5sfte 3" exhaust under rear suspension, pics and vid |
Sep 4, 2005 - 9:43 PM |
QUOTE(Jaws4God @ Sep 4, 2005 - 10:38 PM) I am just wondering... how many cats do our celicas have? [right][snapback]331146[/snapback][/right] AFAIK 94-95 "cali emmisons" cars all had 2, non cali have 1. i "think" 96+ is the same, but i could be wrong about 96+ . im sure someone will chime in also -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 5, 2005 - 3:25 AM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
QUOTE(presure2 @ Sep 4, 2005 - 5:47 PM) QUOTE(celicast3sgte @ Sep 4, 2005 - 5:54 PM) i dont know if this works for all movie players but for people with quicktime when you play the movie hold the fast forward button sounds like a GSXR600 at low revs [right][snapback]331082[/snapback][/right] your point is? [right][snapback]331089[/snapback][/right] my point is i did it and thought i would comment on what i thought since everyone was talking about how it sounds i found another aspect to look at it... btw, i like the sounds both realtime and ffwd. -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Sep 7, 2005 - 3:15 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
hey can you measure on flat level ground from the bottom of your 3" exhaust to the ground at the point where you rerouted it.
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 7, 2005 - 5:48 PM |
QUOTE(nik @ Sep 7, 2005 - 4:15 PM) hey can you measure on flat level ground from the bottom of your 3" exhaust to the ground at the point where you rerouted it. [right][snapback]331767[/snapback][/right] yea, i can prolly try to squeeze under there and take a pic actually, with a tape measure in there. :edit: heres the pic nik:
Sep 7, 2005 - 6:04 PM |
thanks my 3" is routed around it I might cut to do like you did but i'm still thinking about it alot of speed bumps are crazy big over here for some reason thanks again your the man
Sep 10, 2005 - 9:02 PM |
Enthusiast Joined Aug 22, '04 From Menomonie, WI Currently Offline Reputation: 0 (0%) |
if you take speed bumps slow you wont have a problem....your car lifts up as you go over them. if you go fast then you might have problems. you have about 4 inches of travel in your wheels to play with at speed...
Feb 8, 2006 - 9:08 PM |
Enthusiast Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
QUOTE I am just wondering... how many cats do our celicas have? as far as i know the 94-95s had only 1 unless they were in cali then there was 2 and then I think the 96+ had 2 -------------------- -Brian
Feb 8, 2006 - 9:11 PM |
QUOTE(presure2 @ Sep 7, 2005 - 5:48 PM) [snapback]331842[/snapback] QUOTE(nik @ Sep 7, 2005 - 4:15 PM) hey can you measure on flat level ground from the bottom of your 3" exhaust to the ground at the point where you rerouted it. [snapback]331767[/snapback] yea, i can prolly try to squeeze under there and take a pic actually, with a tape measure in there. :edit: heres the pic nik: damn manny, your car is LOW -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 8, 2006 - 10:05 PM |
Enthusiast Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
wow.... only 3" to the pipe is low! but if you guys are worried about speed bumps think of it this way. The low part of his exhaust is directly between the rear wheels and will lift up as you drive slowly over the bump, so it should still have a 3" clearance going over the speed bump. The only real problem is road kill or objects sticking up in the road or big ass holes like i got here in PA .....things that both rear tires do not drive over at the same exact time!
Looks nice! DG -------------------- |
Feb 8, 2006 - 10:28 PM |
Strate pipe Manny? Rebel. I've got strate pipe as well, but it's not 3inches. Your turbo quiets it down a bit, I think. I would like to see if mine is louder than yours. I'm so afraid to take my baffle out now. It's really loud and I don't want people to get the wrong impression on Imports, or me. And my inspection sticker is 2 months past due. I've got a strate through glass pack looking muffler.
Feb 9, 2006 - 7:46 AM |
Enthusiast Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Wow, you car is very oxidized underneath, hehe. Nice vid...Magnaflow rocks, hehe. Mine is a Magnaflow Race 14842.
Feb 9, 2006 - 10:06 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(Celiracer18 @ Feb 9, 2006 - 2:08 AM) [snapback]390994[/snapback] QUOTE I am just wondering... how many cats do our celicas have? as far as i know the 94-95s had only 1 unless they were in cali then there was 2 and then I think the 96+ had 2 My '99 had two. Still passes Houston's super stringent emmissions despite the OBDII at the Toyota dealership though. Still can't figure out why. Pressure - you're car sounds so beautiful it makes me want to get off my a$$ and install my Turbo stuff. For some reason I think I have cold feet. Probably because my '86 Swap was such a pain in the a$$. -------------------- |
Feb 9, 2006 - 11:33 AM |
yup straight pipe turbo back.
thanks DG, you know how it is its low, but where the exhaust travels with the chassis, so i just about never scrape. like DG said, if i hit a tire popper, (HUGE pothole ) it gets close..and even then, ive only hit once or twice since ive had it, and thats mostly on dirt roads, not the street. its really not that loud, except @ WOT. you want LOUD, check out the HKS jeff has. lol oobe, yea...part of living up here in the north east part of the country...lots of salt on the roads in the winters.. -------------------- Former Team 5SFTE pro member ;)
Feb 10, 2006 - 11:12 AM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
QUOTE(presure2 @ Feb 9, 2006 - 11:33 AM) [snapback]391251[/snapback] yup straight pipe turbo back. thanks DG, you know how it is its low, but where the exhaust travels with the chassis, so i just about never scrape. like DG said, if i hit a tire popper, (HUGE pothole ) it gets close..and even then, ive only hit once or twice since ive had it, and thats mostly on dirt roads, not the street. its really not that loud, except @ WOT. you want LOUD, check out the HKS jeff has. lol oobe, yea...part of living up here in the north east part of the country...lots of salt on the roads in the winters.. Haha come on man why do you need to bring me in this. LMAO Your exhaust sounds great. Mine requires ear plugs. Large and in charge. This ****er is beyond loud hahaha -------------------- I will return one day. |
Feb 10, 2006 - 6:54 PM |
QUOTE(defgeph @ Feb 10, 2006 - 11:12 AM) [snapback]391749[/snapback] QUOTE(presure2 @ Feb 9, 2006 - 11:33 AM) [snapback]391251[/snapback] yup straight pipe turbo back. thanks DG, you know how it is its low, but where the exhaust travels with the chassis, so i just about never scrape. like DG said, if i hit a tire popper, (HUGE pothole ) it gets close..and even then, ive only hit once or twice since ive had it, and thats mostly on dirt roads, not the street. its really not that loud, except @ WOT. you want LOUD, check out the HKS jeff has. lol oobe, yea...part of living up here in the north east part of the country...lots of salt on the roads in the winters.. Haha come on man why do you need to bring me in this. LMAO Your exhaust sounds great. Mine requires ear plugs. Large and in charge. This ****er is beyond loud hahaha hehe hell yea. i really like the way it sounds, just LOUD for me. -------------------- Former Team 5SFTE pro member ;)
Nov 2, 2006 - 10:04 PM |
Enthusiast Joined Sep 30, '06 Currently Offline Reputation: 0 (0%) |
NICE IM TRYING TO DO THE SAME THING !
-------------------- IT DON'T PLAY! |
Nov 3, 2006 - 9:41 AM |
Enthusiast Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
You can get 3" over axle pretty easily with some 3" u-bends.
-------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Nov 3, 2006 - 10:36 AM |
Enthusiast Joined Aug 16, '04 From Baton Rouge, LA Currently Offline Reputation: 0 (0%) |
What muffler are you using?
Nov 3, 2006 - 12:11 PM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
jeff, wheres the pic of you hugging your muffler. I love that pic.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Nov 3, 2006 - 7:13 PM |
QUOTE(zachattack15 @ Nov 3, 2006 - 10:36 AM) [snapback]499084[/snapback] What muffler are you using? magnaflow oval race 3" inlet, 7"long 4" dual walled tip. -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: November 27th, 2024 - 11:36 AM |
