter would go on between the filter and the block. If you do have a relocation kit, then it would still have to go between the filter and the relocation kit.
you would still want the oil to go to the filter durring cold start conditions, then when the oil reaches the 180 degrees, the valve would open and circulate the oil cooler oil through the system (cooling the oil).
or you could run the adapter at the block, then you wouldn't be filtering your oil until the valve opens and reaches 180.
you dig ?
2 Pages V  < 1 2
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 4th, 2024 - 3:21 PM
