15 Pages V   1 2 3 > »
> Superstrut Suspension, ST202 - ST205 suspention
post Aug 18, 2005 - 9:18 AM
celi94
From Belgium
In Europe we also have celica's with Superstrut Suspension.
Thats wy i'm sharing this information!
The ST205 GT-Four uses a system of front suspension design unique to Toyota. It moves away from the MacPherson strut used on all other Celicas and is much more complex. This system is used on the GT-Four, some Japanese spec Corollas and the higher spec Japanese fwd Celicas (SSII and SSIII). It was available in Europe on the Carina GTi and was an option on the ST202 (thanks Dirk for the info).
My understanding of the system is that the geometry does not give the same camber and castor changes during cornering that occur with MacPherson strut. Is it better? Well, it is different. There are reliability problems if maintenance isn't kept up, TTE had continual problems and I believe they swapped the rally cars back to MacPherson strut.
A brief description of MacPherson strut is in order. The Toyota system uses a lower A arm with rubber bushings front and rear. This has only one degree of motion (ie. it rotates on the bushings). At the outer point of the A arm is a balljoint which connects to the steering knuckle and allows for rotation (steering) and pivot (shock compression). The steering knuckle is rigidly bolted to the bottom of the strut. The whole strut turns when steering, twisting in the roller bearing in the top mount. Fairly simple and cheap, used by most manufacturers.
So what is Superstrut suspension? It is a hybrid between normal MacPherson strut and a multilink setup. One of the requirements of the design brief was that the system would fit existing suspension mount locations. Therefore the system can be fitted into export Celicas as well as the Japanese lower spec SSI! The late production cars even share the same subframe.
The photo below shows the lower part of the system. This consists of a front and rear lower arm, connected (by rodends) to a connector plate. The rear arm has a rubber bushing at the inner end (the only rubber bushing at the front except swaybar D-bushings), the front arm has a balljoint. This system allows the arms to pivot as the suspension turns.
The steering knuckle is quite different to that of the MacPherson strut cars. It bolts securely to the connector plate joining the lower arms (see photo below). The top end connects to the strut part way up using a balljoint (see red arrow in left picture and upper arrow in right picture below. The strut mounts to the body in the normal way, but the lower end is secured to the front lower arm using another pivoting arm visible at the right in the photo above. This arm is near vertical in the photos, it is actually about 150mm long and pivots at each end.
user posted imageuser posted image
The photo of the assembled suspension below shows that the strut rotates minimally when steering ( the same amount as the front lower arm as it is rigidly connected). The steering knuckle moves instead. While the outboard strut moves rearwards slightly when the car turns in (turning left in the photo), it can be seen that the hub moves forward. But because of the strut movement the actual movement at the wheel is minimised.
The second photo shows the mounting points for the lower arms on the subframe.
All the info from: gtfour.supras.org.nz
post Aug 18, 2005 - 10:02 AM
post Aug 18, 2005 - 12:42 PM
Mr_E
Joined Nov 16, '04
From UK
Vote for sticky.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Dec 29, 2006 - 3:49 AM
G3D45
Joined Dec 15, '06
From Lithuania, Europe
Great write-up, but how to determine, is my ST202 with SSS or not... I'm not a mechanic (prob. LOL), but I wish to know. VIN doesn't tell anything...
post Dec 29, 2006 - 8:55 AM
Kadett
Joined Mar 17, '05
From The Netherlands
If you have 2piston Calipers in the front. Its SS Supension.
Other then that, look under the car. If your strut is shaped like this
Then you have SS
post Dec 29, 2006 - 9:14 AM
Nibbe
Joined Jan 6, '05
From Finland, Turku
Is it impossible to change superstrut to MacPherson strut (normal one)? Or if its possible how much would it cost? I just cant get a tein adjustable kit because of the superstrut model costs 2300euros and i think its way too much considering that same kit without superstrut is something like 1200euros.
Please visit on our teams new website. hrp-tuning.com
19in deepdishes - invader bodykit - invader cf hood - x-box - dls audio
post Dec 29, 2006 - 9:15 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
QUOTE(G3D45 @ Dec 29, 2006 - 1:49 AM) [snapback]513801[/snapback]
Gedai - susuk vaira ir viska tu ten pamatysi biggrin.gif O jei Superstrutas stovi - ant galiinio lango apacios eina lipdukas SuperStrut.
Sorry guys for our language biggrin.gif But ussualy when superstrut is suplied on the GT the sticker on the rear glass is placed telling this. BTW - not too many GT in 94 came with the SS.
<<<<<< DCw / JDMart >>>>>>>
post Dec 29, 2006 - 9:18 AM
Nibbe
Joined Jan 6, '05
From Finland, Turku
QUOTE(doGGy @ Dec 29, 2006 - 9:15 AM) [snapback]513831[/snapback]
doGGy
Joined Oct 28, '02
QUOTE(Nibbe @ Dec 29, 2006 - 7:14 AM) [snapback]513830[/snapback]
You will need to change Steering Gear, And whole suspension including lower arm from Mac, Struts, steering knuckle, basicly everything, including Brakes. Im pretty sure what lower subframe is the same as on the normal MAc equiped cars. Im planing to change my suspension to MAc pretty soon, cuz im tired of the SS problems already, and i only done like 200 miles with my SSIII....
post Dec 30, 2006 - 6:30 AM
G3D45
Joined Dec 15, '06
I compared mine suspension with this one and I don't see any differences. So I guess I'm SS and all the coming problems owner rolleyes.gif
post Dec 30, 2006 - 8:25 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE(doGGy @ Dec 29, 2006 - 3:15 PM) [snapback]513831[/snapback]
post Dec 30, 2006 - 11:27 AM
G3D45
Joined Dec 15, '06
I don't have such stick smile.gif Maybe it was only on the facelifted versions.
post Dec 30, 2006 - 1:19 PM
doGGy
Joined Oct 28, '02
Martin - we all know what you cheated biggrin.gif intresting... from what year does ST came with the SS suspension and SSIII stickers on spoiler biggrin.gif biggrin.gif biggrin.gif tongue.gif
post Jan 1, 2007 - 11:30 AM
Nibbe
Joined Jan 6, '05
From Finland, Turku
Btw i dont really know much about that ssI II III thing. So if ive got 1994 gt with a ss suspension does it make my car one of those? You might be laughing for this question.
post Jan 1, 2007 - 11:45 AM
Kadett
Joined Mar 17, '05
http://en.wikipedia.org/wiki/Toyota_Celica....281994-1999.29
post Jan 1, 2007 - 12:34 PM
G3D45
Joined Dec 15, '06
QUOTE(Kadett @ Jan 1, 2007 - 6:45 PM) [snapback]514381[/snapback]
There is almost no info about SSS Celicas in Europe...
post Jan 1, 2007 - 12:43 PM
doGGy
Joined Oct 28, '02
QUOTE(G3D45 @ Jan 1, 2007 - 10:34 AM) [snapback]514389[/snapback]
As long as i know and remeber (if i remeber corectly) i was reading somthere what SS in EU on GT's was availible as Special option witch you could chose when buying a celica from Dealers.
post Jan 1, 2007 - 12:58 PM
Kadett
Joined Mar 17, '05
Yup,
Sportpackage or Sport Undercarriage its called here in Holland. Came standard with ABS too.
post Jan 1, 2007 - 3:56 PM
G3D45
Joined Dec 15, '06
QUOTE(doGGy @ Jan 1, 2007 - 7:43 PM) [snapback]514391[/snapback]
Rather interesting. I don't know any similar example in nowadays cars. Such important thing like suspension would be optional rolleyes.gif
post Jan 2, 2007 - 4:59 AM
malpaso
Joined Feb 3, '06
QUOTE(doGGy @ Dec 30, 2006 - 7:19 PM) [snapback]514055[/snapback]
It's 96 Ultra Limited Malpaso's Edition biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif
QUOTE(doGGy @ Jan 1, 2007 - 6:43 PM) [snapback]514391[/snapback]
SSS are in EPC for Europe so they must be available (or was available)
Lo-Fi Version Time is now: February 17th, 2025 - 2:54 AM
