DIY - changing your transmission fluid/oil, M/T 7afe |
May 3, 2006 - 2:17 AM |
i'd like to state one think. oils should ALWAYS be drained hot after a hard romp so that sediments are stirred up and drain with the oil.
also replace the standard plug with a magnetic tipped on to trap steel shavings. -------------------- |
May 18, 2006 - 1:47 PM |
Enthusiast Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
sorry for bring in this thread back to life..but...
idk why but i cant find both the fill/drain bolt in my auto 5sfe...am i not lookin hard enough...or is there anotehr location for it???... EDIT:..some1 plz slap me.....hahha..jus noticed it was for a mt .....gosh...no wonder i cant find it.....i found out that it needs a 10mm hex socket and a filter n gasket kit....... This post has been edited by DeW_H0e_GT: May 18, 2006 - 6:57 PM -------------------- |
May 18, 2006 - 9:36 PM |
Enthusiast Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) |
*slaps* dew_hoe_gt
you're welcome, and yes, the manual transmission is much easier to change than the auto, i just changed mine, and it feels a lil better but it still grinds, oddly enough i only put in about 2 1/2 quarts before it started to drain itself out again, so i just left it at 2 1/2 quarts, get a manual trans ftwwwwwwwwwwwwwwwwwwwwwwwwwwwww This post has been edited by pure_dx: May 18, 2006 - 9:38 PM |
Jul 24, 2006 - 8:31 PM |
Enthusiast Joined Jul 19, '06 From Colorado Currently Offline Reputation: 0 (0%) |
I have tried a few fluids.
ATF works best from my experiance. But I will give syncromesh a try to stop my grindage. |
Jul 24, 2006 - 8:34 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
nice tutorial!
Jul 24, 2006 - 9:32 PM |
QUOTE(Steevo @ Jul 24, 2006 - 9:31 PM) [snapback]460587[/snapback] I have tried a few fluids. ATF works best from my experiance. But I will give syncromesh a try to stop my grindage. QUOTE(tomazws @ Jul 24, 2006 - 9:34 PM) [snapback]460591[/snapback] nice tutorial! thanks. Syncromesh is the way to go -------------------- |
Aug 26, 2006 - 11:52 AM |
There are 2 reasons to have fluid come out of the fill hole when you remove the plug.
One is QUOTE(defgeph @ Nov 5, 2005 - 1:20 PM) [snapback]353477[/snapback] Make sure you fill the tranny with all four tires on the ground. If the car is jacked up when you're filling it, there will be too much fluid in there. So when somone opens the filler hole tranny fluid will come pouring out of the hole. DEF Also, if your flat spot is on a slope.... The other is if the trans is hot at all, the fluid expands, and raises the level. So if you have driven it 30 min ago, it will probably still be hot. -------------------- |
Aug 28, 2006 - 7:23 PM |
Enthusiast Joined Sep 5, '04 Currently Offline Reputation: 0 (0%) |
Cant get the damn fill hole off. Its chewed up a bit now and its just being a pain.
Aug 28, 2006 - 7:52 PM |
Using a cold chisel make a indent in the side of the plug square to the plug itself, close to a corner, then point the chisel at the next corner and give it a whack.
Aug 29, 2006 - 12:38 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
QUOTE(Steevo @ Jul 24, 2006 - 8:31 PM) [snapback]460587[/snapback] I have tried a few fluids. ATF works best from my experiance. But I will give syncromesh a try to stop my grindage. It might be because you are putting ATF(Automatic Transmission Fluid) into a standard transmission. And btw, it's called "gear oil" or "ATF" depending on the type of transmission. Let's all get the terminology correct. Gear oil goes into standard transmissions. ATF goes into automatic transmissions. We might wanna add that to the information, so that people aren't using the wrong terms, and buying the wrong thing. If someone doesn't know what they are doing, and they go into AutoZone to get something to fill their transmission with, and they are looking for "transmission fluid/oil," they will probably end up with ATF, much like Steevo here. -------------------- |
Aug 29, 2006 - 1:38 PM |
alot of manual transmissons use ATF as well. i know that in cold climates its often used instead of gear oil and infact many manual transmissions require it outright no matter what climate you're in.
you guys might also try the scott grey mix which is "Mix 2 parts Redline MTL and 1 parts Redline MT-90". that mix has been known to help smooth shifts and help with grinding. This post has been edited by Bitter: Aug 29, 2006 - 1:44 PM -------------------- |
Aug 29, 2006 - 1:43 PM |
I'm about 99% that the Celica's specs call for gear oil in manual transmissions. I go by that.
Aug 29, 2006 - 1:46 PM |
QUOTE(Mynzeyes @ Aug 29, 2006 - 1:43 PM) [snapback]474152[/snapback] I'm about 99% that the Celica's specs call for gear oil in manual transmissions. I go by that. i bet they do, but you man a unilateral statement than all manual transmissions take gear oil. thats not correct. -------------------- |
Aug 29, 2006 - 2:39 PM |
QUOTE(Bitter @ Aug 29, 2006 - 1:46 PM) [snapback]474154[/snapback] QUOTE(Mynzeyes @ Aug 29, 2006 - 1:43 PM) [snapback]474152[/snapback] I'm about 99% that the Celica's specs call for gear oil in manual transmissions. I go by that. i bet they do, but you man a unilateral statement than all manual transmissions take gear oil. thats not correct. I never said "all". See below: QUOTE(Mynzeyes @ Aug 29, 2006 - 12:38 PM) [snapback]474130[/snapback] It might be because you are putting ATF(Automatic Transmission Fluid) into a standard transmission. And btw, it's called "gear oil" or "ATF" depending on the type of transmission. Let's all get the terminology correct. Gear oil goes into <Celica> standard transmissions. ATF goes into <Celica> automatic transmissions. We might wanna add that to the information, so that people aren't using the wrong terms, and buying the wrong thing. If someone doesn't know what they are doing, and they go into AutoZone to get something to fill their transmission with, and they are looking for "transmission fluid/oil," they will probably end up with ATF, much like Steevo here. *Implied/Understood words are red and bold, as they pertain to this message board. This isn't an all inclusive board. So I speak in reference to Celicas. This post has been edited by Mynzeyes: Aug 29, 2006 - 2:44 PM -------------------- |
Aug 30, 2006 - 9:38 AM |
As a fact the shear stability of the ATF in use was more than adequate for use on the lubrication standpoint, and the addative package contains almost the same amounts of sulphated ash and zinc.
Really and honestly it helped alot while it was in use. It went from a 3K shift with grindage, to a 4+ shift. I changed to the syncromesh last night, and no more grindage at all!! mad props to whoever was pouring out the money to try and fix this problem. I found it at the local Autozone for $6.59 a quart, and it was well worth the cost. Just a side note about it, it is alot thinner (lighter in oil weight) than the 75W90 that is reccomended for use in the transmission, but it works GREAT!! |
Aug 31, 2006 - 8:15 PM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
man this pissed me off so much, i found the first bolt, the fill one. but i have no idea where the drain one is, i mean i just couldnt find it... does anyone have anymore pictures that show 'where' it is like he showed 'where' the first one is by circling it or something? cause i spent 30 bucks on that syncromesh and i wanna use ittttttt
lol thanks alot if anyone can help -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Jan 6, 2007 - 3:35 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
It sure is nice to get a list of tools needed for jobs
without going thru a book to do it. I have used these stickys and how tos countless times. They are always a great reference. -------------------- JDM guy made me do it.
Jan 7, 2007 - 12:28 AM |
Randy, did you change the fluid on the Celica or the Corolla ?
Jan 7, 2007 - 3:28 PM |
QUOTE(Batman722 @ Jan 6, 2007 - 9:28 PM) [snapback]515769[/snapback] Randy, did you change the fluid on the Celica or the Corolla ? Clearly since this is not an "allinclusive" forum it was the celica. OK you caught me, I am using this forum for info on my other toys as well. I am changing it in the rolla. It is a little tighter though. I'm just using some 75-90 because I am replacing this tranny soon and I couldn't find sycromesh anywhere around here . To bad GT4s don't have hubs I need to rebuild one on my truck. -------------------- JDM guy made me do it.
Feb 26, 2007 - 2:58 PM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(Batman722 @ Nov 28, 2005 - 6:45 AM) [snapback]360399[/snapback] QUOTE(Dunners @ Nov 28, 2005 - 1:41 AM) [snapback]360397[/snapback] While we're on the topic, What is the differences between normal engine oil and transmission oil? I couldn't imagine too much difference, they do pretty much the same thing? I'll do mine again soon with syncromesh cause i have to do my inner cv's and i may as well change it. Cheers fella's. transmission fluid (oil) is very thin, much thinner than normal engine oil. A transmission has many more smaller moving parts (gears) and the oil needs to flow throughout easier. Sorry but I thought we should clear this up. To start I am a lubrication engineer so I have a little working knowledge and experience on this subject LOL. I'm sure Dustin just got his wires crossed when he typed this as having changed it he probably knows by feel. 10w30 engine oil is waaay thinner than 75w90 Manual Transmission Oil. Gear oil is thicker because it is not having to be pumped through the small oil passageways of the engine block. This is also why it does not have to be changed out as often as it will take alot longer for the viscosity to break down to the point where t is no longer lubricating. This post has been edited by Negative: Feb 26, 2007 - 3:00 PM -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 11:10 PM |
