Dual Exhaust-Possible? |
Aug 15, 2005 - 1:48 PM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I would like to use a dual exhaust or a single one coming out of the middle to clean up the looks to my rear. Has any one done it? Did they have to cut into the
spare tire holder? |
Aug 15, 2005 - 1:52 PM |
You can split the piping after the rear suspension and make a 2 90 degree bends.
Aug 15, 2005 - 2:02 PM |
Aint the rear wheel holder in the way?
Aug 15, 2005 - 2:11 PM |
this is what I want to do
Aug 15, 2005 - 2:16 PM |
mad mods i got it
and i'll put some pics up of how with mine i just hammered the side of my spare tire well a little bit to give me some extra clearance.....this way i get perfectly even flow.... by doing what super said you will have HORRIBLE gas flow on your car and not to mention a reasonably worthless system....exhaust gas goes out the easiest path meaning shortest....with the way super said it will 90% go out the right side and 10% out the left side giving a really poor performing system, bad sound and when its cold you'll look really really goofy..... by splitting B4 the back support back as in my system with a Y pipe..you can make the both sides of equal length giving even and better flow as well as better sound This post has been edited by playr158: Aug 15, 2005 - 2:20 PM |
Aug 15, 2005 - 2:26 PM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
QUOTE(madmods @ Aug 15, 2005 - 2:11 PM) this is what I want to do [right][snapback]324375[/snapback][/right] that has to be the UGLIEST celica rear end i have ever seen in my life. and i think with your bumper it would be cooler to have a center exhaust kind of like on a Mini -------------------- 1999 Celica GT
Aug 15, 2005 - 2:31 PM |
playr, you have done all kinds of mods with you car. Looks good. Do you have any more pics from the underside. thanks
Aug 15, 2005 - 3:07 PM |
QUOTE(madmods @ Aug 15, 2005 - 3:02 PM) Aint the rear wheel holder in the way? [right][snapback]324369[/snapback][/right] You'd have to do it in-between. I used to have it on my car, but it was before I owned a digital camera and I hated it. -------------------- |
Aug 15, 2005 - 3:18 PM |
Enthusiast Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
QUOTE(blu94gt @ Aug 15, 2005 - 3:26 PM) QUOTE(madmods @ Aug 15, 2005 - 2:11 PM) this is what I want to do [right][snapback]324375[/snapback][/right] that has to be the UGLIEST celica rear end i have ever seen in my life. and i think with your bumper it would be cooler to have a center exhaust kind of like on a Mini [right][snapback]324384[/snapback][/right] omg yes that is horrible! :-X it's huge, YUCK. -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Aug 15, 2005 - 3:31 PM |
yea i'll get you some tonight mads
Aug 15, 2005 - 3:42 PM |
Wow , Im surprised you guys/gals hate it. I think that is one of the wickedest conversions i have ever seen!
Aug 15, 2005 - 6:19 PM |
Aint the rear wheel holder in the way? HEY< THATS MY CAR!!!!!!!! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Aug 15, 2005 - 10:43 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I liked that car too... especially the front with the Supra Bumper
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Aug 16, 2005 - 7:59 PM |
Enthusiast Joined Jun 28, '05 From Bay Area, CA Currently Offline Reputation: 0 (0%) |
QUOTE(playr158 @ Aug 15, 2005 - 2:16 PM) with mine i just hammered the side of my spare tire well a little bit to give me some extra clearance.....this way i get perfectly even flow.... by doing what super said you will have HORRIBLE gas flow on your car and not to mention a reasonably worthless system....exhaust gas goes out the easiest path meaning shortest....with the way super said it will 90% go out the right side and 10% out the left side giving a really poor performing system, bad sound and when its cold you'll look really really goofy..... by splitting B4 the back support back as in my system with a Y pipe..you can make the both sides of equal length giving even and better flow as well as better sound [right][snapback]324378[/snapback][/right] That's not true, it doesn't matter which side the actual exhaust flow comes out, in fact the best performance would be if it all came out one side instead of having to split the flow. It loses velocity when it hits the fork in your exhaust. However, it WOULD result in worse flow if the piping was too small for that one side to flow enough volume, but that probably won't be a problem in this case. The big question is, why do you want to add weight to the car when the dual exhaust won't flow any more than a single exhaust? Dual exhaust is only appropriate for cars with two exhaust manifolds, like a V6 or V8. Granted, there's plenty of dual exhaust I4's, but it's just a waste of weight (my SRT has a dual exhaust stock). Single exhaust is better for your performance, as long as your piping diameter is large enough. I suggest doing a single exhaust with a center exit, maybe dual-tip, right in the middle of your bumper (make a cutout). |
Aug 16, 2005 - 8:05 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
QUOTE(Gen6-GT @ Aug 16, 2005 - 8:59 PM) The big question is, why do you want to add weight to the car when the dual exhaust won't flow any more than a single exhaust? Dual exhaust is only appropriate for cars with two exhaust manifolds, like a V6 or V8. Granted, there's plenty of dual exhaust I4's, but it's just a waste of weight (my SRT has a dual exhaust stock). [right][snapback]324931[/snapback][/right] It looks cooler. -------------------- |
Aug 16, 2005 - 9:03 PM |
"That's not true, it doesn't matter which side the actual exhaust flow comes out, in fact the best performance would be if it all came out one side instead of having to split the flow. It loses velocity when it hits the fork in your exhaust. However, it WOULD result in worse flow if the piping was too small for that one side to flow enough volume, but that probably won't be a problem in this case."
dude you didn't even read what i was walking about we are comparing a 90* split compared to an even Y split.....Y is better then 90* by any physics means...... and yes the whole point is it looks cooler.....and CENTER exhaust nasty dual tip wtf....keep that to EURO stuff and mini coopers..... |
Aug 17, 2005 - 8:25 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
QUOTE(playr158 @ Aug 17, 2005 - 3:03 AM) keep that to EURO stuff and mini coopers..... [right][snapback]324954[/snapback][/right] We european have the 3S But ontopic. Looking at the back bumper en rear exhausts. Those Remus dual tip mufflers are FUGLY Cant say much about the rear bumper since its not painted. -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 17, 2005 - 11:09 AM |
i meant european cars kadett which doesn't include your 3s celica
import cars need to stick to single tip mufflers imo |
Aug 17, 2005 - 11:46 AM |
Agreed. My dual exhaust will go out also. It has been cracked just before the muffler (already posted that) its been repaired at this moment. But when time comes and i find a nice single exhaust i will put that on. Maybe before the repaint of my car i will already cut the "fake" part off because the underskirt has been cut into on the left side and has to be F/G and everthing to get it to look clean again. The exhaust looks great but its has no real purpose (rice anyone??) but the exhaust sound is so addictive, hence my low MPG -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 17, 2005 - 6:30 PM |
QUOTE(playr158 @ Aug 16, 2005 - 9:03 PM) "That's not true, it doesn't matter which side the actual exhaust flow comes out, in fact the best performance would be if it all came out one side instead of having to split the flow. It loses velocity when it hits the fork in your exhaust. However, it WOULD result in worse flow if the piping was too small for that one side to flow enough volume, but that probably won't be a problem in this case." dude you didn't even read what i was walking about we are comparing a 90* split compared to an even Y split.....Y is better then 90* by any physics means...... and yes the whole point is it looks cooler.....and CENTER exhaust nasty dual tip wtf....keep that to EURO stuff and mini coopers..... [right][snapback]324954[/snapback][/right] Actually, you said 90% would come out one side, not a 90 degree split, but I see the earlier message someone else posted about the 90 degree split and yeah, I agree, that would be REALLY bad. The exhaust is going to hit the wall with a 90 degree split in there. You want it to encounter as little interference as possible. The center exit dual-tip thing is subjective, I don't think it's that bad looking, I only suggest it for the performance benefit. The dual exhaust is just extra weight on a 4-cyl., but it does tend to sound better (louder) and it does look nicer if it's done right. As for the sound being worse with 90% flowing out one pipe, that's not necessarily true at all. A lot of the SRT exhaust systems are largely straight-back with a split-off for the second pipe, and they flow mostly from one side, but they sound even deeper than the stock system. Here's the Mopar/Borla cat-back, notice how the pipes are set up, most of the exhaust comes out the driver side. (keep in mind that this system was designed and tested by Borla, for Mopar. i.e. it's top quality for flow and sound) What it comes down to is the design; having inline resonators and as straight a piping as possible will make all the difference. The resonators will take out the raspiness of the I4 and keeping the main piping straight will give you the best flow characteristics. |
Lo-Fi Version | Time is now: November 26th, 2024 - 8:02 PM |
