> celica 3sgte swap, transmission swap
post Aug 22, 2005 - 10:58 AM
cyb593
Joined Feb 22, '04
From USA
is there any way to tell what transmission is in a car after it got swapped it was a 90 celica gts got a 3sgte put in and its from a mr2 turbo well the shifter cable rataining clips werent there i need to know which ones i need i ordered them for a 94 mr2 turbo. the reason behind this is because look for sparked plugs for the celica all trac 3sgte and they were wrong and the mr2 turbo sparks were right let me know if u think i will need the mr2 ones
post Aug 22, 2005 - 11:33 AM
The alltrac & MR2 part #s are the same, its the same engine so if they were wrong then you got something completely different.
If the person who did the swap got the engine from an MR2T and used a clip, he probably put in the E153 tranny. If he only used the engine then he could have used his stock S53 transmission. Either way, you might wanna check out Celicatech considering its a question about a 5th gen.
post Aug 23, 2005 - 4:47 PM
cyb593
Joined Feb 22, '04
From USA
this cant be true considering the spark plug wires are different. we order the alltrac ones and they were different from the mr2 turbo wires which were right.
post Aug 23, 2005 - 4:58 PM
jgreening
Joined Jan 17, '04
From Illinois
What? Can you restate your question a little more clearly?
post Aug 23, 2005 - 5:01 PM
QUOTE(cyb593 @ Aug 23, 2005 - 5:47 PM)
[right][snapback]327325[/snapback][/right]
Now im confused, are u talking wires or plugs?
post Aug 23, 2005 - 5:15 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
yeah, please clarify.
The plugs should all be the same.
The wires are different depending on year.
post Aug 25, 2005 - 5:06 PM
cyb593
Joined Feb 22, '04
From USA
the wires were different but dude said all the parts are the same number. nvm i got the answers from toyota i need thanks everyone
post Aug 25, 2005 - 5:17 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
they gave you the wrong wires??? lol
post Aug 25, 2005 - 11:20 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE(Consynx @ Aug 25, 2005 - 3:17 PM)
[right][snapback]327999[/snapback][/right]
there was a change to the dizz cap and wires in 92
post Aug 25, 2005 - 11:58 PM
Consynx
Joined Dec 25, '02
lol, that's what i get for not thinking. . .
Lo-Fi Version Time is now: February 22nd, 2025 - 1:21 PM
