Clanking/Clunking sound when I start off. |
Apr 30, 2003 - 10:03 AM |
Enthusiast Joined Nov 13, '02 From Bangor, Me/ Huntsville, Alabama Currently Offline Reputation: 0 (0%) |
I have a 95 GT 5 speed. When I start off in 1st gear and the rpm's are pretty low I hear a clank/clunking for a couple seconds up front most of the time when I start off, also sometimes at low rpm's in 2nd gear around a corner. Its a pretty nasty sound that I don't like, it hasn't been happening that long so I don't really get it. I figured it was something with the motor mounts so I replaced the one under the intake on the drivers side as well as the rear one, still having that problem. The front mount looks just fine, so I have no idea. I dunno what else you might need for info without driving the car, but im stumped and I hate hearing this sound. Thanks.
Apr 30, 2003 - 12:20 PM |
Enthusiast Joined Sep 22, '02 From Detroit Currently Offline Reputation: 0 (0%) |
If you lived near me, I'd take you to Toyota(they diagnose me for free because I've been going there for 5 years now).
It does sound like a motor mount though. Even though the front mount 'looks' fine, it could still be worn enough to allow more play than it should. Taking your car to the dealer for a diagnoses should cost less than $50(cheaper than a new mount, they charge $37 here) and they can tell you exactly what's wrong. |
Apr 30, 2003 - 6:18 PM |
It was toyota who did the 2nd mount...perhaps I will go buck them tomorrow and see if they can check out the front one. Any other ideas guys?
Apr 30, 2003 - 8:21 PM |
Enthusiast Joined Sep 28, '02 From Lancaster Ca Currently Offline Reputation: 0 (0%) |
hey this might soudns stupid but i ehard it before and my intake came loose and was hitting the side, i thought it was an engine mount also. just a guess kinda like if the remote isnt working dont do taking it apart before you check teh batteries
Apr 30, 2003 - 9:02 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
i have a similar sound, and 3 diagnostic checks by 3 reliable sources each returned the same source... valve problem.
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Apr 30, 2003 - 10:43 PM |
hmmmmm...interesting...valve problem wouldn't be real good...ummmm...would I notice any performance changes really? Have you? I dunno, thanks. |
May 4, 2003 - 8:55 PM |
Enthusiast Joined May 1, '03 From Victoria, Australia Currently Offline Reputation: 0 (0%) |
Hi,
I had some strange noises also from my 97 Celica 2.2ltr in 1st & 2nd Gear at low revs. Initially it is the factory clutch, Toyota changed it and the noises stopped. If you havn't had it changed or worked on then maybe look at that. Also some Thick gear box oil helps. If your hearing noise when your cornering also get your CV joints (Steering Joints) checked. They also make a cluncking noise when the bearings are worn. Otherwise if you are past the 100,000Km (Sorry don't know what this is in Miles) on the odometer. Then have checked the timing blets and pullies. I have mine in for servicing as the belts are worn and pullie can become lose. Not healthy for the engine. Hope this might help...Cheers |
Sep 11, 2007 - 5:57 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I hear / feel a clunking noise just driving.. I can't find a connection between gears or speed etc.. seems to come and go.. then i'll feel it start clunking.. if I accelerate it gets worse. I popped the hood.. didn't notice anything immediately wrong.. engine mounts looked good... it is possible my intake is bumping into the engine mount.. but its hard to believe it could make the sound and feel I get...
any ideas? -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Sep 11, 2007 - 8:20 PM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
maybe your piping from your exhaust is hittin somewhere on the underbody. mine does from time to time if im stoppn n goin it just gets loose n starts hittn this piece of metal below the rear bumper.
QUOTE(TigerWoodsJr @ Apr 30, 2003 - 10:03 AM) [snapback]30038[/snapback] I have a 95 GT 5 speed. When I start off in 1st gear and the rpm's are pretty low I hear a clank/clunking for a couple seconds up front most of the time when I start off, also sometimes at low rpm's in 2nd gear around a corner. Its a pretty nasty sound that I don't like, it hasn't been happening that long so I don't really get it. I figured it was something with the motor mounts so I replaced the one under the intake on the drivers side as well as the rear one, still having that problem. The front mount looks just fine, so I have no idea. I dunno what else you might need for info without driving the car, but im stumped and I hate hearing this sound. Thanks. how fast is the clicking/clanking?? is it really quick or slow? i remember my axles were messed up along with my driverside bearing (broke apart as i took it out ) n it made clickn noises when i was goin slow and turning.. -------------------- Pandelica 2.0 in progress. |
Sep 12, 2007 - 2:11 PM |
It seems to be a constant speed.. I thought it might be my intake but I re-routed the pipe and it happened agian on the way to work.. It feels like its the axle or transmission.. Cuz I do feel the clunking near the floorboards..but i'm not good at diagnosing things.. anyone have any ideas or had the same problem?
Thanks! -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Sep 12, 2007 - 4:00 PM |
clunking, especially while turning, is almost always because of an axle problem.
Sep 13, 2007 - 9:28 AM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
ditto^ having same problem happenes in 2nd or third gear when turning
Sep 13, 2007 - 3:19 PM |
WTF!!!!!!!! sorry i had to flip out, why do you have almost the exact same name as i do?!?!?!
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Sep 13, 2007 - 6:50 PM |
Enthusiast Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
chillax
this is an old thread that guy hasnt been on in a while Last Active: March 25th, 2006 -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Sep 13, 2007 - 9:53 PM |
dude i wasnt serious. i saw that he wasnt active for a while so i just left him a comment so whenever he signs on he will get it
Sep 22, 2007 - 11:08 PM |
found out what mine was.. the passenger side axle bracket didn't have the 2 bolts in it.. not sure how they worked out.. but it just allowed the axle to vibrate.. so got one bolt in but coudln't get the other in.. gotta see if threads are ok...
Nov 12, 2007 - 6:18 PM |
Enthusiast Joined Jul 12, '06 Currently Offline Reputation: 2 (100%) |
QUOTE(freestyler121 @ Apr 30, 2003 - 7:21 PM) [snapback]30130[/snapback] hey this might soudns stupid but i ehard it before and my intake came loose and was hitting the side, i thought it was an engine mount also. just a guess kinda like if the remote isnt working dont do taking it apart before you check teh batteries I hear a rattling/clunking on low revs around 1st to 2nd gear. I thought it was transmission/suspension related then thought about the intake, before taking it to a mechanic. It was my Injen heatshield vibrating, duh... I removed it and prayed to the celica gods, hoping it would solve it. Problem solved! |
Lo-Fi Version | Time is now: January 10th, 2025 - 9:42 AM |
