> Power Window *problem*, I am gonna scream!
post Aug 21, 2005 - 8:35 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
So, I finally pulled my 97 Celica out of storage and put a new system in it...put down my windows....pulled into a parking lot,tried to put up my passenger side window..won't go up..from both controllers,checked to make sure I didn't have the passenger side turned off with the safety button...It won't go up..it makes a click sound when I hit the down button like electricity is flowing thru it,nothing when I hit up.............
Please help! Ahhh, I don't want to have to buy a new motor for my window and replace all the crap cuz I have to be in NY for monday night...3 hr drive.
Also,if you know the answer,please respond in forum cuz my mailbox is jam packed cuz I just got back on.
Ah well,looks like I have to drive my 92 GT to work :-(
post Aug 21, 2005 - 10:14 AM
first check to see if maybe a fuse is blown.
Does it make any noise when you try to put it up ? (hum or click) ?
it may be that the window fell off track. If it wasn't used for a while (being in storage), the grease on the track could of dried up and caused this.
Take the panel off and I am sure you will see the problem
post Aug 22, 2005 - 3:17 AM
94CelicaRedHatch
Joined May 29, '03
From West Allis WI
prolly fell off the track since u can hear the electricity running
post Aug 22, 2005 - 7:25 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
ok,so,...I still don't know is wrong because I only had a 1/2 hr of daylight after work. the motor does not move the cable up or down. I don't really see a "track" per say but there isn't much movement in the window glass from side to side.
If it is the motor,does anyone know much it was to get a new one?
checked fuses in the engine and under the steering wheel...doesn't even seem to be a controller for the door, my friend suggested a bad controller behind the glovebox or somewhere else behind the firewall.
post Aug 22, 2005 - 10:00 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Sounds like the wheels on the track broke. its a common problem
post Aug 25, 2005 - 11:03 AM
TheMan
Joined Aug 25, '05
hey,
Sorry for the late reaction.
i had the same problem.
this is my solution:
I have taken out all window switches.
open the switches en make them clean with some alcohol.
then make them dry en put it all back in.
i did both side`s the passenger and the driver side.
the driver side is a little harder to do but it works fine for me.
Sorry for my bad English i am a Dutchman
Greetz michiel
post Sep 6, 2005 - 8:12 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
So, I finally got the new motor in and installed it....2 freakin weeks later! ugh! stupid cali junkyards... anyways, my Celica is back to being operationable smile.gif
I will see you guys at the October 1st meet!
post Oct 10, 2005 - 9:44 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
ok now i have the same problem...
it was stuck rolling down about 2 inches, then back up to close all the way...
NOW after trying to roll it down all the way, it made crunching noises going down. after that: it only rolls up about an inch and back down. like the motor is too weak to bring it up or something is stuck on the track. i'm getting a new motor tomorrow if anybody has any info on this-(easier fix/experience) let me know because the window actually moves. im thinking its just the motor.
post Oct 11, 2005 - 3:22 AM
purplegt4
Joined Feb 7, '03
bump
post Oct 11, 2005 - 8:57 AM
Niskyspy
Joined Jan 21, '05
From NY
Check fuses, if u installed front speakers check if u connected all the wiring harness back in cuz if u didn't that might be the problem. Then get some WD40 and spray connections if they look bad (if they are fine then u might start looking for a window electric motor)
<<AKA THA RUSSIAN>>
Lo-Fi Version Time is now: February 21st, 2025 - 2:41 PM
