> Still stranded 8-22-05
post Aug 21, 2005 - 2:46 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Updated and edited post:
Ok, I just retested my plugs, and i am only recieveing spark on cylinder 3. Any suggestions?
This post has been edited by madmods: Aug 22, 2005 - 10:41 AM
post Aug 21, 2005 - 2:48 AM
you got the right idea. you just use your normal spark plugs... if you get spark off of one, then youll get it off the other 4.
edit: might want to pull the efi fuse too, and unplug all 4 plug wires too
This post has been edited by lagos: Aug 21, 2005 - 2:50 AM
post Aug 21, 2005 - 10:29 AM
QUOTE(madmods @ Aug 21, 2005 - 2:46 AM)
Ok, I have no spark. What do i do next?
[right][snapback]326481[/snapback][/right]
no spark at a plug ? trace it back through the wire, the cap, ect. Find out where you are losing it.
post Aug 21, 2005 - 2:00 PM
yeah like batman said.... next you want to test the king lead plug wire that comes off from your coil... just be very carefull cause it can shock the **** out of you. if you get spark there, then the problem is with the distributor, the cap or the rotor. if you dont get spark, then the problem is with the coil, or igitor...or maybe a blown fuse somwhere.
post Aug 21, 2005 - 2:50 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i had the same problem and it ended up that a wire to my coil pack came loose.
post Aug 21, 2005 - 3:37 PM
bad spark plug wire, bad cap and rotor or bad distributor.
post Aug 21, 2005 - 4:16 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(lagos @ Aug 21, 2005 - 8:37 PM)
[right][snapback]326598[/snapback][/right]
Alright, the wires are good, the cap is suspect.
post Aug 21, 2005 - 6:03 PM
post Aug 21, 2005 - 6:09 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(presure2 @ Aug 21, 2005 - 11:03 PM)
[right][snapback]326627[/snapback][/right]
just bought a rotor for 5 and a cap for 12. Hopefully this solves the problem.
Thanks for the help guys
post Aug 22, 2005 - 10:44 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Im still stranded, and only getting spark out of 1 cylinder. A new cap and rotor didn't do a thing. A check into my coil showed that I was getting a proper reading to the resistance of the secondary coil, but 0 resistance to the primary coil. The manual says replace it. I'm going to have to buy one frown.gif Can anybody think any other reason Im only getting spark to one plug?
post Aug 22, 2005 - 10:50 AM
Lo-Fi Version Time is now: February 22nd, 2025 - 1:52 AM
