> Hub or rotor help!!, expert help needed
post Aug 16, 2005 - 11:56 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
okay my situation is as followed...I still get an annoying squeeking when i drive but now its happening when i get off the freeway after driving for 30 minutes...drive on normal streets, squeek squeek squeek, goes away when i brake or accelerate...i took the rear wheel off on the passenger side and rotated rotor and noticed that the rotor is moving up after every 360*, making the caliper move and sometimes rubbing my shim off track. so my problem is either the hub, rotor, or caliper right? A few motnhs ago i had my rotor replaced, my hub got new bearings, and i put new brakes on...what should i do now??? plzz experts i need help with this annpyance.
post Aug 17, 2005 - 6:04 PM
LewFX
Joined Jan 28, '05
any ideas??? i also noticed today when i brake and there's a tight sound coming from the rear, almost a clunk...then it squeeks thereafter. whats it like when a caliper freezes or gets stuck?
This post has been edited by LewFX: Aug 17, 2005 - 6:05 PM
post Aug 18, 2005 - 12:07 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
When a caliper freezes or gets stuck, it either doesn't clamp down, stays clamped down, or partially clamps down. I'm not sure if that's what's happening to you though. It's really hard to mess up the hub, so from your descriptions, sounds like you have a warped rotor.
post Aug 18, 2005 - 2:59 PM
LewFX
Joined Jan 28, '05
thats what my mechanic thinks as well, im surprised new rotors can warp so fast.
post Sep 7, 2005 - 10:16 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
new rotors warp faster than old rotors if you dont break them in correctly. gotta slowly use them more at lower to higher speeds
i also have this problem but with the front brakes
seems to be just a sticky caliper
-Brian
Lo-Fi Version Time is now: January 10th, 2025 - 5:50 AM
