BEAMS swap.., what trans do i need? |
Aug 19, 2005 - 11:52 AM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
Im looking into duin a swap in my car over the winter or next summer. So im lookin into a 4age silver top, 3sgte, or a BEAMS 3sge. Im thinkin of duin the beams the most. Im just curious on what transmision i need if i do this swap. Could i just use my factory one on the 5sfe? or would i need to go to somethin like an MR2 tranny??
Aug 19, 2005 - 12:03 PM |
you could always use the 3sge tranny that comes with it..........
Aug 19, 2005 - 1:33 PM |
do you always have to reply so sarcasticly???...i could except the company im gonna deal with, dont carry to many trannys and if they do most r automatics. I called them today about a silvertop and they only had the 4wd tranny and only had an automatic ECU.
Aug 19, 2005 - 1:44 PM |
its not sarcastic?
but search around for a clip not just a motor....clips come with trannys |
Aug 19, 2005 - 2:08 PM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
^^ He's right.
With a clip you will get ECU harness engine and tranny. -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 20, 2005 - 5:03 AM |
Enthusiast Joined Dec 8, '04 Currently Offline Reputation: 0 (0%) |
You could use the 5S-FE tranny. And good luck finding a BEAMS.
Aug 20, 2005 - 7:32 AM |
QUOTE(Valo666 @ Aug 19, 2005 - 11:52 AM) Im looking into duin a swap in my car over the winter or next summer. So im lookin into a 4age silver top, 3sgte, or a BEAMS 3sge. Im thinkin of duin the beams the most. Im just curious on what transmision i need if i do this swap. Could i just use my factory one on the 5sfe? or would i need to go to somethin like an MR2 tranny?? [right][snapback]325976[/snapback][/right] if you get a clip then use the 3sge tranny. It has better syncros and you will have a higher top speed if you use that tranny over your 5sfe. Plus the 3sge axles are much stronger than the 5sfe and you would want them because of the power/torque of the 3sge. A silvertop swap wouldn't be recommended because you have a GT-S, not an ST (you have a S series and the silvertop is an A series) -------------------- |
Lo-Fi Version | Time is now: December 1st, 2024 - 10:42 PM |
