5 Pages V  « < 2 3 4 5 >
> DIY - changing your transmission fluid/oil, M/T 7afe
post Mar 5, 2007 - 12:42 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(tonytutino @ Aug 31, 2006 - 5:15 PM) [snapback]474993[/snapback]
man this pissed me off so much, i found the first bolt, the fill one. but i have no idea where the drain one is, i mean i just couldnt find it... does anyone have anymore pictures that show 'where' it is like he showed 'where' the first one is by circling it or something? cause i spent 30 bucks on that syncromesh and i wanna use ittttttt
lol thanks alot if anyone can help
post May 28, 2007 - 6:21 PM
malecrod
Joined May 30, '05
From MN
Did mine today with synchromesh, pretty straightforward. Only problem was that car has to be jacked up to refill from the bottom. couldn't do it from the top. Haven't driven the car yet. Waiting on clutch release cylinder/slave cylinder replacement.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Jul 8, 2007 - 8:47 PM
94yoter
Joined Apr 27, '07
From Charlotte, NC
i did mine with syncromesh today and it made a humongous difference.
my tranny used to grind when i shifted from 4th to 3rd.....
now the grind is gone
and i am completely thrilled with my fluid change.
i had a hell of a time trying to find the syncromesh though.
my local advance auto didnt carry it
and the guy up at my local NAPA had never even heard of it.
he looked at me like i was crazy when i walked in and asked for syncromesh.
i had to drive to another advance auto to get it.
other than that.....great how to article!
post Jul 30, 2008 - 12:06 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I'd like to do my tranny fluid soon, as far as fluid, I hear some use ATF with good result, and I hear some use Synchromesh with good results. If I went with ATF, I'd use Royal Purple Max ATF.
Anyone use this stuff before with good results? And does anyone know what fluid the manual actually calls for?
-Matt
post Jul 30, 2008 - 11:39 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE (GotToyota @ Jul 30, 2008 - 1:06 AM) *
-Matt
ATF is Automatic Tranny Fluid
Isnt ATF bad for manual trannies?
edit: from royal purple's website
"Max ATF is a synthetic, high-performance, automatic transmission fluid. Its low co-efficient of friction and high film strength help to dramatically reduce heat and wear. Additionally, Max ATF is more oxidation stable than other transmission fluids for longer fluid life."
This post has been edited by devilsden97: Jul 30, 2008 - 11:42 AM
Kawi Love
post Jul 30, 2008 - 11:06 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
LOL, I know what ATF is. I just know some manual trannies can use ATF.
post Jul 30, 2008 - 11:18 PM
brthrurik
Joined Mar 24, '06
From Aloha, Oregon
you can mix atf in with gear oil, that's what Toyota does with most of the newer cars...
post Jul 30, 2008 - 11:35 PM
QUOTE (brthrurik @ Jul 31, 2008 - 12:18 AM) *
and why would you think that ?
post Jul 31, 2008 - 7:30 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I think I'm just going to buy the Royal Purple 75W-90(?) tranny fluid and see how it goes.
-Matt
post Jul 31, 2008 - 8:42 AM
devilsden97
Joined Jun 13, '05
QUOTE (GotToyota @ Jul 31, 2008 - 8:30 AM) *
-Matt
good call
and for the record, when i pointed out what ATF was, it wasnt to inform you as to what the acronym was, it was more to point out that u were using autotrans fluid on your standard. (so i guess in a roundabout way i was trying to inform u of what the acronym ment...didnt mean any disrespect, didnt want u dmging your tranny for no good reason)
Kawi Love
post Jul 31, 2008 - 8:53 AM
Bricy
Joined Mar 28, '07
From Odenville, Alabama
Ive done mine with Synchromesh and it shifted like a dream afterwords. Just some advice though, those bolts WILL give you a hard time but with some PB blaster and some good 'ol muscle they will come right out. Also if your previous owner was like mine then that fluid is still the original that came in the car. When I drained the old fluid out it was a burnt copper color and smelt something awful. It might have been overkill but I changed the fluid drove it for about 2 months or so and then changed it again and the fluid looked a lot better. And a pick for my tools of the trade tongue.gif
post Jul 31, 2008 - 9:02 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (Bricy @ Jul 31, 2008 - 8:53 AM) *
Very nice, so it only took you 3 quarts? Good to know.
DevilsDen: I didn't take it as offensive man, you're good. smile.gif
post Aug 3, 2008 - 5:42 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
http://www.amsoil.com/storefront/mtf.aspx
Anyone have any info on this stuff? I'd like to get this.
-Matt
post Oct 16, 2008 - 6:34 AM
trdproven
Joined Aug 2, '05
From Guam
How would you fill the ATF? My dipstick says cool and hot instead of full or low. Common sense wise, if the car has not been running, it should be at the cool level and at idle, running it should be at the hot level?
When changing ATF, I'm using Valvoline for Dexron III vehicles. How would I change ATF and check the level? From what I've read, is when the car has not been running, fill until you reach the cool marks. Then turn on the car and standstill shift to all gears and back to park. As the car warms up check if the level is NEAR the hot marks. Then drive it a bit to get to the hot range and check again and see if it goes between the hot marks. Fill again as necessary. Correct me if I'm wrong.
This post has been edited by trdproven: Oct 16, 2008 - 7:38 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jun 5, 2009 - 7:21 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I can't seem to find the filler bolt on my 5sfe can anyone help me out?
My Celica!
post Jun 5, 2009 - 7:33 PM
Projek_01
Joined Feb 18, '07
From Calgary, Alberta
the fillter bolt is the side facing the front of your car. the bolt is located higher than the drain bolt. it is the only bolt that looks exactly like the drain bolt.
post Jun 6, 2009 - 3:27 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
i used some motul 75w-90. cost me $30 for 3 liters. Still have grinding when downshifting from 3rd to 2nd when i going about 40mph. People have said that my syncros are gone in 2nd gear. they are probably right.
So about the C52 tranny from the 7afe tranny. I just changed my clutch about a month ago and i was wondering how many bolts hold down the transmission. My friend took out the tranny and then i helped put it back together. But i think i might have forgot to torque down a bolt on the tranny with the torque wrench. I only toruqed down 4 bolts from the top half of the tranny. I couldnt find any big bolts towards the bottom of the tranny and in the chilton manual it list the amount of tranny bolts for the s54 but not for the c52. anybody know?
post Jun 17, 2009 - 5:19 PM
BonzaiCelica
Joined Apr 24, '08
bump (w/e that means) can anybody answer my question?
post Jun 21, 2009 - 4:52 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
I've been reading up about the right gearbox oil to put in my cars, and now I'm confused about what gearbox oil is right for which car.
The codes on my SS-III (Viscous LSD,FWD,Superstrut equipped) read - Trans/Axel S54 - 06D
& the codes on my GT-Four read E154F - 08B
Anyhow, after reading this ... I can't figure out whether any of this applies to my cars & What does he mean GT4 gearbox has no LSD, 185 or all including 205?
Gearbox Oil Selection
There are many many different grades of gearbox and differential oil. Toyota recommends GL-5 for the gearbox in all GT-Four models. Many disagree, but it is vital that a GL-5 is used, with good reason! Some use auto trans fluid with good results, it is now specified for most fwd Toyotas.
I have tried a few different gearbox oils in my eight years of ownership. The oil my ST165 came with was unknown so I changed to Pennzoil 75W-90 semi-synthetic. Despite this oil working very well in the W55 gearbox in my Celica Supra, it was not very good in the GT-Four, resulting in a notchy gearchange.
When my RC gearbox was fitted they used a Castrol oil. I assume this was Castrol Syntrac, as they suckered me NZ$35 a litre!! Despite the gearbox having just been rebuilt, the gearchange was crap! Very notchy.
I (again) changed to Redline oil, which at NZ$20 a litre was pretty reasonable. The correct oil to use in a GT-Four is 75W-90NS. This is the right viscosity rating, is a GL-5 oil and does not have friction modifiers for a LSD. The GT-Four gearbox does NOT have a limited slip diff in it! The viscous centre diff is a sealed unit and therefore unaffected by oil selection. This made a noticeable improvement to gearchange and was well worth doing.
GL-5 oil is mandatory in a GT-Four gearbox. As the excess traction of 4wd does not allow wheelspin the extra load is taken by the ring and pinion (the highest stressed parts in the gearbox). As a result of the high loads the contact surfaces of the teeth are known to wear prematurely. This was evident in my RC gearbox, which despite having new synchros had noticeable wear. We can only presume that the gearbox wore due to high mileage causing a poor gearchange. The owner used GL-4 oil to improve the gearchange, which increased ring and pinion wear. It was then rebuilt soon before I bought it. Hence use GL-5 or you will regret it.
That said, my RC gearbox was eventually replaced with a normal ST185 gearbox when the clutch failed. The gearchange in my RC box had deteriorated and I could trade the box over for only a $100 or so so I did so. I ran the new gearbox on ATF and the gearchange was excellent, who knows about the longativity though!
Mike W
269awhp / 273ft-lbs
post Jun 21, 2009 - 7:31 PM
blu94gt
Joined Mar 23, '05
From Kansas City
delusionz:
While I've never worked on a GT-4 to know for sure, typically all-wheel-drive cars don't have LSD, and usually if they do it's in the rear differential, not in the transmission/transaxle. The SS-III has a limited slip in the transaxle, which is why it requires a different type of fluid than your GT-4 transaxle. The reason for a different fluid is for the extra frictional forces in the LSD. The GT-4 should use just a regular GL-5 75w90 like a non-LSD front wheel drive transaxle.
1999 Celica GT
Lo-Fi Version Time is now: January 11th, 2025 - 11:03 PM
