> wheel bearing, rear
post Aug 14, 2005 - 4:14 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
Did some searches and just want to confirm that I am correct.
For the rears, I would have to buy the full bolton hub?
post Aug 14, 2005 - 9:36 PM
Boss-Celica
Joined Jan 27, '05
From Rockville, MD
Not really, my rear bearing went bad so I just ordered a new bearing. My friend that works at a dealer said I can just take off my hub and have him press on the new bearing.
post Aug 15, 2005 - 12:32 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
How much is the new rear bearing ???
post Aug 15, 2005 - 1:28 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
My understanding was the the rear bearing would require the replacement of the hub? Am I incorrect in that, i could have sworn that is what the chilton said when i looked at it the other day (but lord knows the chilton can / has been wrong in the past)
-FAQ
AIM : FAQdaWorld
post Aug 16, 2005 - 10:19 PM
Junior
Joined May 5, '03
From Toronto
you don't need the hub to replace the bearing, but i think most parts places sell it with the hub anyways. The toyota by me said that the bearing comes with the hub, but i elected to get an SKF one from napa for 80% cheaper.
post Aug 23, 2005 - 1:36 AM
soven
Joined Mar 14, '05
Looked around, and toyota only sell it complete with the hub (abs)
Anyone can confirm that bearings are pressed in for the rears?
post Aug 23, 2005 - 8:08 AM
toyotatech
Joined Jun 14, '05
From colorado
yes they are pressed in. if u don't have a press or don't know how to use one get the hub and bearing and bolt it on.
post Aug 25, 2005 - 1:10 AM
soven
Joined Mar 14, '05
What would be the dangers of driving around with a dying rear wheel bearing?Reason for asking is because I am slowly gethering parts for my suspension and would like to do all of them at one go. (replacing whole hub for noisy bearing)
post Aug 25, 2005 - 10:59 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i got quoted 280 from a parts store that's not even a oem part. i had a hard time finding the one without abs so i gave up and tore one off at the junkyard but now that one is going bad booo
This post has been edited by rjbibeau: Aug 25, 2005 - 10:59 PM
post Aug 29, 2005 - 1:36 AM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
i just had my rear wheel bearing replaced...
oem from toyota (abs) cost 500-550CDN... i ended up getting a used oem one for 100-150CDN
06 Civic EX
My For Sale Thread
post Aug 29, 2005 - 8:33 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
any warn bearings, will just cause more friction and drag. Also could cause a little shaking at higher speeds. If you wait it out a lil bit you'll be fine, but dont ignore it.
post Aug 30, 2005 - 9:49 PM
Boss-Celica
Joined Jan 27, '05
From Rockville, MD
I have been driving for about 2 months with a bad bear, nothing has happened. Just a sound and a vibration.
Lo-Fi Version Time is now: December 2nd, 2024 - 4:15 PM
